ΕΝΙΣΧΥΤΗΣ ΑV SONY STR DG 700 150 EYRO
Future-proof HDMI connection (2 In/1 Out) to bridge multiple High Definition sources to Flat TVs/Home Cinema Projectors without any picture quality loss Digital Cinema Autocalibration - just place the microphone on your couch and plug it into the receiver. The receiver adjusts automatically the perfect surround sound according to your room and speaker set-up. Discrete 6 channels with equally 100W (+subwoofer) for powerful home entertainment. Component video as an alternative High Definition pass-trough connection to HDMI. Video upconversion to component video from all analogue connections. Several sources can be connected analogue (S-Video and Composite for example) to the receiver but only one component cable to the Flat TV/Projector is necessary. All common surround formats are supported. Dolby® Digital / Dolby® Digital EX / DTS / DTS-ES / DTS NEO:6 Decoder / DTS 96/24 Dolby® Pro Logic® II / Dolby® Pro Logic® II X / Dolby® Dual Mono 96k/24Bit PCM Audio-Video Synchronisation - to make sure picture and sound are perfectly fitting together the way they were recorded. Sony's proprietary Digital Cinema Sound (developed together with Sony Pictures) to bring the sound from the best cinemas to your living room. Inbuilt Radio Tuner with 30 station memory. Wide range of possible connections: HDMI In/Out: 2/1 Component Video In/Out: 2/1 Audio In/Out: 3/1 AV In/Out: 4/1 Opt. In/Out: 3/1 Coax In/Out: 2/
ΑΡΙΣΤΗ ΚΑΤΑΣΤΑΣΗ ΜΕ MANUAL
Dragon
