Η Steinberg αναβάθμισε το Groove Agent στην έκδοση 3.
Το Groove Agent είναι ένας "εικονικός drummer" με πολλές δυνατότητες.
Συνεργάζεται με όλες τις εφαρμογές ήχου μέσω της πλατφόρμας VST.
Οι νέες λειτουργίες της έκδοσης 3:
- Special Agent and Percussion Agent: Adding to the Classic Groove Agent of previous versions, the two new modules offer ultra-realistic modelling of a real studio drummer as well as a range of new percussive instruments in a vast range of styles
- Dual Mode: Any two of the three modules can be combined in a virtual jam session for more dynamics and variability
- New acoustic kits with an additional assortment of digital drum machines and percussion
- 42 all-new drum styles: over 120 styles total plus hundreds of percussion performances, including the more unusual time signatures
- Drum Sample Import: Groove Agent 3 can now utilize almost any drum sound for its grooves, beats and fills, with separate samples for dry and ambience for a quick, easy way of creating a virtual drum kit miked up in its own room
- Alternating Hits: alternates samples to avoid repetition of sounds, ensuring lively, realistic drum rolls and paradiddles
- Auto Fill: intelligently generates fills to help produce dynamic drum backing tracks for improvisation on other instruments, making Groove Agent 3 ideal for use as a rehearsal and jamming tool
- A new FX section: a new EQ and compressor, with new presets ready for each drum component as well as each kit.
