ΠΛΗΡΕΣ ΗΧΟΣΥΣΤΗΜΑ ΑΥΤΟΚΙΝΗΤΟΥ
2300 ΕΥΡΟ ΚΑΙ ΠΩΛΟΥΝΤΕ ΟΛΑ ΜΑΖΙ.
ΣΕ ΠΟΛΥ ΚΑΛΗ ΚΑΤΑΣΤΑΣΗ ΚΑΙ ΕΛΑΦΡΩΣ ΜΕΤΑΧΕΙΡΙΣΜΕΝΑ
ΠΑΡΑΚΑΛΩ ΜΟΝΟ ΣΟΒΑΡΕΣ ΠΡΟΤΑΣΕΙΣ
Η ΤΙΜΗ ΑΛΛΑ ΚΑΙ ΟΠΟΙΑ ΠΡΟΤΑΣΗ ΑΝΤΑΛΛΑΓΗΣ (ΜΕ ΑΥΤΟ-ΜΟΤΟ) ΕΙΝΑΙ ΣΥΖΗΤΗΣΙΜΗ
4 Χ 7" PERRLESS mid bass
MODEL : HDS-P830883
Nomex fiber cone/Phase plug-silver color/Rubber surround/Cast frame - silver color/Ventilated raised spider/Shorting rings/180mm flange/147mm cut out
/78mm depth
2 X 1" PERRLESS VIFA tweeter
MODEL :XT25TG30-04
Power handling: 99 watts RMS/Nominal impedance: 4 ohms/DC resistance: 3 ohms/Frequency range: 1,500-40,000 Hz/Magnet weight: 8.5 oz/Fs: 500 Hz/SPL: 91.5 dB 1W/1m
Dimensions: Overall Diameter: 4-1/8"/Cutout Diameter: 2-15/16"/Mounting Depth: 1-13/16"/Magnet Diameter: 2-15/16
2 X 1" SCAN SPEAK mid range
MODEL : 10F-4424G00
Aluminium Chassis/Fiber Glass cone/NR rubber surround/Neodynium Magnet/Copper cap on the pole piece
1 x 12" PEERLESS XLS subwoofer 4+4ohm
MODEL : XLS 830856
Extra Long Stroke Sub/Thick Nomex fiber cone
Cast frame/Big roll rubber surround
308mm flange/278mm cut out/126mm dept
Z -4 ohm/Pe 350W/SPL 87.6 dB/watt1m/Re -1.5 ohm/Fs -49 hz/Qms -8.06/Qes -0.66/Qts -0.61/Vas -20.4 litres/X max 12,5 mm/Sd - Cone Area 466 sq cm/EBP -74
HIFONICS 5 FARAD capasitor
MODEL : HF5.0
5 Farad Triple Puffe with 4 digit blue digital display/
2 blue status-tubes/port protector made ​​of Plexiglas
oversized screw-type terminals
packaged in a sturdy aluminum case
1 HIFINICS amplifier
MODEL : OLYMPUS XI
125 watts x 4 channels into 4 Ohms (stereo)
200 watts x 4 channels into 2 Ohms (stereo)
250 watts x 4 channels into 1 Ohm (stereo)
400 watts x 2 channels into 4 Ohms (bridged)
500 watts x 2 channels into 2 Ohms (bridged)
Full MOSFET Amplifier/Regulated Power Supply
0 - 18dB Variable Bass EQ/Fully Adjustable Crossovers with Variable Slopes/Subsonic Filters/1 Ohm Stable
PLANET AUDIO Handcrafted USA amplifier
MODEL : REM2400
Power Source Voltage 12.6 volts/Bridged Power Four Ohms 803 watts/Output Power two Ohms 402 watts per channel/Frequency Response 12 hz - 50khz/Signal to Noise Ratio 102 dB/Damping factor 152 20hz, 4 ohms/THD 0.045 20hz - 20Khz/Input Sensitivity 102mv - 5.1v/Short Circuit Protection/Dc Protection/Thermal lManagement
ALPINE in-dash dvd 7" multimedia system MODEL : IVA-D310
Motorized Retractable 7" Touch Panel LCD Display/PulseTouch Tactile Feedback/Detachable Control Panel Faceplate/Secondary Display on Control Panel/DVD-R/RW, MP3/WMA, CD-R/RW Compatible/Peak Power Rating: 50 Watts x 4 Channels/DVD Touch Menu Direct Control/Bass Engine Plus Features:4-Channel Time Correction,3-Position High-Low- Pass Crossover
Bass & Treble Center Frequency Control/Subwoofer Level and Phase Control/MediaXpander/iPersonalize: Create Personalized Bass Engine Settings/
SIRIUS, XM Satellite Radio controls/CD Changer/ TV Tuner Controls/AV Input/Backup Camera Input/Navigation Input/iPod Adapter Compatible/AV Output/RCA Preamp Outputs: 3 Pair (Front, Rear, Sub)/Dolby Digital-DTS Decoder Ready/Digital Audio Output
ΧΕΙΡΟΠΟΙΗΤΑ CROSSOVER/ΚΑΛΩΔΙΩΣΕΙΣ/3 ΑΣΦΑΛΙΩΘΗΚΕΣ
Απάντηση: ΠΛΗΡΕΣ ΗΧΟΣΥΣΤΗΜΑ ΑΥΤΟΚΙΝΗΤΟΥ
Βαζω ολες της εικονες σε ενα link το οποιο ειναι online photo album και απο εκει μποριτε να δειτε πιο αναλυτικα τα πραγματα.
http://photobucket.com/bassrider
Tελος η τιμη ειναι ΣΥΖΗΤΗΣΙΜΗ (λογο αναγκης) οποτε μπορειτε να στηλετε την οποια προσφορα σας αλλα και στο τηλ 6972369368
Nick Arvanitakis
Audio Pro
θα ηθελα να διορθωσω οτι τα tweeter και τα midrange ειναι 4" και οχι 1" οπως αναφερω πιο πανω.
Να στο διορθώσω αν θέλεις στο αρχικό κείμενο , αλλά τα tweeter , για μιας ίντσας δείχνουν.
δικο μου λαθος τελικα. οντος 1" και τα δυο ειναι οποτε εκανα edit το 2ο post μου! σε ευχαριστω!
ΣΤΗΝ ΙΔΙΑ ΤΙΜΗ (2000euro) ΠΡΟΣΘΕΤΩ ΚΑΙ ΜΙΑ ΜΠΑΤΑΡΙΑ ΜΑΖΙ
DEKA 9A78DT 12v 785CCA AGM Group 78 Dual Terminal.
spec.:
Absorbed Glass Mat Technology, Spill Free, No Filling, Ready to go
Voltage: 12v 785 CCA @ 0°F
Battery Capacity: 55Ah 20HR
Approx. Weight: 42.5 lbs
Dimensions (+/- 1/16 inch): 10 3/4 x 6 7/8 x 8 inches
Dual Terminal SAE and front mount
No Acid to fill, No Corrosion
Extra cranking power
Increased service life
Protection against acid leakage and corrosion
Impact resistant case and cover
Optimum performance in extreme weather conditions
OEM Battery Compatible
Η τιμή πέφτει στα 1700 ευρό και είναι τελική! Μην παίρνετε για παζάρια.Όποιος προλάβει!
Νεα τιμη στα 1400 ευρο για 5 μερες αλλιως η αγγελια θα διαγραφη!
Παρακαλώ να διαγραφή η αγγελία! Ευχαριστώ!
dimastro
