Stewart CEDIA 2010
STEWART FILMSCREEN INTRODUCES NEW DESIGNER-FRIENDLY GALLERY WALL SCREEN SERIES
- Screen frame’s elegant, sculpted shape has the visual appeal of a fine-art presentation
- Can be customized to match any room’s décor in multiple materials, finishes and colors
- New wall-mount system makes precise installation simple and quick
STEWART FILMSCREEN INTRODUCES DAILY DUAL SCREEN SYSTEM, ENABLING SEAMLESS SWITCHING FROM 2D TO 3D VIEWING
- Single package gives the operator a choice of two screen surfaces, including Silver 3D
- One screen is fixed and the second is on an electronically controlled retractable screen
- Allows for dual-purpose 2D and 3D functionality in the same space
- Multipurpose rooms can be optimized for viewing in both absolute light controlled conditions and higher ambient light situations
STEWART FILMSCREEN INTRODUCES NEW ACOUSTIMASK MASKING SYSTEM
- Stewart Filmscreen's new AcoustiMask masking products now transmit more sound, yet block more light with its deeper black design
- The AcoustiMask's round profile leading edges on the masking panels reduce parallel sonic reflections
STEWART FILMSCREEN INTRODUCES NEW COUTURE COLLECTION EMBELLISHED WITH SWAROVSKI ELEMENTS
- The first screen introduced within the Couture Collection will feature an elegant, sculpted fixed frame design, accented with SWAROVSKI ELEMENTS, the world’s finest loose cut crystals manufactured by Swarovski
- Available in a wide array of premier colors
Απάντηση: Stewart CEDIA 2010
φωτο δεν εχει μελαχροινο αγγορι ,
αντε μην σε δωσω στεγνα:143:
Re: Απάντηση: Stewart CEDIA 2010
φωτο και σχολια.....ο ειδικος...
τι να με δωσεις που με δωσαν αλλοι....:402:
dsisikis
