Mede8er - The Greatest Show on Earth
Απάντηση: Mede8er - The Greatest Show on Earth
Firmware V4.0 public beta 4 για όλους:
V4.Beta4 is available for download:
The downloader accepts that they are downloading and installing firmware with noted bugs -
the firmware is stable but not complete for final release.
Please only constructive feedback on this beta release, no moaning etc... as this is a beta
Mede8er_V4Beta4_2_October2010
http://www.mede8er.org/public_beta/Mede8er_V4Beta4_2_October2010.rar
http://www.mede8er.org/public_beta/Mede8er_V4Beta4_2_October2010.zip
0017L_bootloader_patch.rar XXXXX UPDATED XXXXXX
http://www.mede8er.org/public_beta/0017L_bootloader_patch.rar
http://www.mede8er.org/public_beta/0017L_bootloader_patch.zip
XXXXXXXXXXXX VERY IMPORTANT -- INSTRUCTIONS PLEASE READ XXXXXXXXXXXXXXXXXXXXX
1) Check your Mede8er Bootloader Version in the Setup Menu.
If you have 17L go to point 2.
If you have 23 go to point 3
2) Instructions for updating from Bootloader 17L XXXXX UPDATED XXXXXX
a) Download 0017L_bootloader_patch.rar AND Mede8er_V4Beta4_2_October2010.rar (OR zip equivalents)
b) Unrar/unzip the file 0017L_bootloader_patch.rar or 0017L_bootloader_patch.zip and you will find 2 files inside.
install.img and install.dat
c) Copy these files to the root of a USB drive
d) Install via Emergency Procedure.
--- On the first stage you will see the patch install on the screen
--- then the Mede8er will reboot
--- Next you will see BETA2 install on screen and a yellow box after half of progression bar stating it has to reboot
--- then another reboot
--- then again it starts to install BETA2 and finishes with install complete and reboots
THE PROCESS IS NOT COMPLETE SO PLEASE CARRY ON
e) Delete the two files install.dat / install.img on the USB stick
f) Unrar/Unzip the file Mede8er_V4Beta4_2_October2010 and copy the install.img to the root of the USB stick.
g) Update the Mede8er in the normal way via Emergency procedure
3) Instructions for updating from Bootloader 23
a) Download the file Mede8er_V4Beta4_2_October2010
b) Unrar / Unzip
b) Install in the normal way via emergency procedure
4) If you do not have you own Cover Art download the Demo
http://www.mede8er.org/beta_2010/Mede8er_Video_Wall_demo_images.rar
5) xxxxxPLEASE READ -- THIS IS VERY IMPORTANTxxxxxxx You will find Video Wall instructions VIDEO_WALL_INSTRUCTIONS_V4BETA4.pdf inside the rar/zip files
http://www.mede8er.org/public_beta/VIDEO_WALL_INSTRUCTIONS_V4BETA4.pdf
6) The custom Mede8er Web Remote has not been included as yet but you can test the default Web Remote as foll
Type the following in your browsers adress bar and change the your-mede8er-ip to the Mede8er actuall IP
http://your-mede8er-ip:1024/
Highlights of V4
• Support Dolby True HD and DTS MA passthrough - DD+ hardware
• New “Video Wall” with mapped share functionality
• New GUI
• Improved network streaming performance (both Samba & NFS / DD+ and DD hardware)
• Improved and fixed SAMBA NTFS write (NAS Mode)
• Shoutcast Radio API implementation
• New SDK and general improvement and bug fix
• Picture Thumbnail Viewer
• Improved upsampled picture quality SD content
• Added Thai Language support
• Added Icelandic Language support
Overview of known bugs on V4 Beta based on latest Beta Version: Current version V4BETA4
1] No PCM audio on on SPDIF /Co-Ax Digital
2] On older hardware LCD led on front only changes from Red to Blue after about 5sec after switching Mede8er on from Standby (Fixed with BETA4)
3] creation of the movie, image and music folder after updating firmware or entering movie wall. This should be disabled
4] 5 sec delay before an audio file starts to play (Music Player)
5] If you use Vol Up/Down during Music Play the Player does not come back
6] .divx and bdiso not playing from movie wall
7] when in media library and press menu when focussed on a folder, then select delete. Confirm window has some layer behind that should not be there Fixed in Beta4.
8] Zoom image press info 2x and when in second info screen with picture details on the screen, return button is not working. You have to press again info button and then you are able to use Return button.
9] Dolby True HD does not always work on 1080p 60HZ when source is on USB drive or network. Need to change setting to 50hz. ------------ Awaiting audio patch file from Realtek.
10] BDMV files do not play as folder over NFS
11] when network is instable (simulate by unplugging cable) when in VideoWall browsing movie icons, mede8er hang and finally will bomb. This is not happening when doing the same in NFS network share on Video Wall
12] desired: feature to be able to put HDMI sound and SPDIF sound to off. Now both are on always. A user should be able to choose. All on or only one on.
13] WiFi field strength bar out of alignment
14] Zoom picture from thumbnail view - screensaver does not work
15] resume not working on mkv when 24fps is set to ON
16] italic tag (<i>) inside SRT/SMI/SSA not working. e.g. Giving <i>I amar prestar aen.</i> In stead of Italic without the codes around.
17] browsing about.jpg in zoomed mode with a file structure with 10 or more VIDEO_TS structure folders: Mede8er looses track and starts wrong movie or gives error when you try to start a movie.
18) Fixed Screen Size Calibration issue -- if it was set at max mede8er would show image artefacts and bom with "slow" zoom nav up/down (Fixed with BETA4)
19] When adding an usb device in standby mode or hot-plug while running, USB device not seen over samba link from PC. Need to toggle NAS from ON to OFF to ON to get it visable over samba connection. When doing cold boot (starting from power off mode) with usb device attached, it is immediately visable over samba link.
20] Not able to change genre icons on page 2 and up on moviewall.(Bug introduced in BETA4)
21] Subtitles gone after FF (fixed with BETA2 27 sep 2010)
22] Skip on series in MovieWall not working. Index goes up but keeps playing first movie in series that is started. (fixed in BETA3)
23] Hebrew Subtitles issue (Fixed in BETA3]
24] subtitles play by default on video_ts folders and mkv, even though subtitles are off in settings
25] Some movies when started from video wall only have sound for a few seconds. Pausing and re-starting makes no difference but skipping forward 1 chapter and back again gives sound ok. These are full dvd rip to iso - nothing removed from original. All work ok from media library. [logged by Shamus]
26] On mede8er start up my tv gives "unsupported audio format" message - happens no matter what audio setting I use. Connected to tv by hdmi [logged by Shamus] TV is a TV Sony Bravia KLV40V550A connected HDMI
27] TV series drop down in video wall gives wrong order - eg series 1, series 2,... series10, series 11 show as series 1, series10, series 11, series 2,.... [logged by Shamus]
Note: not really a bug. You need to use naming convention 01, 02,03 etc.
28] PPPoE bug reported many times before i.e. using PPPoE causes lan ip address to change when mede8er starts and lose lan connection. [logged by Shamus]
29] When watching a MKV file with Subtitles, disable them via the remote and they stay away until pause and unpause the movie then the subtitles come back. Might be related to bug [24] (logged by Ricardo)
30] IN VIDEO WALL: while playing video, pressing INFO button will display movie info (filename, duration, codec etc), but I noticed that USB logo is displayed (top left corner) even media is on internal HDD ... This issue is not there when playing from normal File View.(logged by MarioB)
31] when playing mp3s screen saver flickers badly in some cases. The logo is ok it is the track name and artist details that flicker. (logged by Shamus)
32] *.MP2 file format does not display (logged by Insomniac)
33] After changing volume - need to press INFO twice to get audio player back (logged by Insomniac
With special thanks to Hansen and Frank and all the other developers in the team. Also a huge thanks to Insomniac, Maasbommel, Andy and Getsko and the Mede8er Beta Testers for all the late nights and very valuable input and relentless testing.
Τι έγινε κανένας δεν πέρασε το νέο firmware?
Μη το φοβάστε επειδή είναι beta!
Περιμενω να το περασει καποιος αλλος πρωτα, εγω θα ειμαι το πειραματοζωο?
Εσυ Λεο σιγουρα το περασες, γραψε 2-3 λογια. Η την πατησες και θελεις να εχεις παρεα? :142:
Ειναι πολλα τα bugs Αρη....:137:
Δε καγομαστε κιολας, αστους να τα φιαξουν και εχει ο Θεος...
Απάντηση: Re: Απάντηση: Mede8er - The Greatest Show on Earth
κοκκινο φωτακι = on & μπλε φωτακι = on
δλδ ανάβουν και τα δυο μαζί και φαίνεται σαν μωβ το λαμπακι και δεν κλείνει ο εσωτερικός δίσκος
Μετά από ψάξιμο για το παραπάνω πρόβλημα βρήκα ότι ο δίσκος δεν κλείνει (ενώ κλείνουν όλες οι άλλες λειτουργίες του mede8er) όταν το έχω συνδεμένο με καλώδιο HDMI to DVI (είτε σε PC monitor είτε σε προβολέα) ακόμα και αν η συσκευή προβολής είναι κλειστή (ακόμα και χωρίς ρεύμα)
Μόλις αποσυνδέσω το HDMI από το mede8er ή το DVI από την οθόνη, τότε το mede8er κλείνει κανονικά - κόκκινο λαμπάκι - και σταματά να τροφοδοτεί τον δίσκο.
Θα παρακαλούσα αν κάποιος έχει ένα HDMI-DVI καλώδιο και συσκευή να δοκιμάσει να μου πει τι γίνεται.
edit: όταν είναι συνδεμένο με HDMI-HDMI δεν υπάρχει κανένα πρόβλημα
Εγω δινω απο το Mede8er σε οθονη μονιτορ με καλωδιο Hdmi ανταπτορας και dvi. Ολα ομως δουλευουν κανονικα. Πες μου αν θελεις να κανω καποια δοκιμη.
Για δοκιμάστε βρε παιδιά να δω αν φταίει τελικά το καλώδιο γιατί θα σκάσω :121:
Φίλε Vastsar τι ρυθμίσεις έχεις βάλει στο σχετικό setup?
Αν είναι στείλε πμ να μην ενοχλούμε το topic με άσχετα,
ευχαριστώ!
Εγώ το πέρασα,έχει αρκετά bugs αλλά έχω μάθει να ζω με αυτά.
Πάντως και να το βάλει κάποιος και να μην του κάνει μπορεί πολύ εύκολα να γυρίσει στο παλιό.
Περίπου τέλος του μήνα θα βγεί το stable firmware.
Υπομονή!
Κωστα,
Μολις το δοκιμασα.
Το καλωδιο, ενα απλο DVI-D σε HDMI απο oppo 971.
Δουλεψε και στο προβολεα και στo μονιτορακι.
Το φωτακι γινεται κοκκινο και ο δισκος κλεινει.
Απάντηση: Re: Mede8er - The Greatest Show on Earth
Κωστα,
Μολις το δοκιμασα.
ευχαριστώ Απόστολε
Άρα φταίει το καλώδιο μου :121:
Αν είσαι το Σαββατο εκεί μπορεί να περάσω για μια δοκιμή, καφέ κερνάω εγώ :114:
Re: Απάντηση: Re: Mede8er - The Greatest Show on Earth
ευχαριστώ Απόστολε
Αμα θες, να σου στειλω το καλωδιο να το δοκιμασεις.
Παρε τηλ.....
Δοκιμασα και γω το καινουργιο αλλα το εβγαλα κατευθειαν..το video wall παντως εχει πλακα..Αυτο που περιμενω δεν βλεπω να γινεται ποτε και εξηγω..Οταν βαζω να ακουσω ενα αλμπουμ θελω να βλεπω το εξωφυλλο και η μπαρα να προχωραει στο καθε κομματι που παιζει..Μαλλον ονειρο θερινης νυκτος θα μεινει..Αναμενουμε..
Δεν σε καταλαβαινω, γιατι δεν βλεπεις το εξωφυλο? Μηπως στο κατεβασμενο αρχειο δεν το εχεις αποθηκευμενο μεσα στον φακελο που εχεις το συγκεκριμενο αλμπουμ?
Ετσι που τα γραφω ουτε εγω τα καταλαβαινω:105:Το εξωφυλο το εχω μεσα στο φακελο αλλα για να το δειχνει την ωρα που παιζει μουσικη πρεπει η μπαρα να ειναι πανω στη φοτο του..εγω θελω η μπαρα να ειναι στο αναλογο κομματι που παιζει εκεινη τη στιγμη και διπλα στο τετραγωνακι να μην δειχνει τα στοιχεια του κομματιου αλλα το εξωφυλλο..Λες να γινεται και να μην το χω παρει πρεφα?Δεν νομιζω ομως.....στο post97 σελιδα 10 ειχε ανεβασει ο αποστολης φωτο απο το firm που θα εβγαινε..εκει δειχνει οτι ειναι στο all η μπαρα στο κομματι 2 και φαινεται το εξωφυλο..αυτο να καναν μια χαρα θα μουνα..δειχνει και το bitrate που μετα το βγαλανε..
Review στο aνforums:
Conclusion
The Mede8er is a fantastic machine that does everything it is supposed to do with an excellent user interface and a minimum of fuss. It may lack the bells and whistles of some of the more expensive machines on the market but, if you are on the lookout for a machine that will sit in the corner of your room and play virtually every file you could ever throw at it, then the Mede8er is a winner.
The build quality is solid, the range of connections is superb, and the fact that you can install an internal hard drive really adds to the package. It should also be mentioned that the support for the product is excellent. In an area where many companies are continuously rushing to push products to market before perfecting the previous model – the level of support provided via the Mede8er forums has been like a breath of fresh air. Continuous, robust firmware revisions and upgrades have been regular adding functionality to the device.
There are always going to be those who are going to demand more - power users if you like. They are going to bemoan the lack of widgets, the inability to torrent from the device, and the inability to use full YAMJ. These users are probably going to turn their nose up at the Mede8er. Whilst they are entitled to their opinion, they are probably missing the point. To me, the success of this product is that it brings media streaming into the home, at an affordable price and with a stability that is probably unmatched in the sector. You don’t want to be rebooting your machine every five minutes. You want to know that you can turn it on and it will play what you want it to play.
It would be lovely if the player could do more for those who want to use it to play music and pictures, but this is something that is a common complaint within the market. As it stands, for the price point that the Mede8er retails at, this is an awesome machine that appears to have no drawbacks whatsoever.
http://www.avforums.com/review/Mede8er-MED500X-Media-streamer-Review.html
Kαλησπερα σε ολους.
Αγορασα κι εγω πριν απο λιγες μερες το εν λογο player και ομολογο οτι ειναι αρκετα γρηγορο με ομορφο menu και πραγματικα πολυ καλη εικονα.
Αλλα.......μαλλον πρεπει να αντιμετωπιζει καποιο θεμα με τα 24p διοτι καθε φορα και καθε αρχειο μικρο η μεγαλο μετα απο καθε περιπου 30 δευτερολεπτα κανει ενα μικρο σπασιμο σαν να μην σηκωνει ο επεξεργαστης το βαρος του αρχειου bitrate.
Να επισημανω οτι το εχω βαλει να αναπαραγει απο 720p μεχρι και bdiso και σε ολα τα αρχεια κανει το ιδιο.
Το εχω με 500αρι wd σκληρο εσωτερικο,το προβλημα υπαρχει και με τον εσωτερικο και μετον εξωτερικο.
Το firmware ειναι το 3.0.4. και η τηλεοραση η philips 47pfl9664 η οποια δεν αντιμετωπιζει κανενα θεμα με τα 24p,και αυτο το ξερω διοτι εχω το bdp320 pioneer και προηγουμενως σαν player to wd live....
Στις ρυθμίσεις video βάλε hdmi Auto
Καλησπερα.
Το εχω κανει κι αυτο και επισης εχω το 24hz sto auto αλλα παλι τα ιδια.......
Το perfect natural motion της philips ειναι κλειστο αλλα και ανοιχτο παλι τα ιδια κανει και εγω πλεον δεν ξερω τι να κανω......
Σε μένα δε μου το κάνει αυτό πάντως.Κι εγώ στο auto τα έχω και τα 2.Τέτοια σπασίματα σε μερικά sd .avi μου τα κάνει,σε πολύ λίγα όμως μου το έχει παρουσιασεί.Σε ματρόσκες 720p & 1080p ποτέ δεν μου έχει βγάλει πρόβλημα με σπασίματα.
  • loggeo
simplygades
