loudobic
AVSite Member
- Γερμανικό διαμάντι. Άριστη κατάσταση.
- Άνετη οδήγηση στα περισσότερα ηχεία ακόμα και σε δύσκολα φορτία.
2 x 130 Watt at 8 Ohm, 2 x 250 Watt at 4 Ohm, 2 x 330 Watt at 2 Ohm
- 60 Ampere per channel. Damping factor over 800.
- On complex demands, electrostatic loudspeakers and loudspeakers which demand low impedances. Stable down to 1 Ohm.
Design:
Fast circuitry with 60 MHz output transistors, logical layout with very short signal paths, consequent dual mono design with two fully shielded transformers. Only highest quality components used. Sophisticated loudspeaker protection circuitry. Very solid chassis with WBT binding posts and inputs. Output cable Symphonic Line 10 qmm.
Input impedance:
1 Volt at 10 K-Ohm
Dimension:
450 mm x 150 mm x 210 mm (W x H x D)
Weight: 28,0 kg
Τιμή: 1600€
*Ανταλλαγή συζητήσιμη.
![](/forum/proxy.php?image=https%3A%2F%2Fi.ibb.co%2F9GwZybg%2F20240520-163751.jpg&hash=f0a37dcf4aec1a44ab2b7cc9fed6920e)
![](/forum/proxy.php?image=https%3A%2F%2Fi.ibb.co%2F7gxVxrG%2F20240520-163811.jpg&hash=076625c105f2c6d6b4da8f3679a230c9)
![](/forum/proxy.php?image=https%3A%2F%2Fi.ibb.co%2F1XH0V8J%2F20240520-171340.jpg&hash=6a5dd86f4faa065649dd7e7d166c16f4)
![](/forum/proxy.php?image=https%3A%2F%2Fi.ibb.co%2FXkJcPDk%2F20240520-171400.jpg&hash=f8a1c595bef2c360d4d715b9ca1a81f0)
Design:
Input impedance:
1 Volt at 10 K-Ohm
Dimension:
Weight: 28,0 kg
Τιμή: 1600€
