Hypex Digital Loudspeaker Correction Platform
Κώστας Φ.
The “DLCP” is a complete hardware/firmware platform for digitally filtered and corrected active multi-way loudspeakers. It can be used as an digital pre amplifier when the optional input board with relays is bought or used as an active filter. With the optional remote board, you can change the volume, input, power without an USB connection. It also contains a LCD display and IR receiver, for a remote controller. This remote board can be connected to the input board of the DLCP with only one CAT5 cable with RJ45 connectors. Digital response correction allows significant extra degrees of freedom in the acoustic design of a loudspeaker. Driver parameters can be selected for best efficiency and distortion instead of electrical damping, and the cabinet can now be fully optimized for radiation pattern. A PC can control the DLCP through the USB port. This connection is used to upload the configuration and filter settings, USB-audio can also be send thru the same cable. It will also be possible to update the firmware through USB.
Features
  • Personal Computer controlled
  • Control board with IR receiver, LCD display and buttons
  • Link communication with midi (only with two or more modules)
  • Input sample rates up to 192kHz
  • Analogue and digital inputs
  • Digital balanced audio loop-through
  • Low-jitter discrete clock oscillator
  • Balanced audio in and out
  • Six channel active filtering
  • Six user configurable analogue outputs
  • IIR and FIR filtering
  • 96kHz sampling rate
  • Pre amplifier version with four analogue balanced inputs
http://hypex.nl/products/DLCP.html
Απάντηση: Hypex Digital Loudspeaker Correction Platform
IIR and FIR filtering = nice... και τα 24/96 καλά είναι.
πολύ φιλόδοξο κι ενδιαφέρον πρότζεκτ.
ΙΜΗΟ θα έπρεπε να έχει πολλούς-δυνατούς επεξεργαστές, πολλή μνήμη, wordclock input, AES/EBU outputs. Δε θα έπρεπε να έχει ενσωματωμένα DAC, παρα μόνο ως option.
Αλλά σε χαμηλά κοστολόγια, όταν ετοιμαστεί δηλαδή, θα αποτελέσει μονόδρομο.
Re: Απάντηση: Hypex Digital Loudspeaker Correction Platform
Γιατί αυτό ???για να μπορούν να οδηγηθούν ψηφιακοί τελικοί που έχουν aes/ebu είσοδο κατέυθείαν,όπως οι Tact????
Απάντηση: Re: Απάντηση: Hypex Digital Loudspeaker Correction Platform
η για να βαζεις το dac της αρεσκειας σου.
:126:
φυσικά, εννοείται πως αν πάρεις κανα ψηφιακό NAD, τι να τα κάνεις μάνα μου τα dac? :139:
:126:
εννοειται αλλα ακομα ειναι πανακριβα και παη Χ3.
akoustiklab
