Sony STR DA 5800ES
Eνα πραγματικο καλο μηχανακι απο την τοσο παρεξηγημενη sony, ετυχε να τον ακουσω χθες (πηρε την θεση ενος sony δυο φουρνιες πισω) , και το μηχανακι ηχητικα θυμιζει pioneer 90s.
Οκ 2 τοσα χιλιαρικα , αλλα ειναι στην υψηλη λιγκα av , λειπουν πραματα, αλλα ο ηχος αποζημειωνει.
http://www.sony.gr/product/hcs-home-cinema-receiver/str-da5800es
http://www.soundandvision.com/content/test-report-sony-str-da5800es-av-receiver-page-3
Regarding multichannel power: Our first unit failed under test after a few seconds at around 110 watts x five channels, entering a "Protector" mode and refusing to exit it even after multiple reboot and re-power attempts over several days. Sony kindly sent a second sample: after less than a second of driving all 5 channels at a roughly 100 watt level, it shut off its outputs, displayed "PROTECTOR," and self-powered down. It then sat, clicking an internal relay every 8 seconds but otherwise unresponsive, including to its power key, for more than an hour, by which time it was fairly cool but still clicking.
Re-booting by unplugging the AC cord for a minute restored normal operation. Re-trying the test, I briefly saw a 5-channel clipping point of approximately 110 watts, a few seconds of which induced a current-limiting "limp-mode" that reduced power output to no more than 20 watts from any or all channels. Reducing drive to a few watts for 15 seconds or so restored normal ops. I was able to rinse & repeat this cycle several times without re-visiting either the unresponsive/clicking mode, or the living-dead trance of the earlier unit.
Με λίγα λόγια, δεν είναι για πολλά... :D
τι εννοειται βρε χαμενε ......ουτε ξερεις τι ακουσες
οταν ακουνε εναν ολοκληρωμενο av ....δεν κοτσαρουν τελικους για να δουν αν παιζει καλα..
χαιτεκ εχεις καταντησει....:laugh:
  • Like
Reactions: PPG
Ελα ρε ?
δωσε μας το φως σου ......πες τα ολα...που ελεγες τον sunfire ψηφιακο τροματα σου....
Αληθεια μιας και για ακομα μια φορα λες κεφαλιες.....την επεξεργασια ηχου την κανει ο τελικος ?
δηλαδη αν σε ενα τελικο κοτσαρουμε 2 av πριν θα παιζουν ιδια ?
ρε μπας και κανεις παρεα με τον αμπασο και σε εχουν κοψει οι αναθυμιασεις ?
Οσο για το τι ακουει ποιος ?
Σου ειπα , μιλας με ξεκουμπωμενες χρωμοδιαφορες.........
τα βλεπς κιεφαλα ?
μα αυτα που γραφς μαζευεις κοσμο .....τοιρα να τους ταισεις κιολας
σουρουκλεμε
stathis
Ultra Home Theater
Οι τελικοι δεν προσθετουν τον ηχητικο χαραχτηρα τους στο ακουσμα?, αν ηταν θα ειχαμε ολοι τους ιδιους.
Τα παντα ολα προσθετουν και αφαιρουν .......οπως ειπα
αν βαλεις πισω απο ενα τρικαναλο κρελ , ενα ονκιο και ενα ντενον
θα ακους τα ιδια , και σαν ποιοτητα , και σαν επεξεργασια (ταινιας) ?
Καθε συσκευη εχει το δικος της, ηχητικα δακτυλικο αποτυπωμα.......
Εκτος βεβαια και αν πριν στραγκιξεις κανα δυο μπουκαλια σαμαραπετρα ...
οποτε μονο τα σανσουι παιζουν σωστα...
Οταν ξενερωσεις βεβαια απλα θαχεις καψει κυταρα και θα ζεις με την ιδια εντυπωση
Δεν ειναι σανσουι ?
δεν παιζει οποως πρεπει (και στο καπακι θα ανοιγεις ενα μπουκαλι διγενακη).......
Nick Arvanitakis
Audio Pro
Ωραία όλα αυτά , αλλά ένας ολοκληρωμένος AVR , δεν κρίνεται επί μέρους, πχ προενίσχυση , επεξεργασία εικόνας- ήχου , αλλά και και απ την οδήγηση, τις ευκολίες κλπ.
σωστα, αλλη η οδηγηση της σονυ ηταν παντα το αδυνατο σημειο της,
αν προσθεσουμε και την ισοσταθμιση (οχι επιπεδου mcacc audyssey)
+ τα καναλια μεχρι τα 11 ,
και ισως και 4 εξοδους σαμπ.......οποτε μενει να πουμε για αυτα που εχει.
Η επεξεργασια εικονας (πιθανο) να αφηνει αδιαφορους τους υποψηφιους αγοραστες ,
μιας και αν εχεις 2 τοσα χιλιαρικα για ενα μηχανακι ap , θα εχεις και μια πηγη αναλογης λιγκας,
(700 + ευρω), οποτε η επεξεργασια εικονας μαλλον δεν ενδιαφερει.
Εκτος βεβαια και αν εχεις και αλλες πηγες (πλη του br)
Βεβαια οταν οι πηγες θα εχουν εισοδο hdmi τοτε ...........οι av θα πρεπει καπως να ανεβασουν τπον πυχη ψηλοτερα.
Nick Arvanitakis
Audio Pro
Δηλαδή τα ''στραβά'' του κάθε μηχανήματος δεν τ ακουμπάμε?
Τι είμαστε περιοδικό και φοβόμαστε μη μας κόψουν τη διαφήμιση?
και βεβαια , οχι απλα τα ακουμπαμε ,τα αναδεικνυουμε , ολα ειναι υποψιν του καθε αναγνωστη.
ενας μεσος χρηστης των 1000 - 1800 ευρω (ας πουμε) ποσα απο τα καλουδια του καθε av του χρησιμοποιει ? αξιοποιει ?
Ο σονι θα προτιμηθει για τον ηχο του , σε ολα τα αλλα εχει μεινει πισω (και δεν μιλαω για τα ρευματα του) γενικα ειναι ο πιο τεχνολογικα ξεπερασμενος ενισχυτης απο την ιαπωνικη σχολη.
(οπως αναλυσα πιο πανω).
Eνα πραγματικο καλο μηχανακι απο την τοσο παρεξηγημενη sony, ετυχε να τον ακουσω χθες ........
εκανες μ@λ@κια .....ο Zizik το εθεσε σωστα για τους καταναλωτες ενος ολοκληρομενου av
....και μετα προσπαθησες να τα μπαλωσεις.....
ασε μας ρε Αναργυρε.......
και σταματα να γραφεις πραγματα που δεν ισχυουν....
μην πετας φωτοβολιδες μπας και σωθεις.....
εισαι πνηγμενος αν δεν τοχεις παρει χαμπαρι.....!!!
lakiss51
Eσεις μπορειτε να λετε οτι θελετε για τον avr
ο ΗΧΟΣ τον αποθεωσε (τ.481)
Όπως μάθαμε/είδαμε χθες είναι ο πρώτος παγκοσμίως ενισχυτής που ενσωματώνει ένα πλήρες σύστημα ελέγχου αυτοματισμού και συγκεκριμένα της Control4.
Τι σημαίνει αυτό πρακτικά;
Ότι το κόστος για να έχει κάποιος αυτοματισμό ελέγχου τηλεόρασης,οθόνης,προβολέα,φωτισμού,θερμοκρασίας,τουλάχιστον όσον αφορά μία ή δύο ζώνες,κατεβαίνει στα τάρταρα σε σχέση με αντίστοιχες προτάσεις ανάλογης ποιότητας και ευκολίας.Ταυτόχρονα μέσω του εξαιρετικά φιλικού γραφικού περιβάλλοντος αυξάνεται κατακόρυφα η ευκολία χρήσης από όλα τα μέλη της οικογένειας.
Πέραν φυσικά αυτών μεγάλη εντύπωση μου έκανε ότι το πρόγραμμα έχει open source δυνατότητες,το οποίο δίνει σε κάποιον την δυνατότητα να δημιουργεί δικές του εφαρμογές ελέγχου.Αυτό εξ' όσων ξέρω δεν υπάρχει σε άλλη παρόμοια εταιρία.
papaevagelouv
