Ultrasound Rebus
Τα χειροποίητα βιοτεχνικά ιταλικά ηχεία με τα εξής χαρακτηριστικά (Type Reflex, Sensitivity 93 dB
,Response 50 Hz - 30 kHz, Impedance 4 ohm, Dimensions 27 x 35 x 22 cm. προς πώληση.
Οδηγούνται ANETA από έναν λαμπάτο ενισχυτή 2 Χ 9 watt αν και τετράωμα. Δίνουν μεγάλη εικόνα και περιέργως με καλό χαμηλό για τα δεδομένα του. (Φαντάζομαι πώς θα παίζουν με έναν 2 Χ 40!)
Στα μείον η έλλειψη κουτιών χαρτιών.
Η λογική τους βασίζεται στη λογική του ότι δεν υπάρχει πρακτικά crossover.
Όπως λανσάρει και η Ultrasound:
"Small dimensions, but without the limits imposed by little woofers: the 20 cm. woofer give you superior performances in extension and dynamics."
"This
system is practically without crossover avoiding distortions, phase shifts, delays and power consumption introduced by it. Besides, the realization of the cabinets, in steel, is based on an accurate study of the mechanical forces during operation; the great stiffness - low mass structure reduces colorations induced by cabinet and optimizes time-domain response. More, we achieve a total shielding of electro-magnetic fields, while the particular shape allows an optimal distribution of internal pressure. The front baffle is made of a sandwich of steel and solid walnut; this is finished by hand with oil (no industrial varnishing).
All these characteristics - high efficiency, lack of crossover and absorbent and particular construction of the cabinet - give an accurate treatment of the musical signal, with very low distortions even at very high listening volume.
Τιμή: 800 ευρώ
giannis9494
