DENON DN-X600 - mixer
xfader
Νέο δικάναλο ψηφιακό mixer από την Denon με ενσωματωμένη κάρτα ήχου (24-bit 96kHz USB 2.0). Σχεδιασμένο για να καλύπτει τις απαιτήσεις όλων των DJs , είτε χρησιμοποιούν "κλασικό" hardware, είτε δουλεύουν μέσω software και controllers.
[RELIOPS="Τεχνικά Χαρακτηριστικά"]• 24 bit 96kHz USB2.0 Audio Interface (Soundcard) 4in/4out (stereo)
• DVS direct mode (CD/Vinyl) for DJ applications using platter control signal operation (timecode)
• Fully MIDI Mappable control surface (knobs, keys and buttons)
• Intuitive On-board DSP Effects area with, ON/OFF button, Dry-Wet mix & independent Send assignment
(Ch/Mic/Master):
Delay
Echo
Flanger
Filter
Reverb
Loop
Beat Scratch
BeatBreaker
• Powerful 2-way EFX Parameter Filter:
1) Cross Over (comb filter)
2) Isolator (Low pass filter/ High pass filter)
• Internal 32-bit Floating DSP Processing and 32-Bit DAC Output for best possible sound
• MAC OSX 10.6.4 and 32/64-bit Windows Compatible
• Low latency 32/64 Bit ASIO driver for PC included
• Send/Return control -for use with external effectors
• USB Send/Return routing -for use with DJ software DSP effects such as Traktor
• USB MIDI Clock In BPM Detection -for use with, Traktor, Torq, Ableton, Cubase...etc
• Matrix Input Assignment Selector Knob
• Selectable PFL input gain & program meters
• Split Cue function with Cue/Master pan knob
• Phono Amp with high S/N ratio, equivalent to Denon Hifi products
• Ultra clean Mic Amp to realize a studio console class’ low noise level (EIN -126dBu)
• High sound quality high output Headphone Amplifier
• 45mm High Performance Flex Fader (cross fader) w/tension adjust
• Innofader Pro compatible (for cross fader) *see Audio Innovate for more info
• 45mm custom Alps type Channel Faders
• Channel Fader contour adjustment
• Unique 32-point Cross Fader Contour adjustment with:
Contour Adjust
Cross Fader Start Position off the edge (0~2mm range)
"Thru" function for pure MIDI to control Video fades (VDJ, VSL)
• Fader Start function (channel/cross fader)
• Independent 3-Band Isolator EQ w/Kills (High-Mid-Low)
• Large BPM Display w/various beat/time parameter indicators
• Balanced/Unbalanced Master Output
• Master Output Stereo/Mono switch
• Booth Output w/level control
• Mic Input w/Ducking control & 2-Band EQ
• Various Utility presets to customize user settings
• Ideal Grounding Construction protecting from external noise
• ECO stanby mode (green, energy saving)
• Firmware upgradablle over USB
• Solid Steel chassis construction
• Size 9.8(w) x 3.5(h) 12.4(d) inches
250(w) x 90(h) x 315(d) mm
• Weight 8.8lbs unit / 11.7lbs in carton
4.0kg unit / 5.3kg in carton
[/RELIOPS]
Επίσημο site
ΤΙΜΗ : 659 €
[YOUTUBE]m-PqfXb8wMI[/YOUTUBE]
xfader
Απάντηση: DENON DN-X600 - mixer
Πως να παίζει άραγε ως USB-DAC/Προενισχυτής; :616:
Πάντως η ίδια η Denon είναι πολύ θετική σύμφωνα με την περιγραφή της:
The DN-X600 features a 24-bit 96kHz USB 2.0 Audio Interface (sound card) with 4 in / 4 out (stereo) channels. Internal 32-bit Floating DSP Processing and 32-bit DAC Output ensure the best possible sound. The unit can operate with DVS direct mode for DJ applications using platter control signal operation. Aside from the processing and output, the sound is further bolstered by the unit’s Phono Amp with a high signal-to-noise ratio, equivalent to that of critically acclaimed Denon HiFi products; an ultra-clean mic amp, which can realize a studio console classic low noise level (EIN -126dBu); and high-output headphone amplifier.
Παντως (για να γκρινιαξω και λιγο :105: ) καθε αξιοπρεπης digital μικτης πλεον,οφειλει να εχει και
digital out. Ετσι ,το σημα παραμενει στο ψηφιακο domain μεχρι τον επεξεργαστη/crossover,γλιτωνεται μια ακομα μετατροπη D/A και μια Α/D ,και υπαρχει βελτιωση του ηχου με μηδενικο κοστος(αφηστε που ο φοβος ψαλιδισμου των προενισχυτων του μικτη απο ενθουσιωδεις dj δεν υπαρχει)
dhio
