SUNFIRE TRUE SUBWOOFER SIGNATURE MICROPHONE
SUNFIRE ts - eq12 true subwoofer eq signature dual 12 in powered subwoofer with auto eq 2700 - watt amp featuring patented tracking downconverter power supply frequency response: 16 Hz to 100 Hz (+0 , -3 dB) measurement microphone and automatic internal contour compensation keeps it that way greater than 116 dB peak spl with room gain Input coupling is optical and accepts balanced, standard and high- level inputs crossover points variable from 30 hz to 100 hz input level (volume) control phase continuously adjustable 0 ° to 180 ° passive 70 hz 6 db per octave hi- pass line level output for satellite loudspeakers
950 ΕΥΡΩ 6909018848
902 TV
