Διάφορα
Amazing...
On July 19, 2013, in an event celebrated the world over, NASA's Cassini spacecraft slipped into Saturn's shadow and turned to image the planet, seven of its moons, its inner rings -- and, in the background, our home planet, Earth.
With the sun's powerful and potentially damaging rays eclipsed by Saturn itself, Cassini's onboard cameras were able to take advantage of this unique viewing geometry. They acquired a panoramic mosaic of the Saturn system that allows scientists to see details in the rings and throughout the system as they are backlit by the sun. This mosaic is special as it marks the third time our home planet was imaged from the outer solar system; the second time it was imaged by Cassini from Saturn's orbit; and the first time ever that inhabitants of Earth were made aware in advance that their photo would be taken from such a great distance.
With both Cassini's wide-angle and narrow-angle cameras aimed at Saturn, Cassini was able to capture 323 images in just over four hours. This final mosaic uses 141 of those wide-angle images. Images taken using the red, green and blue spectral filters of the wide-angle camera were combined and mosaicked together to create this natural-color view. A brightened version with contrast and color enhanced (Figure 1), a version with just the planets annotated (Figure 2), and an annotated version (Figure 3) are shown above.
The Day the Earth Smiled
xfader
Ανακαλύφθηκε νέο είδος θαλάσσιων σαλιγκαριών. Είναι ερμαφρόδιτα και το μακρύ τους πέος έχει δύο απολήξεις. Κατά τη σεξουαλική συνεύρεση η μία απόληξη εισχωρεί στο γνωστό μέρος, ενώ η άλλη καρφώνεται στο μέτωπο του συντρόφου και εκλύει υγρό από τον προστάτη! Η διάρκεια της επαφής φτάνει τα 40 λεπτά.
http://blog.backblaze.com/2013/11/12/how-long-do-disk-drives-last/
Πότε χαλάνε οι σκληροί δίσκοι σε περιβάλλον datacenter, πολύ σκληρότερο απο την οικιακή χρήση;
Ενώ τον πρώτο χρόνο χαλάει το 5.1%, μετά το ξεσκαρτάρισμα :) το 80% θα λειτουργήσει τουλάχιστον 4 χρόνια και το 50% πάνω απο 6 χρόνια.
http://ktla.com/2013/10/14/18-foot-...lina-amazes-scientists-campers/#axzz2kVYlsnJh
https://en.wikipedia.org/wiki/Oarfish
Νεκροτομή του oarfish που βρέθηκε τον προηγούμενο μήνα στην Καλιφόρνια.
http://www.ctvnews.ca/sci-tech/huge...ed-with-little-monsters-researchers-1.1525409
http://www.southernfriedscience.com/?p=15996
Οι έντεκα πιο τρομακτικές ταινίες κατά τον Μάρτιν Σκορσέζε.
1. The Haunting
2. The Isle of the Dead
3. The Uninvited
4. The Entity
5. Dead of Night
6. The Changeling
7. The Shining
8. The Exorcist
9. Night of the Demon
10. The Innocents
11. Psycho
www.e-go.gr/cinemag/article.asp?catid=10167&subid=2&pubid=129550358
MaxHeadroom
Αναρωτιέμαι τι θα έδειχνε μια ανάλυση DNA στο Μιχαλολιάκο και τον Κασιδιάρη. :D
MaxHeadroom
Το βρήκα τόσο ενδιαφέρον, που πήγα κατευθείαν στο σημείο που το αμάξι έβγαζε καπνούς. :biggrin:
MaxHeadroom
Ανοίγει τις πύλες του ο πρώτος ουρανοξύστης στο «Σημείο Μηδέν»
Νέα Υόρκη
Δώδεκα χρόνια μετά την τρομοκρατική επίθεση της 11ης Σεπτεμβρίου 2001, ο πρώτος νέος ουρανοξύστης στο «Σημείο Μηδέν», εκεί όπου βρίσκονταν οι Δίδυμοι Πύργοι, ανοίγει τις πύλες του σήμερα Τετάρτη.
Πρόκειται για το μικρότερο από τους τέσσερις ουρανοξύστες, στο σημείο όπου δώδεκα χρόνια πριν έχασαν τη ζωή τους 2.700 άτομα. Είναι φτιαγμένος από γυαλί, έχει ύψος 289 μέτρα και διαθέτει 72 ορόφους.
Δίπλα του θα βρίσκεται το υψηλότερο κτίριο στις ΗΠΑ, το οποίο θα έχει ολοκληρωθεί μέχρι τις αρχές του 2014. Το One World Trade Center θα έχει ύψος 541 μέτρα. Το 72 ορόφων κτήριο είναι προς το παρόν άδειο, ωστόσο δύο κυβερνητικές υπηρεσίες έχουν ήδη υπογράψει για την ενοικίαση του μισού του χώρου.
Newsroom ΔΟΛ, με πληροφορίες από Reuters
gagakostas
