Nέοι Marantz(hdmi v1.4)
Απάντηση: νεος marantz
και τελικοιThe AV7005 is the new flagship preamplifier from Marantz, and deservedly so. It's got six HDMI 1.4 inputs that support 3D and an audio return channel as well as a pair of similarly capable outputs. The 7005 handles HD audio of all kinds and includes support for Dolby ProLogic IIz.
It's packed with Audyssey features like DSX room EQ processing and MultiEQ XT. It's capable of streaming from your home network or from a range of internet radio sources and will run you $1,499 when it launches in October. The MM7055 and MM7025 are new amplifiers from Marantz that sport the same great look that you're used to from Marantz products. Both amplifiers were designed with full compatibility in mind, but the 7055 is built specifically to work with the AV7005 preamp.
It's got a discrete current feedback amplifier that pumps out 140 watts to each of its five channels. Hooking it up via XLR to the AV7005 means 140 watts to five channels at eight ohms. If you're looking for seven channels of amplification, or just a little more power, you can add on the MM7025 – a two channel power amplifier. Both the MM7025 ($799) and MM7055 ($1,199) are slated for a September release
Re: νεος marantz
Δεν νομίζω ότι έχω δει ομορφότερο ενισχυτή AV:111:
Με τιμή $1600 στην άλλη πλευρά του Ατλαντικού και 1400 λίρες στην Αγγλία, πόσο άραγε θα φτάσει να έχει εδώ? Μακάρι να έχει γύρω στα 1700 ευρώ (με την αντιστοιχία ευρώ-λίρας). Θα άλλαζα τον Onkyo 806 ευχαρίστως!!
Το όργανο στη μέση τι ακριβώς δείχνει?
Στον τελικό εννοώ.
[YOUTUBE]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/-3dLNTrWbFw&amp;hl=el_GR&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-3dLNTrWbFw&amp;hl=el_GR&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>[/YOUTUBE]
νασου και η κομψη γραμμη της μαραντζ
We all want the best when it comes to our home theater components, but sometimes practicality gets in the way. Maybe you've got an AV rack in your main viewing room, but when it comes to more limited spaces, smaller components can really help out.
The NR1601 from Marantz is the latest in the slimline… line. It's just over four inches high and 13 inches deep making it half the size of a typical AVR, and the exact same size as a Marantz Blu-ray player. That kind of space economy can really pay off if you're hurting for room.
It's not the most feature packed receiver on the market. The 1601 sports four HDMI 1.4 inputs and front panel USB connectivity. It handles Dolby TrueHD and DTS Master Audio as you might expect and it's got a nice audio tool in Audyssey's Audio Calbration. You can pick up the NR1601 later this month for
λινκ
http://www.avrev.com/home-theater-n...601-is-the-new-marantz-slimline-receiver.html
SR7005 < < COMING SOON ! ! > > HDMI ver.1.4a & Network AV Receiver
$1599.99
Newly designed clean front panel with a porthole 2nd display
marantz quality discrete 125 watts Amp x 7ch (8 ohms, 20Hz-20kHz)
Current Feedback topology featuring marantz HDAM circuits for Pre-amplifier
Support HDMI ver.1.4a 3D, ARC and Content type, 6 Inputs(Front 1), 2 Outputs
Support HDMI CEC, Deep Color, x.v.Color, Auto Lip Sync and Standby Pass Through (Last or selected one in menu)
Front USB input for iPod/iPhone Digital connection (Audio) or USB Memory (Audio/Photo)
Ethernet port for Audio/Photo streaming (Support DLNA1.5, Windows 7)
Internet Radio through vTuner UI
Streaming service capability: Rhapsody/Napster/Pandora/flickr
Dolby TrueHD, Digital Plus, Prologic IIz, IIx, II, Virtual Speaker, Headphone
dts-HD Master Audio, High Resolution Audio, ES Discete6.1, Matrix6.1, Neo:6, 96/24, Express, Neural Surround
Audyssey DSX, Dynamic Volume and Dynamic EQ
Audyssey MultEQ XT Auto Calibration
Audyssey MultEQ Pro for Custom Installation
Bluetooth Wireless Audio Transmission Capability with option RX101
Composite/Component to HDMI scaling up to 1080p
HDMI to HDMI scaling
Composite to Component Analog up conversion
OSD overlay on HDMI output
Assignable HDMI, Component inputs
Anchor Bay 10-bit Video Processing/Scaling
M-DAX 2 (Improved Algorithm, Marantz Dynamic Audio eXpander ver.2)
New color GUI On Screen Display
Dot Matrix x2 lines rich info. display in the front door
Input Rename, Skip, Level control
Selectable various volume setup: Power on, Limit and Mute level
8 x7 groups, total 56 Tuner Preset
HD Radio
Sirius ready
Phono (MM) input
11 pair screw type speaker terminals
Zone2 Audio Pre outputs, Component/Composite Video output
Zone3 Audio Pre outputs
7.1ch Pre out + 2nd Subwoofer Pre out
I/P Control
RS-232C for Custom Installation
Flasher In
DC Trigger Out x2
marantz D-Bus(RC-5) In/Out
External IR Receiver Capability with option RX101
Detachable Power Code (IEC320 2pin type)
Backlight, LCD, Learning and Precode System Remote Controller
Available Option Rack Mount Kit RMK8003AV
πηγη
http://us.marantz.com/Products/3230.asp#
Ναι αυτός είναι ολοκληρωμένος , τον προ που τον είδες?
DJCHRISTIANO13
