Κεφαλή mc. Tελευταία επιθυμία?
Απάντηση: Κεφαλή mc. Tελευταία επιθυμία?
O.k.
Για πάρε πράμα:
1)JICO: http://www.export-japan.com/marketing/stylus/product_reviews_info.php?products_id=1124&reviews_id=17
2)LP GEAR: http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=STNS881S
3)ED SAUNDERS: http://cgi.ebay.com/NEW-ELLIPTICAL-...aultDomain_0&hash=item2c54c80d1e#ht_612wt_811
4)SOUNDRING: http://www.soundring.com.au/StyliInfo.cfm?StyliID=1773
5)LPTUNES: http://www.lptunes.com/Stylus-for-Stanton-881S-cartridge-p/stns881s.htm
6)STEREONEEDLES: http://www.stereoneedles.com/Pickering.html ORIGINAL ΣΕ PICKERING D 4000 (D 3000 H STEREOEDRON)
ΑΡΘΡΟ
y edmaidel
."..as I was Pickering's Sales manager during the period when the XSV-3000 was introduced, and then was the Vice President of Sales and Marketing for Stanton Magnetics in the 90's just prior to its sale to a new owner in Florida.
Over the years, when both Pickering and Stanton were selling thousands of phono cartridges to consumers (in the era pre-dating the CD), telling the difference between a Pickering product and a Stanton product was often much like comparing Tweedle Dee to Tweedle Dum. That is until the XSV-3000 was introduced, when the current top of the line Stanton product was the 681-EEE.
The Pickering all but blew away the 681EEE, and most of the Stanton sales people were furious that Pickering really and truly had an infinitely superior product. That is, until the 881-S was introduced. And you're right: it was exactly the same item, though with cosmetic variations and the fact that Stanton cartridges were calibrated, and Pickering's weren't. (Though this led to an industry-wide condemnation of Pickering products as being "Stanton rejects" since they weren't calibrated, they were every bit as good as their Stanton counterparts in each and every respect.)
With the advent of the CD, Pickering's and Stanton's sales all but disappeared until the enormous popularity of the Stanton DJ business (which started in Europe) began taking hold in the U.S.
I rejoined the company (Stanton) in 1992, and despite an attempt to resurrect the consumer audio interest in phono cartridges, quickly realized that the DJ business was that which would sustain the company. The top of the line consumer (not DJ) product then was the Stanton Collector's Series, which was not only calibrated, but included individually run frequency response curves and a signed letter from Walter Stanton thanking those purchasing the product. Despite all this hoopla, the Collector's Series was identical to the Pickering XSV-5000, and yes, both were superior to the XSV-3000, but only marginally.
The current 881S-II, though it states that it has a "Stereohedron" stylus, in fact does not. This is a dirty little secret that the company won't admit to, as they still purchase the diamond tips they use on the stylus assemblies, and the prohibitively high cost of a Stereohedron stylus, in respect to the very limited sales of the product, made the substitution of an ordinary elliptical stylus tip mandatory. (This was done before I left the company in 1999.) Quite frankly, it's pretty difficult to tell the difference in sound between the two, but for the company to still actively promote it as having a "Stereohedron" stylus is quite simply dishonest.
The brush assemblies on Pickering and Stanton cartridges differ, and that used on the Stanton models is actually a little better than that used on the Pickerings, since, if the Pickering assembly (which snaps onto the outside of the stylus handle) is not carefully installed, it will indeed interfere with tracking, whereas that used on the Stanton, with a vastly superior method of connecting the brush to the stylus handle, doesn't elicit this problem. And, you're right: you must add one gram additional stylus force to the tonearm setting (as well as the same extra gram on the anti-skate setting) to offset the brush assembly.
While at Pickering, I introduced a pamphlet to explain the benefits of the Pickering "Dustamatic" Brush assembly, and that same pamplet was reproduced for the Stanton "Longhair" brush assembly. The brush does an excellent job of damping low frequency resonance in a tonearm, and also greatly improves tracking of warped records. And I've NEVER been able to "hear" the brush assembly, and think those who claim they do are certifiably nuts.
Of course, I could go on and on and on. That's all for now. Unless of course you want to hear more (and, believe me, there's lots more!)"
Αυτά είναι για ΜΚ Ι αλλά με τις ανάλογες προσαρμογές θα βγει άκρη και για ΜΚ ΙΙ.
:107:
Κατακλυζζζμός! Όντως έχεις ρίξει πολύ πσάκσιμο, σ ευχαριστώ.
Βέβαια εγώ μίλαγα για το σελ της κεφαλής του πικαπίου MKII, δηλαδίς αν είναι να δοκιμάσω 3 κεφαλές στον ίδιο βραχίωνα, αντί για βίδωνε-ξεβίδωνε, κοτσάρεις την κάθε μια στο δικό της σελ κ μετά ...
Η κεφαλή αυτή (Denon DL-160) δένει τρομερά με το MK II.
Δεν έχει καμία σχέση ο ήχος με ότι είχες ακούσει μέχρι σήμερα και βέβαια ούτε κουβέντα για Stanton και τα σχετικά.
Κολλητός μου έχει τον ίδιο συνδυασμό και παραμιλούσε όταν το πρωτοάκουσε.
Το θέμα είναι να γίνει πολύ προσεκτική ρύθμιση στη γεωμετρία της. Παιδευόταν ο φίλος μου με τη ρύθμιση αρκετά και τελικά την έκανε με universal προτάκτορα και όχι με το χάρτινο κομματάκι που συνοδεύει το πλατό.
Απάντηση: Re: Κεφαλή mc. Tελευταία επιθυμία?
Ωραία!
Άρα να περιμένω μέχρι να μου το στήσει ο συμφορουμίτης φίλος που γνωρίζει κ έχει τον προτάκτορα που ρυθμίζει όλες τις παραμέτρους,
Σ ευχαριστώ για τις πληροφορίες!:107:
Αγόρασε ένα απο αυτά :
Να ρυμθίζεις σε χρόνο dt την κεφαλή σου !
Αν το πάρεις από την technics θα τα πάρεις περίπου στην αστρονομική τιμή των 2 € !
Δες περισσότερες πληροφορίες εδώ :
http://mixonline.com/mag/audio_gettin_grooves/
μπα σε καλό σου, πνίγηκα βραδιάτικα...:143::135::143::135:
Τόχουμε το παρενφενάλιον!
Μας ρυθμίζει τα πάντα όλα?
...και βέβαια ούτε κουβέντα για Stanton και τα σχετικά.
Φίλε geomiat, επειδή υπάρχουν αυτά τα specs:
* Διόρθωση (;) Την έξοδο της STANTON αλλού την βλέπω 4.5 mV.
Kαι αυτή η εκτίμηση ενός χρήστη:
"At 1k loading, the overall presentation of the DL 160 did open out, especially in the lower mids, while retaining the control, attack and crispness of the upper frequencies. I found that the leanness was more than satisfactorily addressed, providing a more rounded overall presentation, not quite as fulsome as say the Stanton 881s and certainly the Grado Z+, but a very nice overall balance. "
εδώ:
http://www.vinylengine.com/phpBB2/viewtopic.php?t=22623&postdays=0&postorder=asc&start=0
Aν έχεις την καλοσύνη, όταν και αν μπορέσεις, πες μας τις, (συγκριτικές), σου εντυπώσεις!
:107:
Αυτό το εξάρτημα εννοούσα παραπάνω λέγοντας πως δεν είναι η καλύτερη δυνατή ρύθμιση.
Θα πρέπει να το παιδέψεις με προτράκτορα.
Υπάρχουν κάποιες μοίρες που διαφοροποιούν το καλό αποτέλεσμα από το καλύτερο.
Ψάξε το και στο νετ για σχετικά.
http://www.needledoctor.com/Koetsu-Coralstone-Platinum-Phono-Cartridge?sc=2&category=376
Να δεις που η Stanton θα είναι καλύτερη και από αυτήν την Koetsu αφού και η Koetsu έχει διαχωρισμό καναλιών 25 db ενώ η Stanton 35.:140::140::140:
Αν ήταν να παίζουν οι κεφαλές μόνο από τις προδιαγραφές δεν θα χρειαζόταν να τις ακούσουμε καθόλου.
Kotsidis John
Photography
Τα phono θα μπορουν ομως να οδηγησουν την Denon ανετα?Γιατι ειναι αρκετα χαμηλοεξοδη.
1,6 mV βγάζει και την οδηγούν άνετα και οι mm προενισχυτές πικάπ.
Αυτά που γράφω είναι πράγματα που τα έχω δοκιμάσει στο σπίτι μου ή σε σπίτια φίλων και δεν γράφω για πράγματα που γράφονται από εδώ και από εκεί.
Geomiat ρίξτην επάνω στο shell και θα σου πέσει το σαγώνι στο πάτωμα.
Εννοείται οτι δεν εχει καμία σχέση με stanton κλπ.Αααααλλος ηχος.
Το πλαστικό του sl το μόνο που κάνει όπως είπε και ο πέτρος είναι μια χονδροειδής ρύθμιση.Χρειάζεται προτράκτορας για να φέρεις την παραλληλία των δυο σημείων.
Πάντως η κεφαλή παίζει άψογα.
Συγνώμη αλλά 2,2 mv λένε παντού. Η DENON για κάποιο λόγο δίνει χαμηλότερη τιμή από την πραγματική. Αυτό φυσικά είναι υπέρ της κεφαλής γιατί έτσι έχει καλύτερο S/N.
:107:
Re: Απάντηση: Κεφαλή mc. Tελευταία επιθυμία?
Μπορεί να είναι έτσι ρε παιδιά αφού το εργαλείο είναι της ΜΑΜΑΣ technics ????
Γιατί η MAMA δεν το πρόβλεψε να φτιάξει το εργαλείο με την "Σωστή" όπως λέτε ευθυγράμμιση ??
Και αφού χρειάζεται ρύθμιση με τον προτράκτορα , με ΠΟΙΟΝ απο όλους ????
Που να είναι τα Null σημεία ??
http://www.vinylengine.com/cartridge-alignment-protractors.shtml
Υπάρχουν οι λεγόμενοι <<universal>> προτράκτορες που κάνουν για όλους τους βραχίονες αλλά απαιτούν μεγαλύτερη εμπειρία στη χρήση τους.
Re: Απάντηση: Re: Κεφαλή mc. Tελευταία επιθυμία?
:107:
Υπάρχει S/N σε μια κεφαλή?
Από πότε?
Και αν υποθέσουμε πως έχει που κολλάει η έξοδος της με αυτό?
τα γνωρίζω αυτά απο το Link που έδωσα !
Απλά αφού το εργαλείο της Technics λέμε ότι είναι λάθος , ποιος προτράκτορας είναι ο σωστός για το sl-1200mk2 ????
Από εδώ
http://www.vinylengine.com/cartridge...tractors.shtml
ποιός είναι ο καλύτερος ???
Απάντηση: Re: Απάντηση: Re: Κεφαλή mc. Tελευταία επιθυμία?
Από πότε?
Φυσικά το phono stage έχει S/N!
To στοιχείο για την έξοδο φίλε Πέτρο, θα το βρεις με λίγο Googling να αναφέρεται παντού όπως εδώ:
"Jerry Raskin also, (η υπογράμμιση δική μου), measures 2.2mV output in the DL160, quite a bit more than the 1.6mV claimed by Denon."
Aπό εδώ:
http://www.high-endaudio.com/RC-Denon.html
:107:
bmavroeidis
