Το home cinema του Argi
ελα μου να σε φιαξω λιγο....
η φωτο δε βγαινει...παρε λινκ
Klipsch was showing off their new Reference II line. They have done a major update to the Tractix horns and titanium tweeters. They are also rolling out a new line of compact high-powered subs that have the capability to keep up with the output of their very sensitive towers. Their subs can be retrofitted for wireless operation with an upcoming add-on dongle that connects to the plate amp. The dongle gets its power from the amp so no wall wart is required in the vicinity of the sub. Klipsch had a live demo where they A/B their old and new Synegy towers. The increase in imaging and air was amazing with the new speakers.
Απο τη σπηλια....:126:
Απάντηση: Το home cinema του Argi.
παλκαρ εχω τις φωτο απο τις μοναδες, και τα νεα ανερχομενα σαμπ εδω και κανα 2μηνο.Υπομονη κανα μηνα σκαρτο..........
Το SW-311 θα έχει εντεκάιντσα ή δεκάιντσα σαν το SW-310;
Εδώ το παρουσιάζει σαν 10ιντσο:
All new Klipsch flagship subwoofer•10” Active/Dual 10” Passive non-resonantWoven Fiberglass drivers•Upgraded, increased efficiency BASH® Amplifier with DSPcontrolled 500 watts FTC continuous/1200 wattsdynamic power•Similar specs to the two RT models it replaces in a muchsmaller footprint/more aesthetic design•Large 4-layer Aluminum-Wound voice coil for high output•New, patented ARC II room correction program with12 active filters•New universal power input with 1-watt standby mode•DCS electronic controls•USB input for upgrading, viewing ARC II roommeasurements, viewing/editing correction filters•Line output for multiple system subs•Input for future wireless capabilityBandwidth: 22Hz to 120HzSensitivity: 106db @ 40HzMax output: 118dB @ 30Hz500 – 1200 wenclosure: Bass Reflexsize: 13” x 13” x 14”
Σε δικό μου mail αναφέρονται τα:
SW-311 10''
SW-310 10''
SW-308 8''
SW-112 12'' μονό
SW-110 10'' μονό
Εσύ σε ποια μοντέλα αναφέρεσαι;
ων , δεν εχουν ακομα ανακοινωθει,μεσα στην επομενη θα ξερουμε
Re: Απάντηση: Το home cinema του Argi.
Εγώ έχω ήδη τα μοντέλα και τιμές.
Το 12άρι πού το είδες;
δωστε μου 20-5 μερες καιρο μετα υποσχομαι ηχητικο αποτελεσμα που μαλλον δεν εχετε ακουσει.Κουραγιο μεχρι τοτε:126:
μετα απο καμποσες μερες αναμονης , τα 2 σαμπακια φτανουν αυριο.Μενει το κεντρικο και φυγαμε για ντισκο
ευχαριστω, :126:
ευτυχως δεν εσπασα το ρεκορ του ερθ , 4 μηνες αναμονης .
θα ακολουθησει νεο φωτοσοπ.....και λαιβ καταστασεις..........
αντε ναρθει και αυτο να κανουμε καμμια δουλιιτσα:126:
καλη ερωτηση
μαλλον θα ειναι το πρωτο στην ευρωπη.Κανα 10 μερο το πολυ.Με λιγη τυχη:144:
agnooumenos
