WBT - ΑΚΡΟΔΕΚΤΕΣ ΚΑΛΩΔΙΩΝ ΗΧΕΙΩΝ
....ΠΩΛΟΥΝΤΑΙ ΩΣ ΑΚΟΛΟΥΘΩΣ.
1. WBT-0680 Cu
Sandwich Spade
High current spade lug with elastomer shock absorber for progressive contact pressure eliminating structure-born and air-born noise as well as magnetostriction. Fully insulated body is safe to use and conforms to international safety standards. Color code: red or white. Easy fit for wire size up to 10mm2 (8AWG)
5/16" / 8.1mm Sandwich spade connector. Pure OFC copper contact is direct gold-plated.
8 ΤΕΜΑΧΙΑ
2. WBT-0644 Cu
Top quality banana plug with robust design and sleeve with polished ruthenium finish. High contact pressure due to expanding inner spike. Fitted with two Torx screws (T6) for secure crimp connection as well as cable strain relief. Color code: red or white. Easy fit for wire size up to 10mm2 (8awg).
8 ΤΕΜΑΧΙΑ
3. WBT-0437
8AWG 10.0mm Copper Crimp Sleeve
WBT crimp sleeves are made of highly conductive electrolyte copper with 24-karat direct gold-plating which gives a flexible surface protection. Sleeves have an insulated collar for added protection.
16 ΤΕΜΑΧΙΑ
4. WBT TORX SCREWS T6
16 ΤΕΜΑΧΙΑ
5. WBT-0488 T-6 Torx Key
T-6 size fits all WBT™ set screws.
1 TEMAXIO
ΚΑΤΑΣΤΑΣΗ ΑΡΙΣΤΗ
Δώρο 2 ζεύγη καλωδίων ηχείων, biwire/biamping-διατομής 10mm2, OFC, της Neotec, μήκους 1.3 μ.ζεύγος.
ΤΙΜΗ ΠΑΚΕΤΟΥ 230 ΕΥΡΩ
ΤΗΛ. 6977210589
[email protected]
Απάντηση: WBT - ΑΚΡΟΔΕΚΤΕΣ ΚΑΛΩΔΙΩΝ ΗΧΕΙΩΝ
Aυτά WBT-0644 Cu 8 τεμάχια τα δίνεις μόνα τους..και πόσο;
Κατ'αρχήν πωλούνται σαν πακέτο.
Εάν όμως υπάρξει ενδιαφέρον, από τρίτο για τα υπόλοιπα, τα δίνω στα μισά.
Ευχαριστώ
opanamas
