Neumann KH 420 & KH 310 D
Press Release: Neumann is expanding the successful KH line with its first midfield monitor – the KH 420. The active 3-way system (10-inch/3-inch/1-inch) is ideal for larger 5.1 and 7.1 configurations and listening distances of up to 11 meters.
With a corner frequency of 52 Hz, the KH 120 nearfield monitor set new standards in its class for low frequency performance. Neumann engineers have succeeded in raising the bar with the KH 420 too. Its 26 Hz corner frequency is not only lower than other comparable midfield monitors; it is also a whole octave lower than the KH 120. Anyone requiring even lower bass reproduction for surround systems with a dedicated LFE channel can add the KH 870 woofer to extend the response down to 18 Hz.
An optional Digital Input Module (DIM 1) is available for the KH 420 which provides the monitor with digital AES3 and S/P-DIF inputs and a delay function. This feature, which is available on both the digital and analog inputs, may be used for audio/video lip synchronization and to compensate for non-equidistant speaker placement. Maximum delay time is 409.5 ms with a minimum resolution of 0.1 ms.
The KH 310 D nearfield monitor
One of the most compact 3-way monitors in its class, the KH 310 is the perfect choice for situations where space is limited. In addition to extra digital inputs, this brand new digital version, designated KH 310 D, comes with all the delay features of the DIM 1 module described above.
With the KH 120 D, the KH 310 D and the KH 420 with optional DIM 1 module, Neumann now offers monitors in three distinct size classes to support a completely digital workflow.
KH 420 €3837 (excl. VAT)
KH 310 D €2229 (excl. VAT)
απο εδω...
xkaragi
