Verity Audio Amadis
Κώστας Φ.
The Verity design team is delighted to introduce the latest in its new series of higher-sensitivity loudspeaker designs: the Amadis. "Occupying a place in the product line just above our legacy product, the Parsifal Ovation, this two-cabinet three-way design uses new custom 6" midrange and 9.5" woofer drive units, the new Neo-dome tweeter first used in our Leonore, a new crossover topology and the refined industrial desgin from our latest offerings. Amadis is a nominal 8-ohm load and features a generous 93dB 1w/1m sensitivity rating, making it an agreeable load for many amplifier topologies."
Efficiency of 9dB @ 2.83 Vrms & 1meter on axis.
Bandwidth of 20 Hz to 50,000 Hz;
Resonance free, pure neo-ring soft dome tweeter;
Superb proprietary 5-inch (127 mm) midrange;
Superb proprietary 10-inch (254 mm) woofer;
Verity Audio rear woofer configuration for extreme definition down to the lowest octaves.
Wide amplification selection starting from 18 watts up to unlimited power;
Bi-wirable and bi-amplifiable;
Beautifully crafted and finished with exquisite Italian lacquer;
Nicely packed and delivered in deluxe Air Transportation Approved metal cases.
6moons.com
wendigo
