Spendor SA1 + stands , zebrano finish
LUXMAN
Εx-Demo Spendor SA1 zebrano finish με ελαχιστες ωρες λειτουργιας και βασεις Spendor zebrano finish , με εγγυηση αντιπροσωπειας (ημών) 3 χρονια . Ουδεμια αμυχη . Μονο 1040 ευρω (η τιμη δεν περιλαμβανει ΦΠΑ ως μεταχειρισμενο) τα ηχεια και οι βασεις !
  • Optimally damped, infinite baffle for easy room placement
  • New Spendor 15cm drive unit with large excursion motor
  • New 22mm wide surround tweeter for extended response
  • High grade crossover network with gold conductors
  • Silver plated pure copper internal cables throughout
  • WBT high copper alloy binding posts on the rear
  • Multiple panel thicknesses to reduce coincidental resonance
  • Matching low-mass stand to complement the design
  • Modern finishes including high gloss piano lacquer
Description 2-way stand or open-shelf mounted loudspeaker
Enclosure type Sealed
HF drive unit 22mm wide-surround dome with fluid cooling
LF drive unit Spendor 150mm ep38 cone
Sensitivity 85dB for 1 watt at 1 metre
Crossover point 4.8 kHz
Frequency response 75 Hz to 20 kHz ± 3dB anechoic
Typical in-room response -6dB at 60 Hz
Impedance 8 ohms nominal
Impedance minimum 6.3 ohms
Power handling 125 watts unclipped programme
Terminals WBT 4 way binding posts single-wired
Cabinet (HxWxD) 305 x 165 x 190mm
Finish zebrano high gloss, jet black piano lacquer, wenge deep satin
Weight 5.4 kg each
Stand height 600mm excluding feet
Kosmas HiFi
Στοα Φεξη 39
Πλ. Κανιγγος , ΤΚ 10677
Αθηνα
2103828281 , 2103811720 , [email protected]
PanosLouis
