YAMAHA RX-V795RDS
ΡΑΔΙΟΕΝΙΣΧΥΤΗΣ 5,1 DD DTS home cinema
Yamaha Original LSI (YSS-918) Incorporates Dolby Digital and DTS Decoders plus DSP Processing Circuits
Equal Output Power for Five Channels
Preset Remote Control Unit with Control Code for TV, VCR, etc.
40-Station Random Access Preset Tuning
Max Power: 125 W x 5 (main, center and rear effect channels)
200 €
[email protected]
Nikos
ΠΡΟΔΙΑΓΡΑΦΕΣ
TOP-OF-THE-LINE 5-CHANNEL HOME THEATER RECEIVERThe RX-V795 is a 5-channel receiver providing the finest performance and processing available for music and video sound. Yamaha's Digital Sound Field Processing, Cinema DSP, and Tri-Field Processing are all included as are Dolby Surround Pro Logic, Dolby Digital, and DTS processing.
DISCRETE POWER TRANSISTORSDiscrete power transistors rather than IC chips are used in the amplifier section to provide the cleanest sound possible. The amp delivers 85 watts each to the five channels.
BUILT-IN DOLBY DIGITALThe most advanced and realistic encoded surround sound for movies from Dolby Laboratories. The new Dolby Digital system is a fully discrete system providing six channels of sound. Five are full-frequency channels, and the sixth is a low frequency effects channel.
BUILT-IN DTS*Like Dolby Digital, DTS is a discrete 5.1 channel system. It uses a higher bit-rate for greater resolution and is available on DVDs, laser discs, and music CDs.
NEW YAMAHA DESIGNED IC CHIPS*Yamaha has designed and employed single function IC chips, called ASICs -- Application Specific Integrated Circuits -- for the RX-V795. ASICs are more efficient than multi-function chips and provide the most accurate decoding possible. Yamaha's YSS-918 is an ASIC which provides Dolby Digital, Dolby Pro Logic, DTS, Cinema DSP, and Tri-Field Processing.
TRI-FIELD PROCESSINGYamaha's exclusive Tri-Field Processing which applies Digital Sound Field Processing technology to Dolby Digital and DTS to create a true movie theater experience in the home. It develops independent enhanced sound fields for the front signals as well as for left and right surround.
25 DSP/CINEMA AND MUSIC DSP PROGRAMS - INCL. 70mm MOVIE THEATER CINEMA DSP*Yamaha's exclusive Digital Sound Field Processing for music recreates the acoustic personalities of actual concert halls and other venues, such as the Roxy Theater in Los Angeles, Village Gate in New York, Anaheim Stadium, and concert halls and churches in Europe. 35mm and 70mm Cinema DSP multiplies the effects of Dolby Pro Logic and Yamaha DSP to provide the best possible Pro Logic movie theater recreation in your home.
DOLBY PRO LOGICStill the most popular format for movie surround sound and superbly handled by the RX-V795.
ON-SCREEN DISPLAY WITH SPEAKER TEST MODE*Allows you to easily establish, change, and adjust settings from across the room. The on-screen display gives you a visual readout of the receiver's settings on your TV or monitor screen. The on-screen speaker test mode makes it easier to balance speaker output from your listening position.
PRE-OUTS FOR ALL CHANNELS INCLUDING SUBWOOFER*Allows you to add outboard amplification and direct subwoofer connection.
6-CHANNEL INPUTS FOR EXTERNAL DECODERThe RX-V795's rear panel has input jacks to accommodate an external 6-channel decoder. So the receiver is ready for any other 5.1 channel format, should one be developed.
NEW SLIM-LINE UNIVERSAL REMOTE CONTROLThe RX-V795's new Universal remote control keypad is an easy-to-use slim-line design which has preset codes for most brands of VCRs, TVs, etc.
THREE DIGITAL INPUTS*The RX-V795 can accommodate three digital sources DVD/LD, TV/DBS and CD. The DVD/LD input has both optical and coaxial digital connections.
THREE AUDIO AND 4 VIDEO INPUTS*The RX-V795 is a versatile receiver incorporating three sets of audio-only inputs and 4 pairs of A/V inputs. All the video inputs have RCA jacks and two have S-video terminals. Includes one set of A/V inputs on the front panel for fast and easy connection. In addition, the RX-V795 provides S-video and composite video output.
AUTO PRIORITY INPUT SELECTIONWhen different input formats are connected from the same source, the RX-V795 automatically prioritizes them and selects in order optical digital, coaxial digital, and finally the analog input.
AUTO SOUND DECODERThe RX-V795 senses a DTS or Dolby Digital signal and will automatically switch the receiver to the appropriate mode when the signal is detected.
REAR PANEL I/O JACKS FOR MULTI-ROOM CAPABILITY*Input and output jacks on the RX-V795's rear panel make the receiver easy to use in multi-room or other custom installation situations.
LOW IMPEDANCE DRIVE CAPABILITY AND IMPEDANCE SWITCHINGYamaha's famed low impedance drive circuitry is included in this receiver so that it can handle virtually all loads and a wide variety of speakers. For further speaker matching, the amplifier can be set for either 4- or 8-ohm speakers.
LINEAR DAMPING FACTOR CIRCUITThe advantage of full range, 20 to 20,000 Hz, damping is that it improves the definition and resolution of the sound output throughout the audible frequency range.
BASS EXTENSION CONTROLAccentuates the bass by adding a 7 dB boost at around 70 Hz.
TONE BYPASS SWITCHAllows you to bypass the bass and treble controls and provides a flat, pure signal.
A/B SPEAKER SELECTORAllows selection of either a first set of speakers or a second -- or both.
SLEEP TIMERPermits a delayed receiver turn off. You can set it for up to two hours in 30 minute increments.
40-STATION DIRECT ACCESS PRESET TUNINGUp to 40 preset AM and FM stations can be grouped in five groups eight stations. These groupings make it easy for family members to easily access their favorite stations or to have musical genres, such as all the jazz stations, grouped together.
BINDING POST SPEAKER TERMINALSHeavy-duty binding post terminals for the main speakers accept banana plugs, spade connectors, and a variety of speaker wire, including heavy gauge cable.
cbk
Θα ήθελα να μάθω πόσο παλιός είναι και αν είναι πρώτο χέρι.
Ευχαριστώ!
simplygades
