Tannoy Gold
m1ts0s
News poster
Key features
  • Precise and neutral soundstage
  • Dual Concentric driver technology
  • Front-firing bass port
  • Titanium tweeter with Tulip waveguide
  • Class-AB system
  • Transducer-matched LF and HF bi-amplification
  • Dedicated input trim, bass and treble controls
  • Selectable automatic standby mode
Obsessive About Precision
Clearly, to build the best studio monitors you must start with the very best drivers. At Tannoy our reputation for excellence is built on the quality and performance of the speaker systems we build, and that is why we continue to design and manufacture our own drivers. Tannoy has long held to a philosophical stand on crossover points, understanding the anomalous effects of any crossover network with respect to phase. Our monitor designs have consequently always strived to minimise the number of crossover points that fall inside the critical response band. Reducing the number of crossover points reduces potential phase errors and creates a more natural and accurate device.
Tannoy Dual Concentric™
At the heart of the GOLD 8’s superb performance you will find an all-new iteration of our legendary and exclusive Tannoy Dual Concentric Driver Technology. With seven decades of refinement behind it, the Dual Concentric™ driver represents a near-perfect point source, preserving the tonal character and harmonic structure of program material as no discrete-driver system can. The benefits are immediately obvious with flat response, controlled dispersion and a wider sweet-spot in both the horizontal and vertical planes.
Point Source Tulip Waveguide
In nature, all sounds emanate from a single point in space. By centrally-locating the high frequency unit of the Dual Concentric configuration, GOLD 8 acoustically replicates the single point sound source, delivering exceptionally natural performance with an incredibly wide imaging “sweet-spot”. Delivery is further enhanced by the implementation of a highly-innovative point source Tulip Waveguide with symmetrical dispersion, which provides a broad soundstage with remarkably focused and accurate stereo imaging.
Suited For All Placements
The ideal environment for listening is a room that is “flat,” neither too reflective (reverberent) nor too absorptive (where the sound is muffled). But since all rooms are not the same acoustically, your GOLD 8 comes equipped to function in a wide variety of environments. HF trim control, and a rear panel filter switch is provided to adapt the monitor’s low frequency characteristics for the effects of boundary conditions.
https://www.tannoy.com/search/Tannoy?text=gold+5#googtrans(en|en)
Ααααααα, τι ωραία!
Μπράβο!
Λεφτά; Πόσο πάει το 8-αρι;
  • Like
Reactions: PPG
Sugah
Ζαχαρούλης
Εδώ έχουν τιμές και για τα τρία μοντέλα της σειράς
Σορρυ για το off-topic αλλα έχει ψωνίσει κάποιος απο το κατάστημα αυτό ? Δεν δέχονται ουτε πιστωτικές κάρτες ουτε paypal. Δεν είναι κάπως περίεργο ?
hawkwind78
Έχουν τουλάχιστον στοιχεία ποιοι είναι. Είναι μάλλον καθαρά μαγαζι που απευθύνεται κυρίως σε Ολλανδούς.
Τέλειο φαίνεται, μπάνικο και πάμφθηνο, αλλά...
Δεν το χαρακτηρίζει πουθενά "active"
Λέει: HF και LF "bi-amplification" 300 W σκέτο. Τι μέτρηση και πόσα σε κάθε κλάδο;
Κατανάλωση 80w στο 1/8 της πλήρους ισχύος...
... Θέλει ψάξιμο.
Απ΄ την άλλη κάνει κάτω από € 450
jpaudio
Απλά λέει ότι αναμένεται (available soon), Μήπως όταν είναι avaialable η τιμή είναι άλλη;
Τι τρόπο πληρωμής δέχεται; Κάρτα;
Γιάννης
Πάντως αν και πολύ φθηνό είναι και προσεγμένο εμφανισιακά, το βάζεις άνετα σε ένα γραφείο στο σαλόνι.
jpaudio
Πολλά φρου φρου, σχεδιάκια και κουνελάκια...
Ας μην προδικάζουμε όμως τα πράγματα. Ας δούμε την τελική τιμή όταν θα είναι διαθέσιμα και βλέπουμε. Είμαι σίγουρος ότι αν παραμείνει εκεί, κάποιος από μας θα αγοράσει και θα σχολιάσει επί τούτου. Άστε που θα βγουν και διάφορα reviews εν τω μεταξύ.
Γιάννης
Υ.Γ. Δεν είναι λίγο παράξενο στο bass reflex γύρω από τα μπροστινά ρυθμιστικά;
Post automatically merged:
Πάντως site έχουν ωραίο.
Paixtis25
