Vacuum State Electronics JLTi mk2 - integrated hybrid amplifier
Vacuum State Electronics JLTi - integrated hybrid amplifier
35 Watt per Channel - 50 Watt Peak
Hybrid Circuit, Tube Front End, see Schematic Diagram
Front End powered by unique Split Rails, Low Tension (much safer)
VSE type Constant Current Shunt Regulation for Tube Front-End.
Cryogenetically treated Triodes -
Solid State Monolithic IC Output Stage, Quasi Bi-Polar
T-Network Technology - dramatically lower back-EMF distortions.
35 Watts RMS (continuous) into 8 Ohm, 50W short term peak.
Output Stage Modules mounted on fibre board block for damping.
Unusual Power Supply for Output Module, very fast Low Joule
Superb Unity Gain Tube Front-End with 1MHz Bandwidth, called SLCF.
Unity Gain Tube Preamp Output on the Back Panel, also useful for Subs
Four Inputs, total 33dB Gain (enough for VSE upgraded SACD Players).
Made for 220-240V, but 110-120V version available January 2005.
The Sound: Warmish like Tubes (because harmonically it has a sense of sounding right) but not euphonic and not sterile, very refined, with dynamic and soundstage capabilities to compete with the best.
Even most Fully Tubed amplifiers will not match the sonics of this Hybrid design - personal reviews & testimonials to come.
Designed for average to high efficiency loudspeakers, not high current delivery but more like SE designs, yet a bit more power.
EURO 1250 for standard Mark 2 - 220 to 240V
hatzopou
