Subwoofer Vibe Zeta 15inch Τηλεχειριζόμενο
http://www.google.gr/imgres?hl=en&biw=1366&bih=624&tbm=isch&tbnid=T1AXWgWT3w2DlM:&imgrefurl=http://www.avreview.co.uk/review/reviewproduct/mps/RPN/4932/prod/VIBE-Zeta-Subwoofer/RCN/24/rgn/2/sp//v/5&docid=kNmhxcYCs9BFzM&imgurl=http://www.avreview.co.uk/review/images/products/2703_vibe-zeta.jpg&w=164&h=147&ei=6yWMUNefFpDAtAao9YB4&zoom=1&iact=hc&vpx=414&vpy=190&dur=41&hovh=117&hovw=131&tx=71&ty=33&sig=117571679894703339331&page=1&tbnh=117&tbnw=131&start=0&ndsp=18&ved=1t:429,r:1,s:0,i:66 Height: 450mm Width: 500mm Depth: 450mm Driver: 1x15" VIBE BlackAir Enclosure Type: 5th Order Bandpass Nominal Power: 300W RMS Signal to Noise: 100dB Inputs: Line/Spk Level Remote: Standard Available Finishes Black Gloss, Light Oak Veneer Features: Auto on /off, 0/180 phase control, Frequency /volume controls, Alloy spiked /rubber feet
Αγορασμένο προ 3 ετίας σχεδόν αχρησιμοποίητο - άριστο για χρήση Home Cinema
Πωλείται 500 ευρώ.
Απάντηση: Subwoofer Vibe Zeta 15inch Τηλεχειριζόμενο
The Zeta uses a powerful 15" driver in a compact bandpass enclosure. It produces the deepest, heaviest sound across the VIBE range, from a single subwoofer enclosure. The bandpass design pressurises the front and rear of the cone, allowing superior cone control, providing stronger, tighter bass delivery with unprecedented performance in terms of sheer power and amplifier efficiency. The Zeta will amaze any listener by reaching and empowering the lower frequencies that you had never believed to be present. Overall, the Zeta provides a serious edge of depth. Its presence is tremendous, with an excess of volume that is as much felt as it is heard.
4 0 0 Ευρω Τελευταία τιμή
JOHNDOULAMIS
