How do you get the sound of $3500 worth of high end amp and preamp for $1795?
The Portal Panache Integrated Amplifier
The Panache Integrated Amp by Portal AudioTM combines a completely transparent passive line stage with a high gain dual mono Class A/AB amplifier on one chassis.
100 w X 2 @ 8 ohms
200 w X 2 @ 4 ohms
Specifications:
Rated output: 100 watts/ch at 8 ohms;
200 watts/ch at 4 ohms
Distortion: 20 Hz-20kHz both ch driven
@ no more than 0.1% THD
Bandwidth:5 Hz to 100 kHz
Gain: 20 dB
Input impedance: 22 k Ohm
Slew rate: >20 v per microsecond
