Sony...επιπλα
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Τον περασμενο μηνα η Sony, σε συνεργασια με καποιους Ιταλους σχεδιαστες, παρουσιασε ενα περιπτερο επιπλων σε σχετικη εκθεση στο Μιλανο.
Σαφως και τα επιπλα εχουν να κανουν με τον χωρο tou home cinema
Για να δουμε μερικα...
Κώστας Φ.
Απάντηση: Sony...επιπλα
Σε κάτι πιο "προσγειωμένο":
Sony launches new BRAVIA 'home cinema in a TV stand' concept
Sony has announced a May launch for a clutter-busting new AV concept: a home theatre surround sound system built into a TV stand!
The BRAVIA Theatre RHT-G800’s attractive lines and glass top-plate hide a complete surround sound speaker system, with everything pre-installed and connected for you, so there’s no need to worry about installing multiple speakers and dealing with wiring. Just pop your TV on the top, your other kit on the shelves underneath, and connect them to the G800 on its rear, leaving no cables visible.
Obviously the surround sound element of the stand is a ‘pseudo’ affair, in that it uses processing and speaker design to create a virtual rear soundfield rather than using actual speakers positioned behind you. But Sony is confident that the ‘S-Force PRO Front Surround’ system employed works a treat.
Bass duties, meanwhile, are taken on by not one but two subwoofers, which have been engineered using special vibration-cancelling technology so that while you get rich, powerful bass, much less of it escapes through the structure of the stand and into walls and floors. Something your neighbours will doubtless appreciate…
Other features of the BRAVIA Theatre RHT-G800 include:
* HDMI interface and auxiliary inputs
* BRAVIA Theatre Sync for system integration
* illuminated display
* Gloss finish
* space for up to four additional components
* 5 x 70W audio plus 120W for the subwoofers
homecinemachoice.com
Αυτό το TV stand το θυμάμαι αρκετά παλιότερα. Μπορεί να ήταν concept τότε βέβαια.
konfan
