Soundstream Human Reign........& η τέχνη συναντά το Car Audio!!!!
Θαυμάστε τον σχεδιασμό των συγκεκριμένων μηχανημάτων!!
Ακόμα κι αν δεν σας αρέσουν, τουλάχιστον θα σας εντυπωσιάσουν..................
Human Reign Series Amp_Beauty and the Beast. An extreme departure from the norm in both appearance and performance, innovations in design and technology combine to produce an amplifier that will not only please the most eclectic art lover, but will produce enough audio power to satisfy the most stringent SPL freak...
FEATURES
Pure Class A circuitry
Fully regulated MOSFET power supply
RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
Auto High Current™ Matches the amplifier for virtually every load application
Chassisink™ Semiconductors are situated between the circuit board and heatsink for optimal thermal transfer
Ultra-Low ESR Capacitance Bank ensures rapid power delivery for dynamic peaks
Triple Darlington output circuitry
Hawkins Bass Control™ Proprietary bass equalization topology
Harmonic Bass Alignment™ Produces tighter and more accurate bass
IDI™ (Intelligent Distress Indicator) Gives visual indication of amplifier protection status
Bi-Linear built-in selectable 2-way crossovers for amplifier and line output
4-Way protection topology - Thermal, DC Offset, Speaker Short and Reverse Polarity
Selectable Balanced line inputs for highest level of noise rejection
Feature Human Reign 2 Human Reign 4
OUTPUT POWER: RMS/Chan @ 4 Ohms (Watts) 450 x 2 125 x 4
RMS/Chan @ 2 Ohms (Watts) 800 x 2 250 x 4
RMS Bridged @ 4 Ohms (Watts) 1600 x 1 500 x 2
T.H.D:. <0.02% <0.02%
SIGNAL TO NOISE RATIO: >90db >90dB
DAMPING FACTOR: >500 >500
FREQUENCY RESPONSE: 10Hz - 40KHz 10 Hz - 40KHz
INPUT SENSITIVITY (VOLTS): 0.15 - 5.0 0.15 - 5.0
CONTINUOUSLY VARIABLE ELECTRONIC CROSSOVERS: Low-pass@24dB/octave(all channels) 40 - 160Hz 40 - 160Hz
High-pass@12dB/octave(chans1&2) 50 - 500Hz 500 - 5KHz
High-pass@12dB/octave(chans3&4) - 50 - 500Hz
HAWKINS BASS CONTROL
(SUBSONIC POSITION): Variable High Pass ( no boost) 13 - 30Hz 13 - 30Hz
Variable Boost Frequency 30 - 70Hz 30 - 70Hz
HAWKINS BASS CONTROL CONTROL
(ON POSITION): Variable Bass Boost 0 - 9dB 0 - 9dB
REAR CHANNEL DE-EMPHASIS: - 6dB@7KHz
DIMENSIONS (INCHES): 13.125x23.125x7.125 13.125x23.125x7.125
Η ίδια εταιρία βγάζει επίσης και την σειρά ενισχυτών Picasso
Με ποιό διακριτικό σχεδιασμό
2, 4 & 5 Channel Amp Features
Line Outputs
Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
Continuously variable high and low-pass crossovers
Variable subwoofer equalizer
Phase inversion switch (0 - 180†)
OEM floating ground input
Platinum 4-gauge power connectors
Tri-mode operation
Optional Remote Bass Control (EGA-RM)
Digital Class Amp Features
TST™ (Twin Stack Technology) Allows 2 amplifiers to drive 1 voice coil, effectively doubling the power
High quality FR-4 circuit board
Class D circuitry
Continuously variable low-pass crossover
Continuously variable subsonic filter
Platinum 2-gauge power connectors
Source voltage 11 - 16 volts DC
1-ohm stability
Includes EGA-RM Remote Bass Boost Control
αλλά και διάφορα είδη ακόμα (εκτός από ενισχυτές & ηχεία & επεξεργαστές & multimedia κ.ο.κ
Δείτε εδώ: http://www.soundstream.com/sub/products_int.html
Βγάζει ή έβγαζε και τους Tarantulla από τους οποίους έχω δύο ολοκαίνουριους στα κουτιά τους για πούλημα :)
Δυστυχώς,δεν ξέρω ν΄ανεβάζω φωτογραφίες.Αν έμπαινε κάποιος στον κόπο να μου πει...[/img]
Σωκράτη αν υπάρχει η φωτογραφία σε κάποια διεύθυνση στο Internet (πχ http:/www.swkratn Tarantulla.jpg ή http:/www.swkratn Tarantulla.gif) το ζήτημα είναι εύκολο.
Κάτω από τον τίτλο του post reply τέρμα δεξιά υπάρχει το "κουμπί" Img.
To πατάς μία φορά, μπαίνει αυτόματα στο κείμενο στην θέση που βρίσκεται ο κέρσορας το
Κολλάς με copy paste την διεύθυνση της φωτογραφίας
(άρα θα έχει την μορφή πλέον:
[img]http:/www.swkratn Tarantulla.jpg )
ξαναπατάς το κουμπί Img (που τώρα θα έχει έναν αστερίσκο) και μπαίνει στην προηγούμενη περίπτωση η κατάληξη
Στέλνεις το post και.......έτοιμο!!!! :D :D :D
(προσοχή μόνο σε μία λεπτομέρεια: η διεύθυνση της φωτογραφίας να έχει κατάληξη .jpg ή .gif (γιαυτό σου έβαλα δύο παραδείγματα διευθύνσεων πριν.....)
Ουσιαστικά λίγο πριν κάνεις post θα έχει την μορφή αυτή:
Aν έχεις δική σου φωτογραφία και θέλεις να την κατεβάσεις υπάρχουν οι εξής τρόποι
1) Ανοίγεις έναν λογαριασμό στο http://photobucket.com και αφού κατεβάσεις από τον σκληρό του υπολογιστή σου την φωτογραφία σου μετά κάνεις ότι και πριν
(αν και στο photobucket έχει κάτω από την φωτογραφία έτοιμη την διαδικασία με το
2) Αν βαριέσαι όλη τη διαδικασία στείλε μου τις φωτογραφίες των ενισχυτών (ιδανικά σε ανάλυση 800*600) στο e-mail μου (φαίνεται στο τέλος του post μου) και τις κατεβάζω εγώ!!!
Ελπίζω να βοήθησα Σωκράτη!!! :roll: :wink:
Σε τι τιμές παίζουν?
Προδιαγραφές? (κανάλια, ισχύς, ρυθμιστικά κ.ο.κ.)
V
VIDEOMIX
Πόσο πάει η ταραντούλα φίλε Σωκράτη; Εαν ειναι σε σούπερ τιμή, αγοράζω με μετρητά.
Και άλλη μία:
Πρόκειται για "κόσμημα" και σίγουρα η φωτογραφία δεν μπορεί να αποδώσει την ομορφιά αυτού του ενισχυτή!
Το ότι είναι δικάναλοι,ίσως σας κάνει να μην ενδιαφερθείτε...
Πριν γράψω τιμή,κάντε κι εσείς μια αναζήτηση στο google και μετά τα λέμε...
Σας ευχαριστώ
Τσιλικλής Σωκράτης
Πόσο δίνεις τον καθένα Σωκράτη? :roll:
(γιατί σώνει και καλά δεν μπορεί να μας ενδιαφέρουν?
Ίσα ίσα!! Προτιμώ τους δικάναλους!!! :roll: :wink: )
mmapollo
