TsRemux: Transport Stream De/Re-muxer
AYTO ΕΙΝΑΙ ΤΟ DVDSHRINK ΓΙΑ BLURAY !!!
Transport Stream Re-muxer with blu-ray/Sat/OTA and now MPG/VOB/EVOB stream support. Ability to trim streams at the beginning and/or the end, Ability to pick and choose elementary streams to be kept, Ability to remux PCR-less streams, Ability to remux program streams (MPG/VOB/EVOB) into TS/M2TS, Ability to demux elementary streams as well as subtitle streams compatible with SUPreader (right click the selected stream with the mouse)
Having been inspired by Pelican9's and DrMpeg's work, I decided to write a transport stream re-muxer similar in functionality to EvoDemux. Some of the features currently implemented:
Removal of source packet header
Generation of source packet header
Regeneration of DTCP descriptor (all others are kept) which removes analog output restrictions (downrezzing of HD, macrovision etc.)
PAT/PMT generation for RAW TS files sourced from Sat/Cable/OTA
Async I/O for maximum throughput
Fixing PCR/PTS/DTS after a file merge
Removing end-of-stream markers for VC1 and AVC after a file merge
Ability to inmux SUPreader presentation graphics subtile streams
Ability to remux into simple Blu-Ray output (new)
Ability to remux MKV into TS (alpha)
Ability to extract Dolby Digital from TrueHD in Blu-Ray streams (new)
Current Version 0.0.19
Πετάς ότι θες έξω και φτιάχνεις ξανά δισκάκι...... με ότι θες !! :crazy_3: :cool_4:
http://www.digital-digest.com/software/download.php?sid=1506&ssid=0&did=1
http://www.videohelp.com/tools/TsRemux
