Soundblaster Extigy
Πρόκειται για εξωτερική κάρτα ήχου ιδανική για notebooks με τηλεχειριστήριο σε άριστη κατάσταση.Τα τεχνικά χαρακτηριστικά :
SPECIFICATIONS
High Definition Audio Quality
High Signal-to-Noise Ratio (SNR) exceeding 100dB using high linearity, low distortion 24-bit converters with resolutions of up to 96kHz
24-bit / 96kHz Analog-to-Digital Converter (ADC) for various analog inputs
24-bit / 96kHz Digital-to-Analog Converter (DAC) for 6-channel analog speaker and headphone output
Independent 24-bit Analog-to-Digital Converters for Line and Microphone input controls to provide recording and mixing flexibility
Supports Sony/Philips Digital Interface (SPDIF) format input signal of up to 24-bit / 96kHz quality
Professional Quality DSP Engine
Creative's high performance hardware Digital Signal Processor for precise sampling rate conversion, CMSS?, 3D audio algorithm processing, digital mixing or bass management; as well as accurate Dolby Digital processing
Host based 32-bit floating point effects engine for professional quality real-time effects, processing, mixing and positioning of audio streams
EAX? ADVANCED HD? Advanced Audio and 3D Audio Music Technologies
Optimized user-selectable settings for headphones, two, four or six speakers and external A/V amplifiers
Improved Creative Multi-Speaker Surround? (CMSS) technology accurately places any mono or stereo source in a 360o audio space
Realistic EAX technology reverb, panning and elevation effects bring life to your music and games
Advanced Time Scaling feature allows variable playback duration without altering pitch of original content
Powerful Audio Clean-Up feature removes noise and 'clicks' from playback of vinyl disks or cassette tape recordings
Dynamic Dolby Digital? Playback
Dolby Laboratory approved hardware. Dolby Digital decoding that does not rely on the host processor power for decoding, resulting in a consistent Dolby Digital playback that does not depend on the software or hardware DVD player
Dedicated Dolby Digital (AC-3) hardware DSP decoder with support of up to 24-bit I/O data format. Ability to decode Dolby Digital streams from optical, coaxial SPDIF input or host PC via USB connection
Built-in 24-bit DACs provide optimum audio resolution for Dolby Digital playback, making it the perfect partner for DVD applications
Optimum bass management feature allows speakers of different sizes to be accommodated - be it Creative Inspire? range of 5.1 channel speakers or '6-channel ready' home A/V amplifiers
Provides mixing of Dolby Digital audio with the real-time gameplay audio effects - a feature that a normal consumer Dolby Digital A/V receiver is not capable of supporting Advanced USB Features
Optimized dynamic bandwidth allocation architecture for audio data transfer via USB bus. This architecture provides support of simultaneous playback of 5.1 multi-channel audio together with a compressed Dolby Digital (AC-3) stream. This is ideal for playing 3D games with Dolby Digital tracks
Works with the Following Standards
Windows 98SE, 2000, Me and XP
Sound Blaster MIDI and General MIDI
Plug and Play?
EAX ADVANCED HD for music
EAX
Microsoft DirectSound?, DirectSound?3D & derivatives
Dolby Digital
USB 1.1
Sound Blaster Extigy Audio Performance
Signal-to-Noise Ratio (A-Weighted) >= 100dB
Crosstalk (Left/Right and vice versa) = -97dB
Total Harmonic Distortion + Noise at 1kHz (A-Weighted) = 0.006 %
Frequency Response at -3dBr = < 10Hz to 23kHz Specifications are based on digital-to-analog audio playback (e.g. CDDA, WAV, MP3, Dolby Digital)
Τίμη μόνο 50 ευρώ.
Υ.Γ Η πώληση γίνεται λόγω αλλαγής πλατιφόρμας (αγόρασα mac!!)
kchannel
