Datasat RS20i και μια σαλιαρα παρακαλω
Απάντηση: Datasat RS20i και μια σαλιαρα παρακαλω
το φανταστηκα, απλα ειδα τις p.e και ειπα μηπως βαζαν κατι εκει , που χωρα τα παντα ολα,
(αν ειναι εφικτο απο μεσα).............
Βαγγέλης Λάμπρου
Digital Audio Decoders
Dolby
Dolby® AC3
DTS
DTS®-HD Master Audio / DTS ES / DTS 5.1 / Neo:6
Signal Inputs
HDMI Audio & Video Inputs
•Audio Channels: Up to 8 (LPCM, DTS-HD Master Audio & Dolby AC3)
•Connectors: 5 HDMI connectors (4 switched as inputs and 1 as output)
•HDMI V1.4a compliant digital audio with video pass-thru
Digital Audio Inputs
•Channels: 16
•Connectors: Two DB25 Female (Ch1-8 and Ch9-16)
•Digital Format: AES/EBU
•Sample Rates: 44.1kHz, 48kHz, 96kHz and 192kHz
Other Digital Audio Inputs
•Connectors: Two TOSLINK (optical S/PDIF) and 1 coaxial (S/PDIF)
Analog Audio Inputs
•Channels: 8 balanced, can be connected unbalanced
•Connector: DB25 (Female)
•Impedance: 10k ohms
•Reference level: 300mV RMS
Other Analog Audio Inputs
•Channels: 2 stereo single ended input pairs
•Connectors: 4 RCA jacks
•Sensitivity Adjustable: -16dBv to -4dBv
Microphone Input
•Single channel -68dBv to -8dBv input with switchable +48V phantom power
•Connector: XLR female
Signal Outputs
Digital Audio Outputs
•Channels: 16, fully routable as to input
•Connectors: Two DB25 Male (Ch1-8 and Ch9-16)
•Sample Rates: 48kHz, 96kHz and 192kHz
Analog Audio Outputs
•Channels: 16 (fully routable as to input), common mapping with Digital Outputs
•Balanced (can be connected unbalanced or single ended)
•Level: 300mV with Fader at 7, +26dBu max (balanced)
•Connector: 1 single ended RCA output, channel-selectable to drive an external monitor. Adjustable Levels, to 300mV RMS
•Connector: 1 single ended RCA output, summed output for the hearing impaired. Fixed Level Out, 300mV RMS
Audio EQ
Dirac Live® Room Optimization
•12-Channel Dirac Live® room optimization (16-channel Dirac to be available in future release)
•Dirac Live® Installer kit sold separately
3rd Octave EQ
•16 channels - 31 user-adjustable bandpass filters
•Gain +/-6dB adjustable in 0.5dB steps
•Frequencies range from 20Hz to 20kHz
Parametric
•16 channels with 3 user-adjustable parametric filters for shaping Subwoofer response
•Adjustable from 20 to 200Hz, gain +/-6dB i•0.1dB steps
•Q range from 0.7 to 5
Hi/Low/Bandpass Active Crossovers
•Adjustable from 20Hz to 20kHz; adjustable slope of 6, 12, 18 or 24dB per octave (12 and 24dB filters are Linkwitz-Riley crossover)
Bass/Treble tone control
•Adjustable +/-6dB per channel
•Corner frequency for bass adjustable from 50Hz to 300Hz
•Corner frequency for treble adjustable from 1.5kHz to 12.0kHz
Bass Management
•Full or adjustable high pass settings for screen and surround speakers
•Adjustable low pass filter for sub woofers
•Support for 0 to 4 sub woofers
•Optional phantom center
Audio Delays
Individual Channel Delays
•0 - 1000ms
Global Delay
•0 –1000msNote: Total delay per channel not to exceed 1000ms
35mm Film Optical Soundtrack Audio Processing
•Available with optional H338 plug-in circuit board
Κάτω δεξιά,αλλά είναι με θύρα τύπου RS,οπότε χρειάζεται αντάπτορας.
Sorry,τύπου DB25 είναι.
Βαγγέλης Λάμπρου
Αυτή είναι η φύσα σύνδεσης για τους ενισχυτές.
Είπαμε: κινηματογραφικός ενισχυτής.
Τα ηχεία εκεί είναι πάντα ενεργά... "χάρη" μας κάνουν :116:
Βαγγέλης Λάμπρου
βαγγελη το τρεχον μοντελο (πουχεις στην φωτο)
παιζει dolby thd ?
οι αναλογικες (7,1) που ειναι , ? ή θα ειναι ?
Το Dolby HD θα προστεθεί με κάρτα σε μια απο τις 3 θύρες επέκτασης. Οσοι το έχουμε ήδη αγοράσει θα μας τη στείλουν δωρεάν.
Βαγγέλης Λάμπρου
Το δεύτερο καλύτερο χαρτί του είναι η ψηφιακή επεξεργασία του ήχου βάση του χώρου μέσω του Dirac Live. Στην διήμερη εκπαίδευση στο Λονδίνο μείναμε "Παυλόπουλοι"
Το τι πραγματικά κάνει ο επεξεργαστής είτε manually είτε αυτόματα απλά δεν περιγράφεται.
ερε κασιδιαρ , μεχρι στας αγγλιας εφτασε η χαρη σου..........
κοκαλο ο δικος μας......................
αφου τοπες μονο σου, σας αφησε παγωτο το dirac .........στο αμερικανικο φορουμ εχει γινει χαμος.......
ρε συ Βαγγο......
......αυτη ειναι η κινηματογραφικη διορθωση.
Βαγγέλης Λάμπρου
Δεν είναι δική μου παραμετροποίηση Κώστα, παράδειγμα έβαλα απο το Dirac
Για ρύθμιση αγορασαμε απο τη Dirac ένα βαλιτσάκι με το πρόγραμμα, μικρόφωνα, equiazers κλπ, ίδιο με αυτο που γίνεται και το calibration και στις κινηματογραφικές αίθουσες.
Μη ρωτάς πόσο κάνει το Kit του κ.Dirac !
εννοω οτι αυτη η διορθωση που εβαλες ισχυει σε αιθουσες........
σωστα....?
φανταζομαι οτι θα μπορεις να κανεις οτι θελεις,ειτε σε επιπεδο αυτοματο,ειτε σε επιπεδο ορεξεως..
τι ειναι κωστακη ?
το κιτ του audyssey που με 700 ευρουδακια , χτυπαγες
καλιμπραρισμενο μικροφωνο ενισχυτη, σοφτγουερ , καλωδια , τριποδο. βαλιτσακι οδηγιες .......
Αν θες να φας πσαρι πρεπει να ιδρωξεις .........αλλα φανταζομαι καλυτερα μην ακουσεις αυτο το πραμα
Μετα θα στοκαρεις οτι εχεις και δεν εχεις για την επερχομενη γιορτη του Αη Γιαννη του Φανιστη..............
u know
ταπαμε .......αυτο που εχεις ειναι για πεταμα.:105:
Βαγγέλης Λάμπρου
Ακριβώς Κώστα...ορεξη να έχεις.
Στο Λονδίνο το χρησιμοποιούν μεχρι και σε Club εδικά όπου έχουν πολλά ηχεία και διαμορφώνουν τον στερεοφωνικό ήχο σέ καθε ένα ηχείο ξεχωριστα ώστε να έχουν πχ 16 ηχεία που η ακουστική τους να είναι οσο εγγύτερα γίνεται.
Στο δωμάτιο εκπαίδευσης (φωτό) φαίνεται ένας έγχρωμος πιτσιρικάς που είναι απο τους πιο γνωστούς και ακριβοπληρωμένους DJ του Λονδίνου. Εβαλε το Rs20i οχι για Home theater αλλά για να ισοσταθμίσει το ηχο του club βάση "της όρεξη του".
Εκεί μάλλον φαίνεται οτι τα νυχτομάγαζα "πληρώνουν" για τον ηχο που πουλάνε στους πελάτες τους.
εχεις πλακα που λεει ο μαρκου......χοντρη πλακα............:143:
http://www.avsforum.com/t/1366849/d...d-comparison-with-ada-rhapsody-trinnov-teq-12
και δωστου πλακα.....τα καλωδια του πεταματος ειναι ακριβοτερα απο ............
εεεεεεεεετσι......
το ωραιο αποτελεσμα το πλερωνεις...:403:
stratos.april
