TechnoTrend S2-3600 DVB-S2 USB 2.0 box
gkontoletas
trouble in my brain
149euros
http://www.dvbshop.net/product_info....html/XTCsid/1baeaf3a2a3fd1951700d5d5aa336878
HighEnd USB-S2 HDTV receiver for Free-TV and data application
DVB Satellite according to EN 302307
Plug & Play Installation via USB 2.0 interface (USB 1.1 does not work, due to highspeed transmissions)
Video and Audio decoding via software decoder
Recording and Playback with Timeshift, Teletext, EPG etc support
Multicast managament support by NDIS driver
MPEG2 /MPEG4 (AVC/H.264) support (normal and HDTV satellite receiption)
Frequency: 950-2150 MHz
QPSK accordingly to EN 302 307
RF inputlevel -65 up to -25dBm
Input connector: IEC F-type female
Input termination on DVBcard: 75 OHM
LNB control: 14/18Volt, 22KHz, ToneBurst, DiseqC 1.0, max. 400mA powerconsumption
FOR DVB-S (standard satellite)
SCPC/MCPC support up to 45 Msymbols/s.
QPSK supported rates: 1/2, 2/3, 3/4, 5/6, 6/7, 7/8
Viterbi softdecoder rate 1/2
For DVB-S S2 (HDTV)
SCPC/MCPC support up to 30 Msymbols/s.
QPSK and 8PSK supported rates
1/2, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
LDPC and BCH decoder as per DVB-S2 requirements
Digital Nyquist root filter with 0.20, 0.25 and 0.35 roll-off factors
Up to 90 Mbps channel bitrate
General overview:
HDTV Support with AC3 5.1 Software decoder
TV, Radio and data services on notebooks or PC via USB 2.0 Interface
Representation, Record (incl. Timer), Playback of TV and Radioservices
Supported O/S: WindowsXP
TimeShift and Record Timer
Extended EPG functionality with integrated scheduled timerfunctions
Teletext support
Automatic channel setup using IP multicast group address
IP-Unicast Transport using dynamic IP address to MAC address mapping
Supports MAC address filtering
Use of up to 255 PID filters
Download MPEG2-PES speed up to 90 MBit/s.
Technical requirements
Pentium III 733 MHz (for HDTV: 3.8GHz P4/P IV)
Supported O/S: Windows 98SE, Windows ME, Windows2000 and WindowsXP
DirectX 9 or higher
Soundcard
USB 2.0 interface (NOT to be used via a USB-hub or USB-splitter!)
Graphiccard 800x600 with 16Bit or better (recommended)
CD-ROM (for driver and softwareinstallation)
Accessoires
DVB-S2 USB Box (75 x 100 x 30 mm incl. F-connector)
PowerSupply 230V AC, 50Hz to 12V DC with 1.6A
USB 2.0 cable
Master CD-ROM with driver and software application
Licence for MPEG2 and MPEG4 (AVC/H.264) software decoder
mrw
Παράξενο μου ακούγεται, δεν θα έπρεπε να κάνει hardware-assisted decoding?
Τα ίδια ισχύουν για όλες τις DVB-S2 κάρτες/USB box?
gkontoletas
trouble in my brain
Το 99,99%των καρτών δεν έχουν ενσωματωμένο hardware decoder, αυτό θα συνεχιστεί και με την νέα γενιά DVB-S2, H264 (εξαίρεση η MyHD130 με DVI option, ATSC, MPEG2 με τιμή 270$ και φυσικά επαγγελματικές με τιμή από 1000$ και πάνω).
Η είσοδος του DVB-S2 και του Η264 στην αγορά είναι πολύ αργή, ακόμη και επαγγελματίες έχουν πρόβλημα γιατί δεν έχουν ακόμη παρουσιαστεί κάρτες για να καλύψουν τα νέα δεδομένα στην δορυφορική μετάδοση.
mrw
Ο λόγος πού ρωτάω είναι το ότι έχουν βγεί τσιπάκια που κάνουν H.264 decoding για Set Top Boxes (IPTV/TriplePlay κλπ) που θα πωλούνται 100-200 Ε...
Βλέπω και στην Technotrend ότι τα tuner είναι καινούργιας σχεσδίασης και πολύ μικρών διαστάσεων, οπότε δεν πρόκειται για "βελτιώσεις" της παλιότερης τεχνολογίας...πιθανόν να εμφανιστούν "premium" κάρτες αργότερα, μάλλον στη διπλάσια τιμή, αν κρίνουμε απο το παρελθόν
Ήδη δοκιμάζοντια κάποιες κάρτες με hardware h264 decoding, ακόμα όμως τίποτα επίσημο...
Έχει ακουστεί πάντως ότι μια από αυτές θα την βγάλει και η Technotrend στην premium σειρά της...
gkontoletas
trouble in my brain
bmavroeidis
