Wireless 3D.
MyWirelessTV Multi-Room Wireless HD Video Kit
  • Full 1080p HD and 3D Video up to 150 feet away
  • Any content, any room, any device
    • First true, multi-room solution
    • Transmit up to 150 feet
  • Brilliant HD Visual Experience
    • Virtually no latency
  • 100% Standards-Based
    • No interference with existing wireless networks
    • Compression: Standard H.264 codec
    • Transmission:Wireless Standard 802.11 WiFi
    • Content Protection: Standard HDCP 2.0 Encryption
  • Easy Setup...Everything you need is included
http://www.actiontec.com/products/product.php?pid=219
Kαι το βασικότερο:Πέριξ των 230 δολαρίων..
http://www.marketwire.com/press-release/actiontecs-mywirelesstv-hits-stores-1584684.htm
Απάντηση: Wireless 3D.
Aν ισχύει αυτό το "The new wireless solution delivers a 1080p60 3D signal up to 150ft away, with practically no latency, even through walls and floors", είναι ό,τι πρέπει για να δώσω σήμα της Nova και στον επάνω όροφο. :126:
Επίσης πολύ χρήσιμο και αυτό: "Pass-through USB and IR for mouse/keyboard and remote control from anywhere".
Thanks George!
We’ve seen wireless TV transmitters before, of course, but high-resolution and zero wires generally don’t play nicely. HP reckons its system is good enough to handle smooth Full HD, however, and supports not only video content but application mirroring, so that you can squirt your browser over to your TV and surf more comfortably from the couch.
Unfortunately that cord-cutting doesn’t come cheap. The HP Wireless TV Connect will go on sale in mid-December, priced at $179.99.
Απλά δεν ξέρουμε ακόμα αν θα είναι 1080p το σήμα στο 3D.
Belkin ScreenCast AV 4 Wireless AV-to-HDTV Adapter
Overview
Now you can connect your home theater equipment to your HDTV—and keep all the devices out of sight. Connect 4 HMDI AV devices, your Blu-ray™ player, gaming consoles and others, all wirelessly. The ScreenCast AV4 Wireless AV-to-HDTV Adapter is a great way to create a clean, elegant entertainment environment, with no need for a professional installer, no need to run cables through walls. It’s ideal for Wall-Mounted HDTVs, and allows you to store your devices up to 100ft* away, even in another room.
High Quality Picture and Sound
Enjoy full-HD 1080p resolution, 3D video, and up to 5.1 channels of surround sound. † It’s perfect for enjoying high-resolution movies and games in a seamless entertainment experience, without the tangle of wires that often accompany high performance devices.
100ft Range
Store AV equipment up to 100ft* away—in a cabinet, even in another room.
Total Control
The IR Blaster gives you total device control. Just point your remote at the TV, and ScreenCast does the rest.
*Distances will vary depending on audio/video equipment on TV and PC.
†Actual output may depend on audio/video equipment on TV and PC.
Features
Connect 4 HDMI devices
For devices like a Blu-rayTM player, DVR, gaming console and cable box
Keep devices out of sight
Store AV equipment up to 100 feet* away—in a cabinet, even in another room.
Full-HD 1080p resolution,† and 3D video.
High Quality Sound
Up to 5.1 channels of surround sound.†
IR Blaster
Total device control. Just point your remote at the TV, and ScreenCast does the rest.
Tabletop or wall-mountable receiver
Ideal for wall-mounted HDTVs.
Easy setup
Video Compatibility:
480p (EDTV), 720p (HDTV 2D & 3D), 1080i (HDTV), 1080p (FHDTV 2D & 3D)†
Supports 5.1-channel surround sound†
2D Video Resolution Compatibility:
Up to 1080p 60Hz: 480p / 720p / 1080i / 1080p VGA, XGA, SXGA
3D Video Support:
All mandatory HDMI 1.4a modes: 720p 50/59.94/60Hz, 1080p 23.98/24Hz
3D Format Support:
Frame packing, side-by-side, top/bottom
http://www.belkin.com/IWCatProductPage.process?Product_Id=552222
250$
Αν δουλεύουν απροβλημάτιστα μιλάμε πλέον για τον θάνατο των (ακριβών) καλωδίων άνω των 10μέτρων..
Κυκλοφορεί ή θα κυκλοφορήσει κάποιο από αυτά εδώ Γιώργο?
Έλα μου ντε..
Για το 1ο το βλέπω χλωμό.
Για τα άλλα 2 περισσότερες πιθανότητες.
Βέβαια υπάρχει πάντα και το Amazon:116:
Αν είναι το .co.uk τότε κάτι γίνεται. Αλλιώς θα μας γδύσουν.
Και όσους θέλουν να δώσουν κάτι παραπάνω)$379.95):
Iogear Wireless 3D Digital Kit
* Wireless 3D & HD audio / video streaming up to 100 ft.* away through standard home walls
* Multi-room - Delivers content to asecond location at the same time:
- Living room HDTV can connect to transmitters loop-through (local) port directly
- Bedroom HDTV can receive content from wireless receiver
* Connect and wirelessly transmit content from your 3D / Blu-ray / DVD player and DVR / Set-top box
* Wireless 3D support
* Wireless Full HD 1080p and 5.1 channel digital audio
* Video Resolutions: 480p, 720p, 1080i and 1080p (24 / 30 / 60fps)
* HDMI Inputs / Outputs :
- Transmitter:
2 x HDMI in
1 x HDMI out (loop-through local port)
- Receiver
1 x HDMI output
* Create the floating HDTV in almost any location such as bedroom, family room, living room, den, loft or kitchen
* Keep home theater electronic devices neatly out-of-sight
* Built-in IR allows the user control over their source devices that are hidden away in a different location
* No software or driver installation needed
* HDCP Compliant
*Distances may vary depending on environment; solid objects such as steel, concrete and brick may view shorter distances
Θα βγάλουμε κέρατα από την πολλή ακτινοβολία μέσα στο σπίτι... :601:
stathis
Ultra Home Theater
Αν κοστιζει οσο ενα ποιοτικο 15μ καλωδιο, προτιμω το καλωδιο!
Παραπάνω θα κοστίζει αλλά σίγουρα θα υπάρχουν κάποιοι που θα το προτιμήσουν αντί για το καλώδιο.
antavent
