Mede8er - The Greatest Show on Earth
Απάντηση: Mede8er - The Greatest Show on Earth
V3.0.2 Released
DIRECT DOWNLOAD: εδώ
Changelog: Mede8er-v3.0.2 - 3 June 2010
1. Fixed: ogg audio support
2. Fixed: wma audio support
3. Fixed: aac audio support
4. Fixed: Dolby Digital Plus support
5. Fixed: AAC 6 channel passthrough
6. Fixed: Audio player song total length time update on next song play
7. Fixed: Enable Folder Protection Setup Menu -- Zoom about.jpg and navigate up/down nav to a protected folder and press Play or Enter. Pin code screen appears and now wait about 30 sec and do not enter pin code. Mede8er boms.
8. Fixed: Pin Protection "on" enter File Manager dont input code press return and go to Setup and switch Pin
Protection "off" back to File Manager sometimes Mede8er boms
9. Fixed: Select Movies Tab the Folder Playback Function plays previously played video and not the video within the Folder selected.
10 Fixed: Media Library -- Press number jump and quickly press setup button - layer beneath partly shows.
11. Fixed: 16 x 10 Screen size save
12. Fixed: .divx video files
13. Fixed: Italtian "Formato HDD" change to "Formattazione HDD"
Known issues:
o Network (SMB) write not available to Non-Mede8er-formatted HDD (NTFS-only) -- Under investigation
o DVD resume on VIDEO_TS structure - Not working -- SDK
o Repeat A-B on BDISO -- SDK
o Restore from v1.x or v2.x backups -- not restoring all fields correctly
o On certain 16:9 DVD menus - selection highlight is misplaced -- SDK issue
o Simultaneous audio output via both HDMI and SPDIF -- SDK restriction
o resume dialogue DVDISO -- SDK
o resume play DVD VIDEO_TS -- SDK
Μολις το περασα.
Να σημειωσω οτι το λινκ που δινει το σαιτ της MEde8er δεν εχει το καλο firmware. Για καποιο λογο ενω λεει οτι ειναι 3.0.2 μου εδειξε σκετο 3.
Μετα περασα αυτο που εχει βαλει και ο lesarros και ολα καλα.
Η διαδικασια μαλιστα εγινε με το νορμαλ τροπο χωρις προβλημα.
Σχολια :
Ολα δειχνουν καλα μεχρι στιγμης.
Και ενα αρνητικο, για να τα λεμε ολα : το καλωδιο HDMI αρχιζει να τα παιζει. Χανει το σημα. Ειπαμε τζαμπα, αλλα να τη βγαλει κανα χρονο.....Ευτυχως απο καλωδια εχουμε πολλα....
Ερωτηση προς τους beta-δες : που ειναι τα νεα και φιγουρατα GUI μενου κλπ κλπ.......οεο ???
Τα νέα μενού τα απέσυραν από την 3.0 beta 2 και μετά καθώς στους περισσότερους (και σε μένα μεταξύ αυτών) δεν άρεσαν.Θύμιζαν πολύ μενού κινέζικων players.Δεν ήταν κάτι σπουδαίο κατά τη γνώμη μου.Θα τα αλλάξουν σιγά σιγά σε επόμενα firmware.
Τώρα με τον νέο firmware v 3.0.2 που εκ πρώτης όψεως δείχνει αρκετά σταθερό τι θα λέγατε να γίνει μια αναλυτική παρουσίαση στο φόρουμ,ώστε να δούμε όλες τις δυνατότητες του Mede8er αλλά και τα τυχόν bugs που έχει?
Οποιος κάτοχος του player ενδιαφέρεται να το κάνει, ας το δηλώσει εδώ για να κανονίσουμε τις λεπτομέρειες.
apotheker αν ενδιαφέρεσαι εσύ που είσαι και beta tester έχεις προτεραιότητα,εννοείται!
Ουδείς???
Αν είναι έτσι να κάνω εγώ την παρουσίαση γιατί πιστεύω ότι ο Mede8er είναι ο πλέον αδικημένος media player στην ελληνική αγορά και είναι κρίμα!
Μόλις μας έστειλαν νέα beta έκδοση για τεστ την 3.0.3 ενώ στις 14/6 θα βγάλουν άλλη την 3.0.4 για τεστ πάντα.Αρχισαν να το δουλεύουν εντατικά το firmware πλέον...
panosop
Συστημικός
αντε γιατι αυτο που υπάρχει δεν με ...ικανοποίησε πολύ..
Τα γραφικά του ρε παιδί μου, μήπως τα κανανε πολύ μικρα. ειδικά στις επιλογές πηγών?
περιμενα το 3 να ηταν πιο... κάπως...:121:
Παντως στο αρχείο των 25 GB FullHD του AVATAR, ψιλοζοριζόταν το μηχανακι...
Στη beta είναι ποιο μεγάλα,αλλά το ράδιο δεν παίζει καθόλου!
Έχει κανείς καμμιά ιδέα γιατί δεν δουλεύει το ράδιο μετά την αναβάθμιση σε 3.0.2
Εχουν βγει προβλήματα στο ράδιο με την 3.0.2 είναι αλήθεια.
Πήγαινε στο search και βάλε λέξεις κλειδιά όπως pop,greece,greek,rock κλπ και θα σου κατεβάσει σταθμούς.Σε μένα τουλάχιστον έτσι δούλεψε.Σαν έσχατη λύση κάνε reinstall το firmware.
Βγήκε το firmware 3.0.4 θα το κατεβάσετε εδώ
Emergency Installation Procedure
- Download the latest Firmware from the Mede8er website;
- Unzip the file i.e. install.img;
- Copy this file to the root directory of a Flash Drive;
- Plug the flash drive into the Mede8er;
- Disconnect the power jack at the rear of the Mede8er then plug it back in;
- Now press the on/off button (on Mede8er unit - not remote) - keep it pressed in for 10 seconds and then release;
- After +- 15sec the LED on the front fascia of the Mede8er with flash red-blue;
- You will get a progress bar on your TV display (some TV's will not display this);
- Wait until the Mede8er re boots itself +/- 90 sec;
- Your Mede8er is now updated;
- Re-boot once by pulling power and use as normal;
xxxx WARNING - DO NOT REMOVE POWER DURING THE UPDATE PROCESS xxxxx
NOTE: Once you update to V3.0.4 you cannot easily go back to older versions below V2.0.2 if you are using an internal Hard Drive that was formatted with the Mede8er due to a core code (SDK) upgrade. The update process will not damage your Hard Drive contents but the Hard Drive will then be shown as HDD1 instead of C. If you are not using an internal Hard Drive than you can roll back to a earlier version without any problems
A) Do not update the Mede8er from the built-in update facility on the Setup screen;
B) If you experience Samba network connection problems we suggest you perform a "Restore Default" in setup Menu and re-boot the Mede8er.
C) After the Firmware is installed please re-boot the Mede8er – Unplug DC Jack and then re-plug;
D) Do not do a Firmware Restore to update your Mede8er settings across versions - rather input settings manually;
E) Important: Set your TV Resolution on the Main Setup Menu – Video System - for the first time after firmware update.
Mede8er Change Log v3.0.4 -- 14 June 2010
14 June 2010 RTD1073-128M-HMC-M03I-20100613-v7.0.7.r4282.QA20100402_SANJIA_ENGLISH_RC18
1. Fixed: Internet Radio. Station list limited by Shoutcast - Require to Use Search for more stations
Do not use “System Restore” feature from a previous Mede8er firmware version
2. Audio info and other info screens changed to larger info screen
3. Russian text Media Library1 for "Hard drive" changed to "Жесткий диск".
4. Improved navigation (smoother) on folders with images inside
5. Fixed: "Pin Protection “"on"" setup Menu -- then go to ""Home Page ""
- select “"File Manager""
- enter “"File Manager""
- exit “"file manager"" with ""return key""
- press ""home key"" ---> mede8er asks you the PSW
6. Fixed: "Folder Protection" set to "on" -- Now must enter pin code to protect folder
7. Fixed: "Folder Protection" "on" Setup menu.
File manager copy to protected folder-- Now does not ask for a pin code when selecting a protected folder
8. Fixed: Music Player cut on some TV's -- Moved up 10 pix
9. Fixed: Cyclic only in one direction -- zOOM about.jpg and now can cycle down or up
10. Updated Internet Time GMT names
GMT + 12 New Zealand (Wellington dst)
GMT + 6 Bangladesh
GMT + 4 Dubai
GMT + 3 Kuwait
GMT +1 Netherlands
GMT -1 Cape Verde (Praia)
GMT -2 Brazil
GMT -3 Argentina (Buenos Aires)
GMT -4 Chile (Santiago dst)
GMT -5 New York
GMT -8 California
Known issues:
o 6 June 2010 - Very high bit rate 29fps BDISO (+- 40GB+) have stuttering and audio loss - Workaround --
to revert to V2.0.2 or extract your BDISO files to BDMV Folder structure with a program such as ISOBUSTER.
If you are using a program like AnyDVD we suggest you save as BDMV and not a ISO
o Under certain filter conditions, time bar artwork punching through SETUP screen -- Under investigation
Για όσους θέλουν να δουν το mede8er και τις δυνατότητες του live,το Σάββατο 18/06 τους περιμένουμε στο Mega συγκριτικό εδώ
Σε 7-8 εβδομάδες (περί τα τέλη Αυγούστου δηλ.) οι developers του mede8er θα έχουν το νέο sdk από την realtek που θα διορθώνει πολλά από τα bugs που υπάρχουν τώρα.Θα μας δώσουν τότε μια νέα beta για τεστ με πολλά νέα χαρακτηριστικά και βελτιώσεις.
Οπως υπόσχονται τουλάχιστον...
Αναμένουμε.
Re: Απάντηση: Mede8er - The Greatest Show on Earth
τελλικα τι εγινε δε τα καταφερε να βρει το δρομο για το συγκριτικο ?????? :137::137:
Οχι δεν το βάλαμε τελικά.Δοκιμάστηκαν μόνο media players που είχαν και επίγειο ψηφιακό δέκτη για τα κανάλια της digea.
Εγω παντως ακομα περιμενω το καινουριο GUI που μας ειχαν δειξει στις φωτο..Υπομονη..δεν μπορουμε να κανουμε και τιποτα αλλο..
Με το νέο firmware σε 6-8 εβδομάδες θα μπει
Απο χτες το med ειναι συνδεδεμενο στον ADA Suite 7.1HD και του κανω τεστ.
Παιζει πολυ καλα, επισης δινει ολα τα φορματ ηχου χωρις προβλημα.
Δεν εχω αρχεια με τα νεα HD φορματ για να δοκιμασω, αλλα καλα θα κανουν στο νεο SDK να τα βαλουν μεσα η επιτελους να βγαλουν αυτο το under development... αντε γιατι κοντευει χρονος.....:141:.
Τα πρωτα 1073/1283 της realtek ΔΕΝ θα δωσουν ποτε hd audio λογω κατασκευαστικου σφαλματος στο chipset (ασχετως κατασκευαστη)
Εχει δίκιο ο vadegr. Τα 1073DD+ & 1283DD+ της realtek διορθώνουν το πρόβλημα με το hd audio.
  • loggeo
simplygades
