KH 310 A - Active Studio Monitor στο σαλόνι?
deleted user 10898
General Description
The KH 310 three-way active tri-amplified monitor features a Mathematically Modeled Dispersion™ Waveguide (MMD™), flexible acoustical controls, various input options and an extensive range of mounting hardware. This allows the loudspeaker to be used in diverse acoustical conditions, with any source equipment and in a wide variety of physical locations. The KH 310 represents the latest in acoustic and electronic simulation and measurement technologies to ensure the most accurate sound reproduction possible.
The KH 310 is designed for use as a near-field monitor, as a front loudspeaker in mid-sized multi-channel systems, or as a rear loudspeaker in a larger multi-channel system. It can be used in project, music, broadcast centers, OB vans, and post production studios for tracking, mixing, and mastering.
deleted user 10898
Features
Product Feature Benefit to the Customer
Powerful alloy fabric dome
Low-distortion high-frequency reproduction
Elliptical Mathematically Modeled Dispersion™ (MMD™) waveguide, with wide horizontal and narrow vertical dispersion
Smoother off-axis response,
More forgiving of diverse acoustical environments
Freedom of movement across the mixing console
Reduces reflections off the mixing console
New in-house simulated drivers
Latest modeling techniques used to minimize non-linear (intermodulation) distortion
Fabric dome, neodymium magnet, midrange driver
Dedicated driver reproduces important midrange frequencies, which is especially important for speech and vocals
Light weight dome has better transient response and less breakup modes than cone designs
High power magnet reduces harmonic and intermodulation distortion
Long throw composite sandwich cone bass driver with Extremely Linear Force Factor™ (ELFF™) and ribbed surround
Damping of break-up modes and low distortion at high sound levels
Linear pistonic motor gives a very low harmonic distortion even at high excursions
Reduced radial break-up modes on the ribbed surround
Two-color + dimmable Neumann logo
Displays operation status and activation of the extensive protection system
Dimmable for low lighting level conditions or behind the screen applications
Compact sealed three-way cabinet design (magnetically shielded)
No standing wave resonances
Fastest bass transient response
Reduced intermodulation distortion in midrange
One-piece front panel with no discontinuities
Reduced diffraction and smoother frequency response
Powerful analog class AB amplifiers withlarge headroom
Improved transient response
Independent thermo limiters for woofer, midrange dome and tweeter to protect the voice coils. Woofer soft clip and excursion limiters
Fast acting, high reliability and allows extraction of the maximum performance from the system
Production consistency due to individual hand-alignment in final test
Any KH 310 is “pair-matched” to any otherKH 310
4-position bass, low-mid and trebleacoustical controls
More control in diverse acoustical environments
Wide range input gain and output level controls
Easier interfacing with signal sources
Ground lift
Reduced noise in electrically noisy environments and over-comes ground loops
Universal switched-mode power supply(100 … 240 V)
One version works in any country and robust to poor quality mains supply
Extensive mounting hardware options
More flexibility in mounting cabinets in more diverse locations and backwards compatibility with previous models
Optional robust metal grille
Can be used, if required, to protect the drivers
Optional transportation accessories
Stylish soft carry bag with space for cables
Robust wooden flight case
deleted user 10898
Acoustics
Free field frequency response34 Hz - 21 kHz, ± 3 dB
Pass band free field frequency response36 Hz - 20 kHz, ± 2 dB
Self-generated noise
(with input gain set to 100 dB for 0 dBu)< 20 dB(A) at 10 cm
Total harmonic distortion < 0.5 % at 95 dB SPLat 1 m> 85 Hz
Max. SPL in full space / calc. in half space
at 3% THD at 1m110.3 / 116.3 dB SPL
(averaged between 100 Hz and 6 kHz)
Bass capability: Max. SPL in half space
at 3% THD at 1m104.5 dB SPL
(averaged between 50 Hz and 100 Hz)
Max. short term SPL with IEC-weighted noise (IEC 60268-5) at 1 m, in typical listening conditions113 dB(C) SPL
Max. short term SPL with music material
at 2.3 m, in typical listening conditions (pair)100 dB(C) SPL (full range)
107 dB(C) SPL (with subwoofer)
Max. long term SPL with pink noise at 2.3 m, in typical listening conditions (single/pair)93 / 99 dB(C) SPL (full range)
94 / 100 dB(C) SPL (with subwoofer)
Electronics
Bass / Midrange / Treble Class AB amplifiers, cont. (peak) output power*150 W (210 W) / 70 W (90 W) / 70 W (90 W)
Controller designAnalog, active
Crossover frequencies650 Hz / 2 kHz
Crossover slope24 dB/oct, 4th order
Equalization - Bass0, −2.5, −5, −7.5 dB
Equalization - Low Mid0, −1.5, −3, −4.5 dB
Equalization - Treble+1, 0, −1, −2 dB
Protection circuitryIndependent thermo limiters for woofer, midrange dome and tweeter. Woofer soft clip and excursion limiters
Infrasonic filter - frequency; slope15 Hz; 6 dB/oct
Input
XLR, analog electronically balanced
deleted user 10898
Πριν από πολλά χρόνια, το 2009, ο KostaEar παρουσίασε με εξαιρετικό τρόπο στο νήμα
Ηχείο - πλήρες ηχοσύστημα - η δύναμη της λογικής
τα μεγάλα ηχεία της klein and hummel.
Τα μικρότερα ηχεία της ίδιας εταιρίας, τα klein hummel 300, αποτέλεσαν ένα απόλυτο εργαλείο για την μίξη ήχου σε χιλιάδες studio ανά τον κόσμο.
Η μεγάλη εμπορική επιτυχία έκανε την προσδοκία για την επόμενη σειρά μεγάλη.
Όταν δε μπήκε και η Neumann στο παιχνίδι και ειδικά μετά την παρουσίαση των εξαιρετικών Neumann 120, οι προσδοκίες εκτινάχθηκαν και μαζι η αναμονή...
Τα πρώτα δείγματα ηταν εξαιρετικά και τα τεστ στο sound on sound αλλα και στο gearslutz διθυραμβικά...
Overall, then, the new KH310A is even better than its forebear. I'd go as far as to state that it easily rates as one of the very best active three-way monitors currently available, as well as one of the most compact. It certainly gets my vote for 'Best New Monitor of the Year'!
In every way, this is a stunningly good reference monitor and one that is genuinely worthy of that title. It also represents excellent value for money, too. For a number of reasons I never quite got around to purchasing a pair of O300s (although I did borrow pairs a few times for specific jobs), but I will buy these KH310As rather than let them go back to Germany — I really couldn't work without them now! .
http://www.soundonsound.com/sos/oct13/articles/neuman-kh310a.htm
deleted user 10898
Το πρόβλημα με τα klein hummel και τωρα Neumann στην Ελλάδα ήταν ότι ήταν/είναι ουσιαστικά αδύνατο να βρεις ένα ζευγάρι για ακρόαση. Έτσι, μέσα από τα pdf και τις ακροάσεις ΑΛΛΩΝ προσπαθείς να καταλάβεις αυτο που θα μας ενδέφερε εδώ πραγματικά....
Είναι αυτο το ηχείο μια καλή επιλογή για ακροάσεις σε οικιακό περιβάλλον?
Η τιμή του , κάτω απο τα 3800 το ζευγάρι, αποτελεί τιμιότατη πρόταση λαμβανομένης υπόψιν της ενσωμάτωσης ενισχυτών (και φυσικά και καλωδίων) στο "πακέτο".
Για να δούμε λοιπόν τα pdf και το ... σαλόνι μας....
Manos58
εγχειρισμένη
Στο όνειρο σου τα έβλεπες ;
.....ότι ήταν/είναι ουσιαστικά αδύνατο να βρεις ένα ζευγάρι για ακρόαση..........
Το μεγαλύτερο μειονέκτημα του .Και δεν εννοώ να τα πάρεις "στο χώρο σου".
Η ορθότητα της απόκρισης δεν αποτελεί διαβατήριο για το σαλόνι του μουσικόφιλου .
ΥΓ Με το μιντ θόλου θα αρέσουν και στον Β..........:whistling: ATC
deleted user 10898
Μιλάμε για ηχείο κλειστής καμπίνας , με 3 μονάδες ,έναν ενισχυτή ανά μονάδα, ενεργό x-over και αναλογική είσοδο.
Μανος.. "Η ορθότητα της απόκρισης δεν αποτελεί διαβατήριο για το σαλόνι του μουσικόφιλου ."
Η διασπορά Μάνο?
Ουσιαστικά λοιπόν, ο οδηγός του tweeter που η εταιρία ονομάζει MMD κάνει την απόκριση συχνοτήτων εκτός άξονα ποιο ομοιόμορφη. Όσοι παρακολουθείται τις "αναζητήσεις" μου με τους acοustic lens των Beolab 5 βλέπετε ότι στο παραπάνω πινακάκι συνοψίζεται η "ουσία"....
Η ομοιόμορφη διασπορά εκτός άξονα κάνει τις πλάγιες αντανακλάσεις (που σε περιβάλλον οικιακό είναι πολύ περισσότερες απο ενα studio) να φθάνουν με ίδια/παρεμφερή ενέργεια προς τον ακροατή. Χονδρικά και "λιανά" απο τις αντανακλάσεις δεν τονίζονται περισσότερο κάποιες συχνότητες σε σχέση με άλλες, όπως σε ένα ηχείο με το κλασικό "στένεμα" της διασποράς στις υψηλές συχνότητες.
Επίσης το sweet spot είναι ποιό μεγάλο, κάτι ευκταίο σε οικιακό περιβάλλον...
deleted user 10898
Φυσικά η δικιά μου η προσέγγιση είναι ερασιτεχνική και η γνώσεις ελλιπείς, κουβέντα θέλω να γίνει για να ΜΑΘΩ και εγω.
Ας δούμε λοιπόν τι λέει κάποιος που ισως.. ξέρει...
13) Fundamental Questions:
1 - Can loudspeakers and listening room disappear from auditory perception?
2 - Is there an optimum radiation pattern?
3 - Is there an optimum loudspeaker + listener + room setup?
My answer to all 3 questions is YES!
Provided that we have an appropriate
* Radiation pattern
* Speaker positioning and
* Room acoustics
1) Loudspeaker and room can disappear from perception, leaving only a phantom auditory scene in front of the listener, provided that the loudspeakers have essentially frequency independent directivity and provided that they are set up in the room with some distance from large reflecting surfaces, That way the reflected and reverberated sounds in the room have the same tonal character as the direct sound but are delayed such that the brain focuses on the direct sound and creates the illusion.
2) Here you see the sketch of an optimum directivity loudspeaker. It is a dipolar radiator from the lowest bass to the top of the frequency range.
Its radiation pattern is essentially a constant figure-of-eight at all frequencies. The typical box loudspeaker is omnidirectional at low frequencies and becomes more and more directional at high frequencies.
The optimum setup is symmetrical with respect to reflecting surfaces with the loudspeakers at some distance from them. The sweet spot is at the apex of the equilateral triangle, So nothing is new here, except that the sweet spot becomes very wide. The sound does not change when listening at greater distance or off-axis. Only the precision of imaging changes.
The listening room itself is optimized by being diffusive behind the loudspeakers and absorbing the sound behind the listener. Rather than a closed box the room should be thought of as a waveguide. The sound from the loudspeaker end of the room travels towards and past the listener and disappears without reflection. While this ideal may not always be achievable it can serve as a guide of where to provide diffusive and absorptive room surfaces.
With this type of room, this type of loudspeaker and listening room setup it is left up to the recorded material to establish the quality of the illusion.
deleted user 10898
Και μια που το ανέφερε ο Μάνος, κοιτάχτε τι μέτρησε ο "άνθρωπος" στα 2 μέτρα...
deleted user 10898
Όσο διαβάζω τα pdf τόσο αρχίζω να πιστεύω ότι το "ηχειάκι" θα αποτελούσε ιδανικό "εργαλείο" σε οικιακό περιβάλλον....
Και μην νομίζεται ότι η Neumann "νοιάζεται" για εμάς...
Κυκλοφόρησαν κάποια στιγμή μετρήσεις κάποιας εταιρείας με την απόκριση συχνότητας ενός μονιτορ ηχείου της σε διαφορετικά studio... έγινε... το έλα να δεις... οπότε... ΞΕΡΟΥΝ.
Απευθύνονται σε τεράστιο κοινό και θέλουν να παίζει καλά σε πολλούς.
Manos58
εγχειρισμένη
Πήρες κατά γράμμα αυτό που έγραψα .
Εγώ εννοούσα το κλασσικό "αν παιζ "
Η μικρή μου εμπειρία στο χώρο με έχει πείσει οτι hifi &ορθολογισμός είναι προαιώνιοι οχτροί .
deleted user 10898
κοίτα... το αν "παιζ" "στον χώρο ΜΟΥ" κλπ highendοτσιτάτα είναι κάτι που προσπαθούμε σιγά σιγά να δώσουμε στον κόσμο να καταλάβει ότι θα μπορεί να το ΞΕΡΕΙ διαβάζοντας κάποια πράγματα και αν γνωρίζει (δηλαδή ουσιαστικά μετρώντας) τον χώρο του.
Δεν είναι δύσκολο να καταλάβεις γιατι το ηχείο αυτο θα παίξει καλύτερα/σωστότερα απο τα περισσότερα πχ wilson σε πολλους οικιακούς χώρους.
Και για να συνεχίσουμε παρακάτω, είναι ευτύχημα μια εταιρία να προσπαθεί να κάνει ένα ηχείο προσαρμόσιμο σε πολλούς χώρους.
κοιτάχτε πχ τις μικροδιορθώσεις του EQ.
dapost
Rehdeko & Harbeth lover
"When the words 'mid-range' and 'special' are used in the same sentence, a lot of people will think of the well-known and much-loved ATC mid-range driver, and K+H actually used it in their O500C model. However, it was deemed too expensive for the new KH310A, so the Neumann/K+H designers designed their own 75mm mid-range dome driver, which they describe as being more cost-effective, more sensitive, having lower THD and intermodulation distortion, and better break-up behaviour. That's a very bold claim, but on listening it is very easy to believe; the mid-range is very revealing and very accurate."
dapost
Στην ώριμη πλέον εποχή του digital room correction, τέτοια ρυθμιστικά είναι άχρηστα. Αντίθετα είναι απαραίτητο ένα high-pass filter γιατί αργά ή γρήγορα θα πρέπει να προστεθούν sub. Έχει τέτοιο; Αυτό που επίσης θεωρώ απαραίτητο σε state-of-the-art ηχείο του 2014 είναι να είναι όλες οι μονάδες time-aligned για grimm-like impulse response. Ετούτο, είναι;
εγω θελω συγκριση μεταξυ KH-310 και adam s3x-h...
στο βιντεο εδω, απ το tube (που δεν λεει τιποτα - το ξερω), το adam για μενα ειναι πιο ευχαριστο στο αυτι, ενω πιο φλατ παιζει το kh-310...αλλα ας το αφησουμε στην ακρη το βιντεο ειπαμε...αλλο συγκριτικο υπαρχει?
deleted user 10898
ωραία... το ηχείο κατεβαίνει φλατ στα 40 και με λιγα ντιμπι μειoν αρκετα ποιο κατω.
Θεωρεις λοιπον οτι η αυξηση της παραμόρφωσης κατω απο τα 80hz ειναι τετοια που ΠΡΕΠΕΙ να προστεθουν sub?
deleted user 10898
ξέρεις πως το κάνει αυτο η Grimm?
θα μπορουσε να εχει εφαρμογη στο συγκεκριμενο με το συγκεκριμενο κοστολόγιο?
Η συγκριση που θα ηθελα να κανω δεν ειναι με τα Grimm Ls1, είναι με καθε πιθανο συνδυασμο home ηhi-fi ηχειων και ενισχυτικων στην κατηγορία τιμης τους.
dapost
Τι να σου πω; Το πρέπει είναι πολύ σχετικό. Δες τι λένε οι πιο ειδικοί στην παράγραφο 6.3:
http://www.grimmaudio.com/site/assets/files/1088/speakers.pdf
dapost
Αυτό είναι πολύ ενδιαφέρον θέμα που σηκώνει δικό του νήμα. Μάλλον έχεις δίκαιο και δε θα μπορούσε να γίνει χωρίς ισχυρό onboard dsp. Από την άλλη, δεν μπορεί να επιτευχθεί και με αναλογικό cross; Εδώ το καταφέρνει ο vandersteen με παθητικό cross και ενεργό σαμπ:
dapost
Κατά τα άλλα μια χαρά ηχεία φαίνονται ότι είναι. Και προσφέρονται σε πολύ λογική τιμή σε μια πολύ ανταγνωστική κατηγορία. Και είναι και ομορφούτσικα. Γενικά οι τιμές των επαγγελματικών ηχείων είναι προσγειωμένες και πάντα συσχετίζονται με την προσφερόμενη αξία.
roberto_portale
