The Hansen Audio Knight Loudspeaker
Κώστας Φ.
Specifications
General: Time Coherent; Dispersion Coherent;
Frequency Response: 29 hz to 23,000hz +/-2db;
Nominal Impedance: 6 Ohms ; Sensitivity: 87DB
Crossover: Engineered, designed and manufactured by Hansen Audio; V2 DAT (Driver Assimilation Technology); Frequency and phase optimized; Hand assembled; High grade hand selected components; Point to point silver solder connections
Tweeter: Engineered, designed and manufactured for Hansen Audio; 25mm high performance dome mounted on a dispersion optimized 6mm aluminum plate; Precision assembled
Terminal Connections:"WBT" connections; High current pole terminal; Decreased transition resistance
Woofer/Mid Band Drivers: Engineered, designed and manufactured by Hansen Audio; 182 mm driver x 2; Exotic multi-layer composite sandwich cone; Optimized geometry "Hansen" motor system; Hand assembled "Hansen Architecture" frames; Sound wave deformation prevention
Size: Height: 39 inches/Width: 9 inches/Depth: 13 inches
Cabinet: Engineered, designed, and manufactured by Hansen Audio; Hansen Audio "Cloaking Device"; "Hansen Composite Matrix" material with Class "A" finish; Acoustically inert; Sound wave refraction distortion elimination technology
Price: USD$20000
"Conclusion
Are they worth the 20G price tag? Yes. In a heartbeat. You'll get much of what Lars Hansen has spent years creating in his flagship King. No, the Knights won't go as low and with as much authority, or handle as much power, but then fifty thousand dollars is a very large difference in price. Personally, I think the King (now in V2 iteration) is the world's finest speaker. If money was no object, the Kings would be in my home 'till I was old(er) and grey(er)! If money is an object and your room is not too large (welcome to the real world), the Knights will be a superb addition to your system. The centerpiece, in fact. They work with all sorts of good equipment and will pass the WAF. And most importantly, they will give the listener many hours of musical pleasure.
After a while, when the pride of ownership has diminished and the lull in the hobby subsides for a month or two, you'll be able to head to the listening room and hear music in its purest form. No glitz or glamour, no 'mine is bigger than yours', no 'check this bass out', just the greatest art form in sound that, in the here and now and at the the Knights' size, technology and price point, will be difficult to better. Very highly recommended."
Full Review: Audiophilia.com
Saitama
