Yamaha RX-V771
Καθως τα τρια μεγαλυτερα μοντελα της Γιαμαχα δε φαινεται να αλλαζουν την τρεχουσα χρονια,απο τους νεους την παρασταση φαινεται να κλεβει ο αντικαταστατης του 767, δηλαδη ο 771 αφου σε διαταξη 7,2 εχει πλεον και θυρα εθερνετ ,κατι που ελειπε απο τον προκατοχο του...
Yamaha RX-V771 replaces RX-V767 and is an advanced 7.2 channel networked AV Receiver with 6 in/2 out HDMI (3D and ARC compatibility), iPhone app compatibility, USB connection, HD Audio decoding with CINEMA DSP 3D, YPAO Multipoint functionality, and 1080p upscaling. It decodes the latest sound modes including Dolby TrueHD, Dolby Digital Plus, DTS-HD Master Audio and High Resolution Audio formats for amazing sounding Blu Ray soundtracks, in addition to standard Dolby Digital and DTS sound modes for DVD.
Set-up is easy thanks to Yamaha's YPAO automatic sound optimisation. This involves placing an included microphone in several places around the room as instructed and it will set the level of each channel perfectly. You'll be enjoying stunning sounding home cinema soundtracks in no time.
In addition to HD sound modes, compatibility with Yamaha iPod/iPhone docks, Bluetooth compatibility, 7.2 channels, 6 HDMI inputs, 3D DSP sound modes, an advanced on-screen GUI display, "Dialogue Lift" (a handy feature if you're using front and center speakers below the screen that "lifts" part of the sound so you hear the dialogue more clearly), the RX-V771 adds many new features over the outgoing RX-V767.
Key Features
- 7-channel 160W/ch (max); 7 channel 665W (95W x 7, RMS)
- Discrete amp configuration
- Access to Internet Radio, Streaming Service and music files on PC
- AV Controller app for operating various functions from an iPhone, etc.
- Front panel USB Digital Connection for iPod and iPhone
- Advanced multi-language GUI on-screen display with album art
- 1080p-compatible HDMI: 6 in (1 front), 2 out (simultaneous), 3D and Audio Return Channel
- HDMI front panel input for devices such as camcorders and digital cameras
- HDMI CEC with versatile control from AV Receiver remote control
- YPAO sound optimisation with multi-point measurement
- HD Audio decoding with CINEMA DSP 3D (17 DSP programmes)
- Versatile Zone control with Party mode
Full Specifications
- Channel: 7.2
- CINEMA DSP: Yes (3D)
- DSP Programs: 17
- Compressed Music Enhancer: Yes
- Virtual Presence Speaker: Yes
- Dialogue Lift: Yes
- SILENT CINEMA / Virtual CINEMA DSP: Yes
- Dolby TrueHD: Yes
- Dolby Digital Plus: Yes
- Dolby Pro Logic IIx: Yes
- DTS-HD Master Audio: Yes
- Pure Direct: Yes (with video on mode)
- YPAO sound optimization: Yes
- YPAO multi-point measurement: Yes
- Adaptive DRC (Dynamic Range Control): Yes
- Initial Volume & Maximum Volume Setting: Yes
- Bi-amp capability: Yes
- Audio Delay: Yes (0-250 ms)
- 192kHz/24-bit DACs for all channels: Yes (Burr-Brown)
- HDMI 3D passthrough: Yes
- HDMI Audio Return Channel: Yes
- Component upconversion: Yes
- HDMI upscaling: Yes (Analog to HDMI / HDMI to HDMI)
- Deep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-Sync: Yes
- HDMI Input/Output: 6 (front 1) / 2 (Simultaneous)
- HDMI CEC: Yes (SCENE, Device Control)
- USB Input: iPod/iPhone, USB Memory, Portable Audio Player
- Network Port: Napster / vTuner Internet Radio
- Dock Port: 1 (YDS-12, YID-W10, YBA-10)
- Front AV Input: HDMI/USB/Analog Audio/Composite
- Digital Audio Input/Output: Optical: 2 / 0
- Digital Audio Input/Output: Coaxial: 2 / 0
- Analog Audio Input/Output: 6 (front 1) / 1
- Phono Input: Yes
- Component Video Input/Output: 2 / 1
- S-Video Input/Output: 1 / 0
- Composite Video Input/Output: 5 (front 1) / 1
- Preout: 7.2ch
- Headphone Output: 1
- FM/AM Tuner: Yes
- On-screen display: Graphical User Interface
- SCENE: SCENE (4 sets)
- iPhone App Control: Yes
- Web Browser Control: Yes
- Remote Control Unit: Yes (Preset, Learning)
- Zone 2 Audio Output: Line output
- Powered Zone: Zone 2
- +12V Trigger Output: 1
- Remote (IR) Input/Output: 1 / 1
- Party Mode: Yes
- Standby Power Consumption (IR only): ≤0.1W
- Auto Power Down: Yes
- Dimensions (W x H x D): 435 x 171 x 368 mm
- Weight: 11.2 kg
http://europe.yamaha.com/en/product...s-amps/rx-v771_g/?mode=model#page=1&selected=
καπου στην Αγγλια, τιμαται στις 650 λιρες (740ε δηλαδη)...
βαλτε και αλλες 40 να ερθει,και με 785ε εχετε ενα πληρεστατο ραδιοενισχυτη...
Απάντηση: Yamaha RX-V771
αν δεν προλαβω ενα τελευταιο κομματι 3067 στο Νησι με τιμη που εδω αγοραζεις τον 2067 η τον Pioneer73 και παιρνεις και ρεστα,μαλλον θα ειναι ο τριτος μου Γιαμι για φετος,μετα τους δυο 467 που πηρα χθες....:109:
να κανω μια ερωτηση..?
με περιπου 400 ευρω ποιον γιαμι θα μπορουσα να παρω με υποστηριξη hd,πανω απο 3 οπτικες kai αν γινεται με 7.1...?ευχαριστω.
1)YAMAHA RXV667
2)YAMAHA RXV567
3)YAMAHA RXV1065
απο Αγγλια,στο αμαζοn & e-bay...
νομιζω πως ερωτευτηκα τον RXV667 ......!!!!!!
o 771 διαθεσιμος στο Νησι σε ενα μηνα περιπου...
Κυνήγα τον 3067 φίλε καλή επιτυχία! Από quantum electronics είδα ότι υπάρχει ακόμα.
Re: Απάντηση: Yamaha RX-V771
Για δεστε σε βιντεο ενα review του 671 να παρετε μια ιδεα : link...
Η σειρα AVENTAGE φαινεται σουπερ. Δεν θα ερθει κατα Ευρωπη μερια ?
oops...την ειδα....ερχεται και Ελλαδα.
George Tzelalis
