Review of the new ATC SCM40
Τι ακριβώς σημαινει πληρωτέα; Τα πουλανε και διχως η τιμη να ειναι πληρωτέα δηλαδη;
lakiss51
Εννοει αφαιρουμενης της εκπτωσης - μονο που δεν ισχυει αυτη η τιμη!
dapost
Rehdeko & Harbeth lover
Και ενεργή έκδοση:
New ATC designed and built dual suspension 25mm soft dome HF unit with precision alloy wave guide.
ATC Soft Dome mid-range driver.
ATC 164mm short coil bass driver.
All drive units incorporate massive optimised motor assemblies.
On-board grounded source 235 watt Class A/B Tri-amplifier.
Active filters and overload protection.
6 year warranty.
Retail Price: £6280
Specifications:
Drivers: HF ATC 25mm dual suspension Tweeter, Mid 75mm ATC Soft Dome, LF ATC 164mm SC
Matched Response: ±0.5dB
Frequency Response (-6dB): 48Hz-22kHz
Dispersion: ±80° Coherent Horizontal, ±10° Coherent Vertical
Max SPL: 112dB
Crossover Frequencies: 380Hz & 3.5kHz
Connectors: Male XLR
Input sensitivity : 1V
Filters : 4th Order critically damped with phase compensation.
Overload Protection : Active FET momentary gain reduction.
Fault Protection : DC fault protection and thermal trip. Fault indication on rear panel mounted LED.
Amplifier Output: 150W LF, 60W MF, 25W HF
Cabinet Dimensions (HxWxD): 980x370x344mm (spikes add 25mm, grill adds 34mm to depth)
Weight: 36kg
ysl
