Verity Audio Monsalvat
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
System description:
Monsalvat complex system consisting of two main buildings . The system includes two separate bass case and a unique crossover. Active crossover must be installed between your preamp and amplifier. The system includes six separate channels of amplification. Our study showed that strengthening the system of columns, the best results are achieved when the entire system increases one unit , so bass unit Monsalvat has no built-in amplifier . The user can select the type and number of amplifiers.
・Housing system:
Shells are composed of two different modules : the medium - high-frequency module and a
bass module. These two sections together to create a column height of approximately as
Lohengrin II. At the same time , the depth of columns exceeds the size of Lohengrin II and to
the rear , they are dwindling. Thus improved performance surround sound . For the stability of
the column are fixed on solid aluminum base with the possibility of adjustments .
・Medium and high frequencies :
In this unit consists of two dynamics: tweeter and midrange speaker . Twitter production
Verity with a range of 6-60 kHz , mid range is based on the dynamics of Sarastro II. The
difference in sensitivity : Sarastro II has a rate of 93 dB 1w/1m, Monsalvat has a sensitivity of
99 dB 1w/1m, made possible by hard work .
・Bass / midrange drivers :
Speakers for midvufera frequencies identical Lohengrin II. Their overall sensitivity equals
average sensitivity of the speakers at high frequencies. Range of 60-500 Hz. Modules are very
powerful , their combined use provides a very powerful sound with minimal distortion and
displacements.
Tower woofers ( bass part ):
Each of the towers vufernyh Monsalvat vufernymi with 4 modules . Each of them is equipped
with a 15 inch speaker , identical Lohengrin II. These modules are designed for installation in
front of the room , the sound is spread throughout space . So they can be positioned
horizontally in front of the angle of the wall and floor. Modules are very powerful , their
combined use provides a very powerful sound with minimal distortion. These modules cover a
range of 15-60 Hz.
・Active crossover:
Experience with digital crossovers shown us that this type of device is not transparent sound .
That's why we Monsalvat ispolschuem exclusively analog filters . At the same time, we have developed high-precision digital delay circuit for the entire system, effectively and accurately a harmonizing sound. The system uses the delay AD and DA converters , as well as the repository of memory. As a result , we have an active crossover system with a completely transparent sound.
http://www.my-hiend.com/vbb/showthread.php?t=2611
Απάντηση: Verity Audio Monsalvat
όλα ωραία, όλα καλά όλα ανθηρά, ενεργό κρος, πολυενίσχυση με 6 συνολικά ενισχυτικές βαθμίδες, σούπερ ντούπερ, μέχρι που διάβασα και την εξής "κοτσάνα":
βρε άϊντ' απ'έδώ ...
πείτε τα αυτά σε καμιά μερίντιαν ή σε τζένελεκ, κλάιν-μάιν κ τα συναφή, να δω αν σας παίρνει εκεί να αμολάτε τέτχιες πατάτες...
Σίγουρο...Monhalvat η ΄΄βεριτάμπλ΄΄ μπροσούρα:142:
Re: Απάντηση: Verity Audio Monsalvat
έ ίσως ακούν βινύλιο γι αυτό....:137::136:
Ποιο είναι το μπροστά και ποιο το πλάι;
themiloc
Κάτι από αυτά υπάρχει εδώ:
http://www.minidsp.com/?gclid=CNS0qJuUpaMCFdQB4wodHSTN3Q
Θα ήμουν κι εγώ σκεπτικός για το ψηφιακό κροσσόβερ.
Όταν έχεις δει τι χάνεις ακόμη και από την καλή ψηφιακή επεξεργασία σήματος κρατάς μικρό καλάθι, όσον αφορά πως ξεκινούν οι χροιές και που καταλήγουν. Και αυτά με επεξεργασία
σε σήματα τουλάχιστον 24/88. Θέλει προσοχή στην υλοποίηση των DSP γενικά.
Απάντηση: Re: Verity Audio Monsalvat
ναι, σαφώς.
αν δεν απατώμαι η weiss έχει ένα ψηφιακό κρος, μάλιστα δεν υλοποιείται με φιρ φίλτρα, για αρκετούς λόγους.
πόσο κάνει άραγες?:126:
Kotsidis John
Photography
κοτσίδη τα δικά σου τι είναι ρε? τα τουήτερ?
χαχαχαχαχαχ
Bρε αιιιιντε τωρα....
Ειναι μικρα στο ματι , αλλα... μεγαλα στο....
Που θα πει ρε , δε θ αλλαξω σπιτι...θα δειτε εσεις ρε παλιοπαιδα....:137::137::137:
Απάντηση: Re: Απάντηση: Verity Audio Monsalvat
άμα αλλάξεις σπίτι άλλαξε και τους καναπέδες....
themiloc
Re: Απάντηση: Re: Verity Audio Monsalvat
ναι, σαφώς.
Διαλέγεις και παίρνεις χρήση.
http://www.weiss.ch/powerhouse/powerhouse.html
akoustiklab
