USB Tunnel 24/96
vlasis
Φωτογράφος!
http://www.bluecircle.com/index.php?page_id=9770
The USB tunnel 24/96 is a digital to digital converter. It is designed to be used as an interface between a USB port on a computer and an external Digital to Analog Converter (DAC). The USB Tunnel is capable of handling up to 24 bits 96 Khz, ideal for high resolution audio. Regular CD quality 16/44 signal also works with the USB Tunnel.
The USB Tunnel is a true plug and play design. Once it is plugged into a USB port of a computer the computer automatically regonizes the USB Tunnel as the interface for music to the external DAC. The volume can be controlled by the volume control in the computer. This is a very useful feature when using the computer as the only source of the system because the system volume can be controlled from the computer. That eliminates the need for an additional volume control.
Features
* capable from 16 bit 44 Khz to 24 bits 96 Khz.
* Input: USB (only)
* Output: SPDIF (RCA) and AES/EBU digital (standard)
* Optional output: Toslink, BNC
* All digital outputs have signal present simultaneously
* Proprietary firmware design for highest quality signal transfer
* Galvanic isolation for low noise operation
* Using power from the USB port eliminates the need for an additional power supply
* Durable ABS construction
Pricing: (all in US dollars)
Basic $169.00
Basic with Toslink output $179.00
Basic with AES/EBU output $179.00
Basic with Toslink AND AES/EBU output $189.00
vlasis
Φωτογράφος!
Απάντηση: USB Tunnel 24/96
The USB Thingee
The USB Thingee is a digital to digital converter with a high quality built in DAC that allows the user to hook up between a computer with a USB port and an external Digital to Analog Converter. It allows you to access music files from the computer, listen to internet radio, even watch movies from the computer with high end sound coming from you main system. If you don’t have an external DAC, with the left and right RCA outputs and the 1/8" headphone jack, the USB Thingee allows the user to hook up to any line level inputs such as integrated amp, preamp and home theater receiver to play computer music through those systems. If you’re new to computer music, this is a good way to start that cannot go wrong and you won’t be spending a lot of money.
Basic $169.00
tazman71
