BMC Audio Germany
vlasis
Φωτογράφος!
bmc -digital/Analogue Converter
http://www.bmc-audio.de/en/bmc-dac-digital-analogue-converter.asp
For receiving digital audio signals besides the established SPDIF-compatible interfaces (AES/EBU 110 Ohm, coaxial 75 Ohm and optical Toslink) there is the exceptional and consequent “Superlink”. Unlike SPDIF transmission the different digital audio signals are not merged into one single signal stream and decoded to separate signals again after being received by the DAC. SPDIF surely makes sense from the commercial point of view, but Superlink is the solution without compromise, which requires 4 times the amount of interconnection cables but skips any coding process. Left/right-clock, bit-clock, digital audio music data are transmistted from the CD-transport to the DAC while the master-clock is generated inside the DAC and sent to the CD-transport. The transmission is done with 4 x 75-Ohm BNC cables with impedance matching.
The conversion is made by two 24-Bit / 192kHz TI/Burr-Brown PCM1792 chips with current output
vlasis
Φωτογράφος!
Απάντηση: BMC Audio Germany
bmc Phono MCCI
1. Balanced Current Injection input
2. Common base circuit for highest bandwidth
3. Widely automatic gain adjustment
4. Feedback free circuit with very short signal path
5. Full balanced circuit
6. Balanced LEF single ended class-A output
1. Special ultra-low-noise transistors with very high Hfe, 10 in parallel
2. “Balanced Current” capacitors for precise and colourful sound
3. Induction-free Polystyrene capacitors
4. Metal-thin-film resistors with 0,5% tolerance
5. Fully gold plated 4-layer printed board
6. Copper plated iron shield cover
αυτο το μεγαλο κουμπι στο κεντρο της προσοψης του cd τι ειναι??
Σαν κουρδιστηρι:105: φαινεται που κουρδιζει το μηχανισμο belt drive με το χερι (...ααααναλογικα :126:).
Καλη η ιδεα μου γιατι με το κουρδισμα γλυτωνουμε απο ενα ακομα μοτερ...:111: και τα...πεδία του...:126:
Πλακα κανουμε λογω ΑΓΙΩΝ ημερων
αυτά τα κιτρινιάρικα πυκνωτάκια με τα μαύρα καπάκια πρέπει να τα αγοράζουν με τα κοντέινερ, ε?
λενε (ας πούμε) για μια παραγγελία: ε, ψιτ! φέρε και 4 κοντέινερ από αυτά τα κιτρινιάρικα πυκνωτάκια με τα μαύρα καπάκια..
Δεν ξέρω πώς παίζουν τα μηχανάκια, πάντως ο τύπος στο Μόναχο ήτανε με διαφορά ο πιο συμπαθής από όλους τους άλλους εκθέτες.Πάρα πολύ cool κι ευγενικός στην συζήτηση.
Παρεπιπτόντως, η εταιρία αυτή πουλάει και parts μέσα από το μηχανήματά της ξεχωριστά για DIYers εάν θέλουνε όπως αυτό εδώ π.χ:
Κάπου έχω τον τιμοκατάλογο νομίζω.Εάν ενδιαφέρεται κανείς ας μου πει να ρίξω μια ματιά..
Δεν γνωρίζω πολλά από ψηφιακά, ούτε και κατά πόσο χρησιμοποιείται το belt drive, αλλά αν αρχίσουν τα αγγλάκια να λένε ότι ακούνε διαφορές και ότι ακούγεται καλύτερα και μετά από λίγο καιρό βγάλουν και σκληρούς δίσκους με belt drive γιατί ακούγονται και αυτοί καλύτερα θα αρχίσω να ακούω μουσική από γραμμόφωνο!
Όσα δεν φτάνει η αλεπού...
Και κάτι άλλο που δεν καταλαβαίνω. Αφού το σύστημα είναι ψηφιακό, και το λέιζερ διαβάζει πληροφορία, γιατί belt drive??? Για να μην δονούνται τα μηδενικά και οι άσσοι?
Ναι μπαρμπούτσαλα! Οι άγγλοι χρυσαυτιάδες "άκουσαν" πιο αναλογικό το CD player με belt drive! Μην τρελλαθούμε!
Κάνε το κόπο να διαβάσεις τι λέει εδώ ο τρελλαμένος λαμπάκιας φίλος μας για το ποιος είναι ο πραγματικός λόγος που ακούγεται διαφορετικό το C.E.C με το belt drive:
"Here is the bitter truth: CEC sounds smooth and analog like NOT because of the belt thing, but because CEC engineers modified the SPDIF trace to be unrecognizable as square. They filtered it and reshaped it to be without the low square harmonic fundamental. So DACS read it but lack bass. This is the fake analog smoothness which was created to fool people into the belt bullshit story. And NOBODY EVER discovered this. Am I the first one to use a scope? Stereophile did not bother, mr. Guru Harley drooled over the belt legend in the same way he drooled over the THETA bullshit."
http://www.lampizator.eu/LAMPIZATOR/REFERENCES/CEC/CEC TL-1X.html
roberto_portale
