high-end audio computer
vlasis
Φωτογράφος!
AUDIOPHILE OPTIMIZER.
Use Windows Server 2012 R2 as operating system for your high-end audio computer, optimize it with the AudiophileOptimizer and experience analog-like sound as you have never heard it before on a computer based audio system. Learn how to set up your own high-end audio computer by simply following the free PDF guide.
A Windows Server 2012 or 2012 R2 system in core mode, fully optimized with the AudiophileOptimizer, runs only 5 to 7 services and about 15 to 20 threads. Almost 150 unnecessary drivers and services are disabled, resulting in the optimal platform for ultra high-end audio reproduction. Over 250 additional modifications also benefit various elements of the operating system including priority scheduling, CPU modes and the file system, all of which greatly improve sound quality. The result is so enjoyable, so detailed, and so compelling that you simply must hear it for yourself.
DOWNLOAD NOW: Windows Server 2012 R2 Evaluation ISO(180 days trial) & free PDF Guide
vlasis
Φωτογράφος!
Sound Quality:
- Analog sound quality rarely heard before on computer audio systems
- Bigger soundstage, holographic imaging, more 3D-effect
- Very well defined bass, deeper and more powerful
- Lifelike, fluid and very precise sound reproduction
- Natural air, timbre and image density
- Ability to fine-tune the final sound presentation (through Sound
Signatures and Digital-Filter modes) to achieve outstanding balance
- Sound Signatures and Digital-Filter modes are 100% bit perfect
- Minimizes harshness in digital sound
- Very low noise floor / blacker backgrounds
- Don't miss to read the REVIEWS
Features:
- World's first solution to offer Kernel-Streaming (for x86 &
x64 Media Players) in Windows Server 2012 core mode
- Express mode for beginners and Advanced mode for experts
- ServiceTool to easily switch between GUI/minimal/core mode
- Doesn't need JPLAY, but works exceptionally well with it
- Works on single box systems and Dual-PC setups
- WASAPI support in minimal server and GUI edition
- ASIO support in GUI, minimal-server and core edition
- No additional processes or tasks running on your system
- Enables JRiver Media Center, Foobar2000 and many other
x86-players under Windows Server 2012 in core mode
- PCM, DoP, DSD, Multichannel DSD, all file formats supported
Feature Details:
- 250+ optimizations with focus on the best music reproduction possible
- Disable unnecessary system services and drivers
- Optimization of your hard drive and file system
- Optimization of USB & PCIe power management
- Optimized power and performance settings
- Optimized CPU and memory management
- Optimization of task & IRQ priorities
- Optimization of TCP/IP protocol
- Additional performance tuning
- Optimization of GUI settings
- Get very fast boot and shutdown times
- Swiss made software
vlasis
Φωτογράφος!
PDF Guide:
- Step-by-step Guide for setup of a high-end computer audio system
- Tips & tricks about BIOS/EFI Settings, network tuning, low latency tuning
- DOS & PowerShell commands, driver installation & configuration
- How to setup a JPLAY Dual-PC setup (StreamerMode)
- How to tune JPLAY registry for maximum sound quality
- How to make a bootable USB Stick for OS installation
- How to configure autologon and shell replacement
- How to get the maximum out of your DAC or DDC
...and much more. Check out the PDF Guide
εχει ασχοληθει καποιος φιλος με αυτο?
πως το βλεπετε το ολο κολπο?
gkontoletas
trouble in my brain
ο τύπος καταργεί πολλές σημαντικές ρυθμίσεις ασφάλειας, αν το βάλεις στο internet έτσι την έχεις πατήσει....8-)
Ζήλεψαν τα λινουξάκια μάλλον,αλλά μπα....
Όσο κι αν το γδύσουν το λειτουργικό,θα συνεχίσει να είναι 100 φορές βαρύτερο από το πιο βαρύ λίνουξ.
Έχουν γίνει ανάλογες και πιο extreme προσπάθειες στο παρελθόν αλλά για άλλους λόγους (για επίτευξη ρεκόρ μεταξύ overclockers,κλπ).Λίγα κέρδισαν.
Πάντως είναι ελπιδοφόρο που κάποιοι το παλεύουν και σε αυτόν τον τομέα.
Θα δοκιμαστεί και θα τα πούμε...
Manos58
εγχειρισμένη
σαν τον πρωτάρη που πάει σε .....κορίτσι .
Ελπίζει να δει το φως το αληθινό :roflmao:
Sorry παίδες αλλά δεν το έχω καταλάβει... Ο τύπος κόβει διεργασίες από τα Win για να αναπαράγει καλύτερα τη μουσική; Στο δικό μου laptop (compaq -amd dualcore 1.3) που χρησιμοποιώ για αναπαραγωγή με τον κινέζο
ακολούθησα αυτές τις οδηγίες και δεν μασάει τίποτα. Τώρα τελευταία δε, χρησιμοποιώ το ks-plugin του foobar και είμαι απόλυτα ικανοποιημένος.
Α,και να μην ξεχνιόμαστε....
Υπάρχουν χιλιάδες εφαρμογές στο διαδίκτυο που κάνουν ότι λεει αυτό το πράγμα,σε όποιο βαθμό θέλει κανείς,από απλό κόψιμο,μέχρι τελείως extreme (off όλα,δίκτυα,υπηρεσίες,χρώματα,αρώματα,κλπ..)
ΔΩΡΕΑΝ οφ κορς.
(Δεν αποκλείεται το συγκεκριμένο να είναι κάποιο τέτοιο μασκαρεμένο.)
Ο τυπος ειναι καραγκιοζης πρεπει να κλοκαρεις τις συχνοτητες τησ cpu και της ram μεχρι να βρεις αυτη που παιζει καλυτερα αχαχα
You can experiment with different speeds of your CPU and or RAM frequencies, as long as you use a fixed value (do not use “auto”). Listen to whatever sounds best to you.
Το ότι πρέπει να κλοκάρεις ακούγοντας το θεωρώ γελοίο.Τελείως.
Το ότι η ταχύτητα του επεξεργαστή όμως πρέπει να παραμένει σταθερή κι απαλλαγμένη από ελεγκτές κι εξοικονομήσεις ενέργειας, για εμένα έχει βάση.
Αν κανείς παρακολουθήσει την κατανάλωση και την συμπεριφορά του επεξεργαστή,θα δει τεράστιες καμπύλες στην διάρκεια τέτοιων σκαμπανεβασμάτων.Στα οποία ανεβοκατεβάσματα,ακόμα και πολύ ακριβά τροφοδοτικά ζορίζονται.
Καλό είναι λοιπόν να αποφεύγονται κατά την γνώμη μου,προσωπικά έχω απενεργοποιήσει χειροκίνητα ότι θα μπορούσε να προκαλεί τέτοιες εξάρσεις.
Αλλο πραγμα το clocking και η συμετοχη του στον ηχο,και αλλο πραγμα να εχεις ενεργα στο bios τις διαφορες τεχνολογιες που μειωνουν τους κυκλους αναλογα το idle ή full μην τα κανουμε αχταρμα ολα.
Τεσπα υπερβολες του κερατα και παραπληροφορηση.
Για τον τυπο μιλαω βεβαιως.
φαντασου να κανεις steping μεχρι να βρεις που σου αρεσει μιλαμε για χιλιαδες επιλογες
Ειναι 3 χρονια που ακουω μουσικη με 2 PC το ενα για AUDIO pc και το αλλο για CONTROL pc . Με Foobar ( Player) και JPLAY (driver) .Σε HYBERNATE λειτουργια το AUDIO PC.
Ο ηχοσ ηταν οτι καλιτερο ειχα ακουσει μεχρι τοτε απο υπολογιστη. (Ειμαι 60 χρονων με αναλογικα ακουσματα.) Πριν 6 μηνεσ ανακαλιψα το AudiophileOptimizer.
Αγορασα το προγραμα και το εγκατεστισα σε ενα μονο pc με Windows Server 2012 R2.σε GUI mode την πρωτη φορα για να εξικιωθω και μετα το γηρισα σε MINIMAL mode.
Αποτελεσμα - Ο ηχοσ εγηνε ακομα καλητεροσ με φανταστικο ηχο. Αναληση,Χροιεσ.Σωμα .Κυριοσ οταν κατεβαζω DSD φακελουσ. Ειναι σκετη απολαυση οταν ακουω κλασικη η Jazz μουσικη. Εγω ειχα ενα καλο PC και το δευτερο ηταν ενα lamtop τησ πλακασ .Οταν επικινονισα με το Phill (AudiophilOptimizer) με συμβουλεψε .Να χροισημοποιησω ενα μονο Pc μεχρi να φτιαξω ενα HighEnd Audio Pc ( στο site του εχει την δικη του προταση.) Αυτο το καλοκαιρι θα συγκεντροσω ολα τα κοματια και θα τοn στησω.( Audio Pc) kai μετα θα στησω το HighEnd Control Pc.
Αυτο που θελω να πω ειναι οτι . Ο μοναδικοσ τροποσ για να ακουσεισ φακελουσ μεγαλησ αναδηγματολιψιασ σε PCM η DSD ειναι αυτοσ που πρωτεινει ο Phill. Εαν αυτο μπορει να βοηθησει , ειναι σαν να εχv αγορασει ενα cd player των 5.000 Ε. Με την διαφορα , οταν εχεισ αγορασει ενα μηχανιμα αυτησ τησ αξιασ στην αρχη το ερωτευεσε αλλα με τον χρονο ανακαληπτεισ οτι δεν ειναι τελικα αυτο που ηθελεσ τοτε η παιρνεισ την μεγαλη αποφαση να τον αλλαξεισ η αρχηζεισ τισ αλλαγεσ σε DAC σε καλοδια σε στιριγματα κτλ Και ξοδευεισ τα μαλια τησ κεφαλησ σου.
Μου χρειαστικαν μηνεσ ψαξιματοσ ρυθμησησ για να συνδιασω στα δικα μου γουστα το ηχο διοτι εχεισ διαφορεσ επιλογεσ με το foobar player με to JPlay με το AudiophileOptimizer και τελοσ με το windows server. Υραρχει το forum στο Jplay οπου διαφοροι μπορουν να σε συμβουλεψουν αλλα ειναι και ο Phill o opoios παντα ειναι εκει και απανταει αμεσα στα μηνηματα σου( αν καθηστερησει ειναι για μερικεσ ωρεσ)
Το συνγκροτιμα μου αποτελητε απο 1 PC -NAS-M2Tech Hiface με την δικη του Μπαταρια και δικο του CLOCK - Benckmark DAC- CLASSE ολοκλιρομενοσ. Ηχεια Spendor Sp 100.
Καλοδια΄..Ρευματοσ τησ KIMBER σε ολλα τα τμηματα ακομα και στο ΝΑΣ και ΠΣ.
USB καλοδιο τησ Wireworld το οποιο τροφοδοτητε με ρευμα η AQVOX και τελοσ Ethernet καλοδια Cat7 Supra
like :thumbsup:
περισσοτερες λεπτομερειες και οι συδεσμοι θα ενδιεφεραν νομιζω πολλους
αν μου επιτρεπεις ... το w στο πληκτρολογιο ειναι το τελικο ς :)
  • rose.athens
Ruler93
