Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Νέος ολοκληρωμένος από την Sonneteer, με το όνομα Orton.
Χαρακτηριστικά
-Microprocessor controlled integrated amplifier.
-Dual main power supply, dual mono design.
-Separate auxiliary power supply for microprocessor.
-6 input, 2 outputs.
-Pre-out and Line-out.
-Programmable input sensitivity per channel via remote.
-Last source memory.
-Infra-red sensor at front and back for easy home installation
-160VA transformer per audio ch. with 30 watts RMS into 8ohms, with more than 80watts instantaneous power.
-12V DC output for switching on power amps.
-Remote sensor at rear for home install applications.
-Dimensions (HxWxD) 70 x 430 x 280
-Net. Weight Approx. 16Kg
Ταυτόχρονα ανανέωσε ελαφρώς την προσιτή της σειρά Bronte.
The NEW Bronte CD
-DAC: 24 bit resolution supporting up to 96 kHz sampling rate
-Fully remote controlled
-Digital out: RCA, S/PDIF
-Dimensions: (HxWxD) 70 x 430 x 280
-Net. Weight: Approx. 7Kg
The NEW Bronte digital amplifier
-Power output (1kHz sinusoid): ~150W into 4 ohm per channel
-Number of inputs Six+Line out+Pre out
-Fully remote controlled for all functions.
-Musicality (Sound quality) Excellent!
-Net. Weight Approx 13Kg
