Topfield TF6000T
Πωλείται δέκτης επίγειων ψηφιακών καναλιών Topfield TF6000T, σχεδόν αχρησιμοποίητος, με ελληνικό μενού. Τιμή: 80 ευρώ.
Χαρακτηριστικά
Tuner & Channel Decoder
Input/Loop through Connector 75Ω, IEC 169-2, Female/Male
Frequency Range VHF(174 ~ 230MHz), UHF(470 ~ 862MHz)
Signal Level Input -78 ~ -20dBm
Aerial supply 5V, max. 100mA
Demodulation OFDM
Carrier Mode 2k and 8k hierachical/non-hierarchical
Constellation QPSK, 16 and 64 QAM
Guard Interval 1/4, 1/8, 1/16 and 1/32
Transport Stream A/V Decoding
Aspect Ratio 4:3, 16:9, Pan & Scan, Letterbox
Video Resolution 720×576
Main System
Main Processor RISC CPU
A/V & Data In/Out
TV SCART
Video CVBS/S-VIDEO/RGB/YUV output
Audio L/R output
VCR SCART
Video CVBS, Audio L/R output
Video CVBS, Audio L/R input for bypass
RCA A/V
Video CVBS output
Audio L/R output
S/PDIF Digital audio or Dolby AC-3 bitstream output(Coaxial)
RS-232C
9pin D-sub type
Transfer rate 115.2Kbps
RF-Modulation
RF-Connector 75Ω, IEC 169-2, Female/Male
Output Service CH21 ~ 69(PAL), CH 14 ~ 83 (NTSC)
TV standard PAL G/I/K, NTSC-M selectable by Menu
Front Panel
Keys 3Keys(CH -/+, STANDBY)
LEDs 2LED(EXT, REMOTE)
4-digit 7-segment LEDs Service number or Time Display
RCU 42 Keys
Power Supply
Input Voltage 95 ∼250V AC, 50/60Hz
Type SMPS
Power Consumption Running : Max. 10W, Standby : 9W
Protection
Separate internal fuse.
The input shall have lightning protection
Physical Specification
Size (W×H×D) 260 × 45 × 180mm
Weight (Net) 1.6 kg
roque
