Zizik's Maxi Home Theater
Τώρα μου τα λές; >:(
Δεν πειράζει, του χρόνου με τον 700 και το 3D!
loggeo
Καλά αφού επιμένεις θα σου πω!:laugh:
Το post είναι απ' το αφεντικό της! Απομονώνω:
In addition, as always, standard HDMI cable rules apply. These include never using an HDMI cable less than 6 feet (2 meters), due to HDMI cable EQ making short cable signals too hot in many cases. Sometimes lengthening a 2 meter cable to a 3 to 5 meter HDMI cable will help if there is quite a bit of cable EQ. As cables approach 30 feet (9 meters) cable length makes HDMI cable quality (including speed rating) and the HDMI receiver’s design critical. Since every HDMI connection will have some level of Transmission-line reflections, which can cause nodal points based on cable length, changing to a slightly shorter or slightly longer cable can move the cable nodal response away from critical failure points.
Try several different brands of HDMI cables if there are issues. At this length differences in manufacturers cable EQ (transmitter and receiver) and speed ratings (2k or 4k) make a significant difference.
Be cautious with name-brand cables. Users have seen issues with some of the more expensive brands. Of course many high-end HDMI cables work well, but why pay more for the same "bits" coming down the wire. Unlike analog cables, the bits are either passed exactly (e.g. solid picture) or they aren't (e.g. sparkles, drop-outs, etc.). Our customers have had good results with Monoprice, DVI Gear, or Bluejeans HDMI cables. For the Mini, XS, XD, XE 2K rated cables work well, but for Radiance 20XX units, please make sure to use 4k rated HDMI cables on the 20XX outputs to either a display or audio processor.
εχτες που λετε ξαφνικα ο Μητσος εφερε μια ταινια χαλαρη να δουμε :D
.....δεν την θυμομουν......οτι πρεπει για τεστ sub (μεγαλα sub ομως) μην την βαλετε εσεις...:D
η ταινια αυτη κατεβαινει ως 1hz και απο τα 5hz δινει μεγαλες εντασεις.
μπορω να πω οτι εξεπλαγην με την αποδοση των svs που φανηκε δε οτι εφτασαν στα ορια τους με -8 την ενταση στον av
ο μεγαλος χρονος που δουλευουν τα sub και το πολυ χαμηλο ειναι πιθανοτατα η αιτια που τα παιζουν ενισχυτες και sub ....
....αν βαλεις και καποιες λανθασμενες ρυθμισεις που μπορει να εχουν γινει στο εκαστοτε setup τα αποτελεσματα ειναι τραγικα για πολλους .....
τετοιες ταινιες θελουν μεγαλα sub με τρελά db εκει χαμηλα στα 15 και 20hz
ιδου ο ενοχος....
War of the World(dts)
αφου περασε και αυτο το τεστ Μητσο εισαι αρχοντας..:imtheking: :)
Αυτό είναι Copy Paste από το διαδίκτυο....
SVS: Γυμναστική, σύσφιξη και καταπολέμηση της κυτταρίτιδας και μυικών παθήσεων χωρίς κόπο?
Πολύ πιθανό να έχεις ακούσει για τον σχετικά πρόσφατο εναλλακτικό τρόπο εκγύμνασης και τόνωσης των μυών με τη βοήθεια χαμηλών συχνοτήτων. Το SVS (υπογουφερομυοδιέγερση) εφαρμόζεται και στη χώρα μας τα τελευταία χρόνια σε σύγχρονα ιδιωτικά (οικιακά) σινεμά κλπ.. Με το SVS γυμνάζεις ακόμη και τις πιο δύσκολες μυϊκές ομάδες του σώματος με τη βοήθεια της χαμηλής συχνότητας συντονισμού, όπου συγκεκριμένα χαμηλές συχνότητες στέλνουν εγκεφαλικά σήματα στους μυς. Ο συγκεκριμένος τρόπος εκγύμνασης δημιουργήθηκε στη Αμερική για τη θεραπεία των ασθενών με μυοσκελετικά προβλήματα και στη συνέχεια γνώρισε μεγάλη απήχηση σε όλο τον κόσμο. Χρησιμοποιείται για ενεργοποίηση του μεταβολισμού, καύση λίπους, αποβολή της κυτταρίτιδας, σύσφιξη, μυϊκή αύξηση, αλλά και αποθεραπεία των μυών.
Οι συνεδρίες διαρκούν συνήθως μισή ώρα, πάντα με την παρακολούθηση εξειδικευμένου personal trainer (Kostas Kefalas).
το copy/paste εχει και το ονομα μου ? :roflmao:
μεγαλο πραμα στο σινεμα το καλο sub και νομιζω δικαιως τα svs τα σπανε στην κατηγορια τους και οχι μονο...
Nick Arvanitakis
Audio Pro
Βουητό , εκρήξεις και τσιρίδες.
Ζιζικ , πότε να φέρω το πικάπ?
Εχει φόνο στέιτζ το ρημάδι σου?
ερχεται η σειρα σου Μ.....κρατησου :fuckyou:
μιας και το xt32 δεν θα κανει δουλεια θα παρουμε δανεικο το fbq 2496 του Μητσου για να δεις την διαφορα του πριν με το μετα...;)
Χρειάζεται άλλο ένα σαμπάκι, στο War of the Worlds BD τα χρειάστηκα λίγο. :D
Καθόμουν στο τραπέζι πίσω απο τον καναπέ και τα πόδια μου πάγωναν απο τον αέρα που ερχόταν στις μπασιές... :rolleyes:
Πού να ξέρω καλέ; Άκου φόνο στέιτζ. :tongue:
Θα κλ@σει το B&W και θα κλαίει ο Μη Κώστα.
Καθόμουν στο τραπέζι πίσω απο τον καναπέ και τα πόδια μου πάγωναν απο τον αέρα που ερχόταν στις μπασιές... :rolleyes:.
ελα βρε......αυτη η ταινια δεν υπαρχει.....ειναι θανατος σε πολυ υψηλες εντασεις που να παιζει και σωστα ομως...
στις εντασεις που ακους αντεχει....απλα εισαι στα ορια σε τετοιες ταινιες .....που ειναι σπανιες.
μια χαρα εισαι βρε τρελε...
Christos Kourmouzoglou
