Πουλάω τα εν λόγο ηχεία σε άψογη κατάσταση πακέτο μαζί με το Sub YAMAHA. Τιμή πακέτου 200 Euro
Specification: Coda 7
System type: Two-way, bookshelf/stand-mount
Enclosure type: Reflex
Dimensions: (H x W x D): 300 x 180 x 235mm (11.8 x 7.1 x 9.3 inches)
Weight: 3.3kg (7.3 lbs)
Nominal impedance: 6 ohms
Amplifier requirements: 10-70W
Maximum Output: 109dB
Frequency response: 48Hz to 20kHz +/-3.0dB (-6dB at 42Hz)
Sensitivity: 91dB at 1m for 2.83V
Finish: Black Ash or Mahogany
System: SP3192
Drive units: B130 bass/midrange unit (SP1355), 25mm tweeter (SP1354)
Crossover network: SP2228
YAMAHA YST-SW315
advanced YST Technology Yes
QD-Bass Technology Yes
High-Efficiency Power Amplifier Yes
Multi-Range Driver 10" Cone
Magnetic Shielding Yes
High Cut Filter 40 - 140 Hz
Phase Control (Normal or Reverse) Yes
Auto Standby Yes
BASS (Bass Action Selector System) Yes
Dynamic Power 270 W
Frequency Response 20 - 160 Hz (-10 dB)
Dimensions (W x H x D) 13-3/4" x 16-15/16" x 15-1/16"
Weight 41.9 lbs.
Shipping Dimensions (W x H x D) 21" x 18-1/8" x 18-1/4"
Shipping Weight (lbs.) 46.3
System: SP3192
YAMAHA YST-SW315
Auto Standby Yes
Dynamic Power 270 W
Weight 41.9 lbs.
