Bραβείο EISA "in car multimedia 2004-2005" στην KE
H KENWOOD βραβεύτηκε με:
EISA AWARD IN-CAR MULTIMEDIA 2004-2005 για το μοντέλο KVT-925DVD
Αυτές είναι οι προδιαγραφές του:
[General Features]
7.0 inch Wide Colour TFT Active Matrix Display
Number of Pixel: 336,960 pixels
Screen Size: W154.1mm x H87.0mm
New Full-automatic "Z-action"Open/Close Mechanism
Motorized Tilt Angle Adjust (8 Step)
Motorized Back and Forth Display Position Adjust (4 Position)
Interactive Touch Panel Control with New Smooth GUI
Multifunction Key Operation
Audio Easy Control Mode
External Hard-key Operation (When Monitor Closed)
Partial Detachable TDF Panel with DSI & Security Code
Mini Display = 5 x 7 Dot Matrix LCD (Blue/Green/Red)
Selectable Key Illumination (Green/Red)
New Amplifier Control System with '04 PS Amplifiers EQ(Bass/Treble/Q Factor/Gain Control) & Voltage/Current/Temperature/Fan Speed Display
Advanced B.M.S.(Bass Management System) with '02 PS Amplifiers
OEM Wired Remote Option
2-way Telephone/Navigation Mute
Digital Clock (24H)
All-in-one Hide-away Black Box ( 5.1ch DSP/ TV Tuner/Receiver) Supplied
Diversity TV Antenna (Window Type) Supplied
Remote Control Unit Supplied
[Audio/Video Features]
Maximum Output Power : 50W x 4 + 47W x 1 (for Centre Channel)
4 Gold Plated Preouts with 5V Pre-output Level (Front/ Rear/ Centre/ Subwoofer)
1 RCA AV Output (PAL or NTSC according to the source)
2 RCA AV Inputs (PAL/NTSC Automatic Selection)
Video 2 Input Signal Automatic Detection Mode (Normal/ AUTO/ Rear View Camera)
Rear View Camera Connection Ready (AV Input-2 only)
RGB Input for Navigation System
Dolby Digital/ dts/ MPEG/ Linear PCM Decode
Dolby Pro Logic II (for 2ch Source to 5.1ch surround)
SFC/ 4 Band Parametric EQ/ Digital X'over/Digital Time Alignment
Sound Management System (Type of Car & Speaker Size for Each Channel Selectable)
Dolby Digital DRC (Dynamic Range Control : Wide/ Normal/ Midnight)
SPF (Speaker Protect Filter) Operation
Dual Zone Source & Volume Control
Attenuator(-20dB) with Smooth Volume Return
[Tuner Features]
FM/MW/LW 24 Station Presets (18FM, 6MW & LW)
RDS with Radio Text
K3i Clear Reception Tuner Circuit
AME (Automatic Memory Entry)
Up/Down Seek Tuning
Local Seek
FM Stereo/Mono Selector
[TV Tuner Features]
TV Tuner (PAL/ SECAM)
12 TV Station Presets
Auto Memory Entry
SNPS (Station Name Presets)
[DVD/CD Features]
DVD Video & DVD Audio Compatible Player
DVD ± R/RW Compatible (Video Format Only)
VCD Compatible
WMA (Windows Media Audio) Decoder
MP3 Decoder with ID-3 Tag Display
CD Text Ready
CD-R/CD-RW Compatible
Direct Access with Remote
Random/Repeat/Scan Play
[Changer Control Features]
Dual Disc Changer Control Capability (CH1/CH2 & AUX)
DNPS (Disc Name Presets) with Compatible CD Changers
DNPP (Disc Name Preset Play) by Remote
CD Text Ready with Compatible CD Changers
Random/Repeat/Scan Play (Disc/Track)
[Optional Accessories]
Centre Speaker Unit (KSC-700CCS)
10 Disc MP3/CD Changer (KDC-C719MP)
10/ 6 Disc CD Changer (KDC-CPS89/ KDC-C719/ KDC-C669/ KDC-C469)
Music Keg: HDD Slave Unit (KHD-C710)
Sandofer
