Voxativ - High End Loudspeakers
vlasis
Φωτογράφος!
VOXATIV - Ampeggio
Technical data:
Frequency response :
38 - 20,000 Hz Driver System : VOXATIV AC-3X Efficiency : 100 dB/1W/1 m Capacity : 50 W sine wave
Dimensions (W x H x D) : 40x110x35 cm Weight : 55 kg
vlasis
Φωτογράφος!
Απάντηση: Voxativ - High End Loudspeakers
VOXATIV - Zarah
Technical data:
Frequency response:
20 – 20,000 Hz Suitable drivers: VOXATIV AC-3/AC-X Efficiency 106/110 dB/1W/1 m Capacity: Up to 250 W sine wave
Dimensions (W x H x D): max. 42x145x55 cm Weight max. 118 kg
Πάρε και ένα review.
Και κάτι σπάνιο στο hi-end:
Initially just as a hobby, Inès Adler began experimenting with widebanders in the 1980s. After she finished her engineering studies with a master's degree, she went to work for Daimler's Mercedes Benz diesel section where she developed engine electronics, ECUs and software. She holds 14 patents on diesel combustion, injection and exhaust treatments. In the late 90s Inès wanted to optimize her widebanders and began a second round of many experiments which netted promising results. To properly distinguish her Voxativ drivers from all precursors like Lowther, AER, Stamm and Loth-X, she designs and fabricates each component part from scratch.
Φαντάζεσαι να την έχεις γκόμενα ή,ακόμα χειρότερα,γυναίκα;
Ότι και να φέρνεις σπίτι θα στο κάνει φυτίλα:137:
Υ.Γ.Respect στην κυρία!
vlasis
Φωτογράφος!
Απάντηση: Re: Απάντηση: Voxativ - High End Loudspeakers
Υπόθετο :137:
Αρχικό μήνυμα απο skaloumbakas
VOXATIV... Νόμισα ότι είναι αντιβιοτικό...
Aκριβως!!!!!!!!!!!!παρτε ενα ο καθενας και βολευτειτε!!!!!!!!!!!!
:143::143::143:
roberto_portale
