Stealth Acoustics Model AX3 invisible speaker
vlasis
Φωτογράφος!
Stealth Acoustics is displaying its cool product “Model AX3” at the CES 2008. This product is a 3-Way Invisible Speaker. You can get outstanding sound from the apparent Invisible Speaker. You can install it anywhere from board room, conference room to your living room in home. This remarkable model uses a rigid frame that fits into a standard 3.5″ deep stud wall. The speaker directly gets attached to standard structural framing without requiring any special mounting brackets.
Steve Olszewski , vice president of Stealth Acoustics, said “The fact that it becomes a completely invisible part of the finished wall or ceiling adds aesthetic benefit, but listen to the speaker; there’s very little compromise for being invisible compared to other visible speakers in its price range. We have complete EASE and CLF test data to support the use of performance predication software in higher–end designs.”
The Model AX3 is priced at an MSRP $1,500.00.
Specs:
* Ceramic 20 oz Magnet
* Frequency Response: 40Hz - 20kHz, -4db
* High Frequency Motor: 25 mm Neodymium
* Low Frequency Driver: 8” Poly Cone, 1.5” Voice Coil, 8″ Woofer
* Mid Frequency Motor (x2): 25 mm Neodymium
* Nominal Impedance: 4 ohm
* Power capacity: 150 watts RMS
* Sensitivity: 85db 1 Watt 1 Meter
Via: Press
partis
