JOHN MARKOU
Münchhausen
Απάντηση: Νκορίασις......πως λέμε ψωρίασις.
Kαλά!!! , ρίχτους εσυ 1500wrms, και άμα δεν γίνουν πύραυλοι εδάφους αέρος, εγω θα γίνω λαμπάτος.
SCM50SL (Passive)
Drivers: HF 25mm Mid 75mm LF 234mm Super Linear
Amplitude Linearity ±2dB: 70Hz – 17kHz
Frequency Response -6dB: 40Hz & 22kHz
Matched Response: ±0.5dB
Dispersion: ±80° Coherent Horizontal ±10° Coherent Vertical
Sensitivity (sine wave): 85dB @ 1W @ 1m
Max continuous SPL @1m: 112dB SPL
Crossover Frequency: 380Hz & 3.5kHz
Input Connector: Binding Posts/4mm banana plugs
Recommended Power Amplifier: 100 to 1500 Watts
Nominal Impedance: 8 ohms
Cabinet Dimensions(HxWxD): 717x304x425mm
Weight: 41.1kg
http://www.atcloudspeakers.co.uk/hi-fi/loudspeakers/classic-series/scm50/
Τουλάχιστον ΔΕΝ καίγονται ρεεεεεεεεεε!![]()
