Steg qk200.4
vassilis1984
Πωλούνται δύο τεμάχια steg qk200.4, εκπληκτικοί ενισχυτές 4 καναλιών.
Τιμή 550 ευρώ ο καθένας, μαζί με τα κουτιά τους και τα παρελκόμενα τους. Οδηγούσαν ενεργά 3δρόμο οπότε έχουν παίξει μόνο στο ρελαντί.
The QK200.4 from STEG is a 4-channel amplifier with outstanding performance. The amplifier has an impressive 4 channels with an output of 200 watts RMS each at 4 ohms and can be switched to 2 ohms for an output of 4 x 300 watts. It also offers a bridged output of 2 x 600W RMS at 4 ohms and includes HP and LP filters for different frequency ranges. With its compact dimensions of 394 x 64 x 207 mm, this reliable device fits easily into any facility.
Data
4-channel power amplifier Class AB
Terminals current: 35mm²
Power: 4 x 200 Watt RMS @ 4 Ohm
Power: 4 x 300 Watt RMS @ 2 Ohm
Power bridged: 2 x 600W RMS @ 4 Ohm
HP filter 12 dB/oct. 20 - 300Hz or 400 - 6000Hz
LP filter 12 dB/oct. 30 - 600Hz or 300 - 6000Hz
Full, high-pressure or low-pressure filter.
Dimensions: 394 x 64 x 207 mm
nikolaosA
