SONY TA-2650+ST-2950F
Ev 8848
Προς πώληση τό πανέμορφο σετ, στο μικρό τερατακι έχει γίνει πλήρες αναβάθμιση στους πυκνωτές, δεκτός κάθε έλεγχος καί ακρόαση.
Τιμή πώλησης 250 ευρώ.
Για άμεση επικοινωνία τηλ 6974273622.
Specifications
Power output: 43 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 100kHz
Total harmonic distortion: 0.2%
Damping factor: 25
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 70dB (MM), 90dB (line)
Output: 150mV (line), 30mV (DIN)
Speaker load impedance: 4Ω to 16Ω
Semiconductors: 2 x IC, 23 x transistors, 16 x diodes
Dimensions: 390 x 145 x 290mm
Weight: 8.65kg
Specifications
Type: Mono/Stereo Tuner
Tuning Bands: FM, MW, LW, SW
Tuning Scale: Analogue
FM Tuning Range: 87.5 to 108 MHz
MW Tuning Range: 530 to 1605 kHz
LW Tuning Range: 150 to 350 kHz
SW Tuning Range: 6 to 18 MHz
Sensitivity: 2uV (FM), 100uV (MW), 100uV (LW), 30uV (SW)
Signal to Noise Ratio: 68dB (FM), 50dB (MW), 50dB (LW), 50dB (SW)
Distortion: 0.6% (FM), 0.5% (MW), 0.5% (LW), 0.5% (SW)
Selectivity: 50dB (FM), 50dB (MW), 50dB (LW), 45dB (SW)
Frequency response: 40Hz to 12.5kHz (FM)
Output: 750mV (FM)
Dimensions: 390 x 145 x 310mm
Weight: 6kg
intergrale
